IC8 Python API:RLPy RBakeTextureOption
From Reallusion Wiki!
Jump to: navigation, search
Description
This class provides options for configuring a mesh texture-baking operation.
Constructor & Destructor
__init__ (self)
Initializes a new bake texture option instance.
Properties
bUseCage
Enables use of a projection cage when baking textures.
eNormalMode
Selects the normal-map baking mode.
eNormalSpace
Selects how normal-map space is handled during texture baking.
fBiasDist
Distance bias applied during texture projection.
fCageOffset
Absolute projection-cage offset, measured in iClone/CC units (1 unit equals 1 cm).
kChannels
Names of the texture channels to bake.
kDefaultColor
RGB color values used as the default bake color.
kExtendChannels
Texture channel names to extend during texture baking.
strBodyMeshName
Name of the body mesh used for the bake operation.
strTargetMaterial
Name of the material that receives the baked textures.
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
uOutputSize
Output texture size setting.
