IC8 Python API:RLPy RBodySetting
Contents
- 1 Description
- 2 Constructor & Destructor
- 3 Member Functions
- 3.1 GetActivePart (self)
- 3.2 GetCoordinateOffset (self, fRotation, vTranslation)
- 3.3 GetFixLowerState (self)
- 3.4 GetFootBottomToAnkle (self)
- 3.5 GetHipPositionLockedAxes (self)
- 3.6 GetLockFootRotationState (self)
- 3.7 GetMirrorState (self)
- 3.8 GetMotionApplyMode (self)
- 3.9 GetMotionMatchSource (self)
- 3.10 GetReferenceAvatar (self)
- 3.11 SetActivePart (self, eActivePart)
- 3.12 SetCoordinateOffset (self, fRotation, vTranslation)
- 3.13 SetFixLowerState (self, bIsFixLower)
- 3.14 SetFootBottomToAnkle (self, fFootBottomToAnkle)
- 3.15 SetHipPositionLockedAxes (self, eAxes)
- 3.16 SetLockFootRotationState (self, bIsLockFootRotation)
- 3.17 SetMirrorState (self, bIsMirror)
- 3.18 SetMotionApplyMode (self, eMotionApplyMode)
- 3.19 SetMotionMatchSource (self, bMatchSource)
- 3.20 SetReferenceAvatar (self, spAvatar)
- 4 Properties
Description
This class is used to store the settings of body motion capture.
__init__ (self, *args)
copy constructor
Parameters
- args
Member Functions
Get active part.
Sample code
Demonstrates calls to `RLPy.RBodySetting.GetActivePart`, `RLPy.RBodySetting.GetFixLowerState`, `RLPy.RBodySetting.GetFootBottomToAnkle`, `RLPy.RBodySetting.GetHipPositionLockedAxes`, `RLPy.RBodySetting.GetLockFootRotationState`, `RLPy.RBodySetting.GetMirrorState`, `RLPy.RBodySetting.GetMotionApplyMode`, `RLPy.RBodySetting.GetMotionMatchSource`, `RLPy.RBodySetting.SetActivePart`, `RLPy.RBodySetting.SetFixLowerState`, `RLPy.RBodySetting.SetFootBottomToAnkle`, `RLPy.RBodySetting.SetHipPositionLockedAxes`, `RLPy.RBodySetting.SetLockFootRotationState`, `RLPy.RBodySetting.SetMirrorState`, `RLPy.RBodySetting.SetMotionApplyMode`, and `RLPy.RBodySetting.SetMotionMatchSource` using the example's inputs.
def run_script():
import RLPy
value = RLPy.RBodySetting()
active = value.GetActivePart()
value.SetActivePart(active)
mirror = value.GetMirrorState()
value.SetMirrorState(not mirror)
assert value.GetMirrorState() is (not mirror)
value.SetMirrorState(mirror)
fix_lower = value.GetFixLowerState()
value.SetFixLowerState(not fix_lower)
assert value.GetFixLowerState() is (not fix_lower)
value.SetFixLowerState(fix_lower)
lock_rotation = value.GetLockFootRotationState()
value.SetLockFootRotationState(not lock_rotation)
assert value.GetLockFootRotationState() is (not lock_rotation)
value.SetLockFootRotationState(lock_rotation)
foot = value.GetFootBottomToAnkle()
value.SetFootBottomToAnkle(foot + 0.25)
changed_foot = value.GetFootBottomToAnkle()
value.SetFootBottomToAnkle(foot)
mode = value.GetMotionApplyMode()
value.SetMotionApplyMode(mode)
axes = value.GetHipPositionLockedAxes()
value.SetHipPositionLockedAxes(axes)
match = value.GetMotionMatchSource()
value.SetMotionMatchSource(not match)
assert value.GetMotionMatchSource() is (not match)
value.SetMotionMatchSource(match)
return (active, mirror, fix_lower, lock_rotation, foot, changed_foot, mode, axes, match)
Get coordinate offset.
Parameters
- fRotation
- vTranslation
Get fix lower state.
Sample code
def run_script():
import RLPy
Get foot bottom to ankle.
Sample code
def run_script():
import RLPy
Get hip position locked axes.
Sample code
def run_script():
import RLPy
Get lock foot rotation state.
Sample code
def run_script():
import RLPy
Get mirror state.
Sample code
def run_script():
import RLPy
Get motion apply mode.
Sample code
def run_script():
import RLPy
Gets force motion match source enable state.
Sample code
def run_script():
import RLPy
Get reference handle.
Set active part.
Parameters
- eActivePart
Sample code
def run_script():
import RLPy
Set coordinate offset.
Parameters
- fRotation
- vTranslation
Set fix lower state.
Parameters
- bIsFixLower
Sample code
def run_script():
import RLPy
Set foot bottom to ankle.
Parameters
- fFootBottomToAnkle
Sample code
def run_script():
import RLPy
Set hip position locked axes.
Parameters
- eAxes
Sample code
def run_script():
import RLPy
Set avatar active part.
Parameters
- bIsLockFootRotation
Sample code
def run_script():
import RLPy
Set mirror state.
Parameters
- bIsMirror
Sample code
def run_script():
import RLPy
Set motion apply mode.
Parameters
- eMotionApplyMode
Sample code
def run_script():
import RLPy
Sets force motion match source.
Parameters
- bMatchSource
Sample code
def run_script():
import RLPy
Set reference avatar.
Parameters
- spAvatar
Properties
active_part
Body part selected for the body-setting operation.
fix_lower_state
Indicates whether the lower-body state is fixed.
foot_bottom_to_ankle
Distance from the bottom of the foot to the ankle.
hip_position_locked_axes
Coordinate axes locked for hip positioning.
lock_foot_rotation_state
Indicates whether foot rotation is locked.
mirror_state
Indicates whether the body settings use mirrored state.
motion_apply_mode
Mode used to apply motion to the body.
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
