IC Python API:RLPy RDeviceSetting
From Reallusion Wiki!
Jump to: navigation, search
Main article: Modules.
Detailed Description
This class is the device setting used in the device class, such as RBodyDevice and RHandDevice. Provide methods to set the coordinate system (Lefthand/Righthand),axis orientation(Up & Front), offset data(Rotation & Position offset) and setting data(RPositionSetting & RRotationSetting).
Member Functions
GetAxisXYZ
RLPy.RDeviceSetting.GetAxisXYZ ( self, eAxis )
Get vector of an axis.
Parameters
eAxis [IN] An axis - RLPy.ECoordinateAxis
  • RLPy.ECoordinateAxis_X
  • RLPy.ECoordinateAxis_NegativeX
  • RLPy.ECoordinateAxis_Y
  • RLPy.ECoordinateAxis_NegativeY
  • RLPy.ECoordinateAxis_Z
  • RLPy.ECoordinateAxis_NegativeZ
Returns
Vector of an axis - float
GetCoordinateOffset
RLPy.RDeviceSetting.GetCoordinateOffset ( self, fRotation, vTranslation )
Get translation and rotation offset of the mocap coordinate.
Parameters
fRotation [OUT] Rotation offset - float
vTranslation [OUT] Translation offset - float
GetCoordinateSystem
RLPy.RDeviceSetting.GetCoordinateSystem ( self )
Get coordinate system. ( Default value is ECoordinateSystem::RIGHT_HAND )
Returns
Coordinate system - RLPy.ECoordinateSystem
  • RLPy.ECoordinateSystem_RightHand
  • RLPy.ECoordinateSystem_LeftHand
GetMocapCoordinateFrontAxis
RLPy.RDeviceSetting.GetMocapCoordinateFrontAxis ( self )
Get front-axis of mocap coordinate. ( Default value is ECoordinateAxis::NEGATIVE_Y )
Returns
Front-axis of mocap coordinate - RLPy.ECoordinateAxis
GetMocapCoordinateSystem
RLPy.RDeviceSetting.GetMocapCoordinateSystem ( self )
Get coordinate system of mocap coordinate. ( Default value is ECoordinateSystem::RIGHT_HAND )
Returns
Coordinate system of mocap coordinate - RLPy.ECoordinateSystem
GetMocapCoordinateUpAxis
RLPy.RDeviceSetting.GetMocapCoordinateUpAxis ( self )
Get up-axis of mocap coordinate. ( Default value is ECoordinateAxis::Z )
Returns
Up-axis of mocap coordinate - RLPy.ECoordinateAxis
GetPositionSetting
RLPy.RDeviceSetting.GetPositionSetting ( self )
Get position setting.
Returns
Position setting - RLPy.RPositionSetting
GetRotationSetting
RLPy.RDeviceSetting.GetRotationSetting ( self )
Get rotation setting.
Returns
Rotation setting - RLPy.RRotationSetting
SetCoordinateOffset
RLPy.RDeviceSetting.SetCoordinateOffset ( self, fRotation, vTranslation )
Set translation and rotation offset of the mocap coordinate.
Parameters
fRotation [IN] Rotation offset - float
vTranslation [IN] Translation offset - float
SetCoordinateSystem
RLPy.RDeviceSetting.SetCoordinateSystem ( self, eCoordinateSystem )
Set coordinate system.
Parameters
eCoordinateSystem [IN] Coordinate system - RLPy.ECoordinateSystem
SetMocapCoordinate
RLPy.RDeviceSetting.SetMocapCoordinate ( self, eUpAxis, eFrontAxis, eCoordinateSystem )
Set mocap coordinate.
Parameters
eUpAxis [IN] Up-axis - RLPy.ECoordinateAxis
eFrontAxis [IN] Front-axis - RLPy.ECoordinateAxis
Return Values
RLPy.RStatus.Success Success
RLPy.RStatus.Failure Fail
