IC8 Python API:RLPy RCameraDofData
Contents
- 1 Description
- 2 Constructor & Destructor
- 3 Member Functions
- 3.1 GetCenterColorWeight (self)
- 3.2 GetEdgeDecayPower (self)
- 3.3 GetEnable (self)
- 3.4 GetFarBlurScale (self)
- 3.5 GetFarTransitionRegion (self)
- 3.6 GetFocus (self)
- 3.7 GetMinBlendDistance (self)
- 3.8 GetNearBlurScale (self)
- 3.9 GetNearTransitionRegion (self)
- 3.10 GetRange (self)
- 3.11 SetCenterColorWeight (self, fCenterColorWeight)
- 3.12 SetEdgeDecayPower (self, fEdgeDecayPower)
- 3.13 SetEnable (self, bEnable)
- 3.14 SetFarBlurScale (self, fFarBlurScale)
- 3.15 SetFarTransitionRegion (self, fFarTransitionRegion)
- 3.16 SetFocus (self, fFocusData)
- 3.17 SetMinBlendDistance (self, fMinBlendDistance)
- 3.18 SetNearBlurScale (self, fNearBlurScale)
- 3.19 SetNearTransitionRegion (self, fNearTransitionRegion)
- 3.20 SetRange (self, fRangeData)
- 4 Properties
Description
RCameraDofData is used to store the DOF related settings for the camera. https://manual.reallusion.com/iClone_7/ENU/Content/iClone_7/Pro_7.4/10_Scene/Camera/The_Concept_of_DOF.htm See also: RICamera
__init__ (self)
Create a camera Depth of Field settings data structure.
Member Functions
Returns the center color weight.
Sample code
Demonstrates calls to `RLPy.RCameraDofData.GetCenterColorWeight`, `RLPy.RCameraDofData.GetEnable`, `RLPy.RCameraDofData.SetCenterColorWeight`, and `RLPy.RCameraDofData.SetEnable` using the example's inputs.
import RLPy
def run_script():
dof_data = RLPy.RCameraDofData()
dof_data.SetEnable(True)
dof_data.SetCenterColorWeight(0.625)
return (
dof_data.GetEnable(),
dof_data.GetCenterColorWeight(),
Get the power of the edge decay for the camera DOF.
Sample code
Calls `RLPy.RCameraDofData.GetEdgeDecayPower` with the inputs shown in the example.
def run_script():
import RLPy
new_data = RLPy.RCameraDofData()
new_data.SetEdgeDecayPower(20)
print( new_data.GetEdgeDecayPower() )
GetEnable (self)
Get the active state of the camera DOF.
Sample code
import RLPy
def run_script():
return (
Get the camera DOF Far Blur Scale.
Sample code
Calls `RLPy.RCameraDofData.GetFarBlurScale` with the inputs shown in the example.
def run_script():
import RLPy
new_data.SetFarBlurScale(3)
print( new_data.GetFarBlurScale() )
Get the camera DOF Far Transition Region.
Sample code
Calls `RLPy.RCameraDofData.GetFarTransitionRegion` with the inputs shown in the example.
def run_script():
import RLPy
new_data.SetFarTransitionRegion(5)
print( new_data.GetFarTransitionRegion() )
GetFocus (self)
Get the camera DOF Focus value.
Sample code
Calls `RLPy.RCameraDofData.GetFocus` with the inputs shown in the example.
def run_script():
import RLPy
new_data.SetFocus(20)
print( new_data.GetFocus() )
Get the camera DOF's Min Blend Distance.
Sample code
Calls `RLPy.RCameraDofData.GetMinBlendDistance` with the inputs shown in the example.
def run_script():
import RLPy
new_data.SetMinBlendDistance(0.2)
print( new_data.GetMinBlendDistance() )
Get the camera DOF Near Blur.
Sample code
Calls `RLPy.RCameraDofData.GetNearBlurScale` with the inputs shown in the example.
def run_script():
import RLPy
new_data.SetNearBlurScale(2)
print( new_data.GetNearBlurScale() )
Get the camera DOF Near Transition Region.
Sample code
Calls `RLPy.RCameraDofData.GetNearTransitionRegion` with the inputs shown in the example.
def run_script():
import RLPy
new_data.SetNearTransitionRegion(5)
print( new_data.GetNearTransitionRegion() )
GetRange (self)
Get the camera DOF range value.
Sample code
Calls `RLPy.RCameraDofData.GetRange` with the inputs shown in the example.
def run_script():
import RLPy
new_data.SetRange(20)
print( new_data.GetRange() )
Set the camera DOF's Center Color Weight.
Parameters
- fCenterColorWeight
Sample code
import RLPy
def run_script():
return (
Sample code
Calls `RLPy.RCameraDofData.SetCenterColorWeight` with the inputs shown in the example.
def run_script():
import RLPy
new_data.SetCenterColorWeight(20)
Set the power of the edge decay for the camera DOF.
Parameters
- fEdgeDecayPower
Sample code
def run_script():
import RLPy
Sample code
Calls `RLPy.RCameraDofData.SetEdgeDecayPower` with the inputs shown in the example.
def run_script():
import RLPy
Whether or not to activate the DOF funcationalities.
Parameters
- bEnable
Sample code
import RLPy
def run_script():
return (
Sample code
Calls `RLPy.RCameraDofData.SetEnable` with the inputs shown in the example.
def run_script():
import RLPy
data.SetEnable( False )
data.SetEnable( True )
Set the camera DOF Far Blur Scale.
Parameters
- fFarBlurScale
Sample code
def run_script():
import RLPy
Sample code
Calls `RLPy.RCameraDofData.SetFarBlurScale` with the inputs shown in the example.
def run_script():
import RLPy
Get the DOF Far Transition Region.
Parameters
- fFarTransitionRegion
Sample code
def run_script():
import RLPy
Sample code
Calls `RLPy.RCameraDofData.SetFarTransitionRegion` with the inputs shown in the example.
def run_script():
import RLPy
new_data.SetFarTransitionRegion(100)
Set the camera DOF focus value.
Parameters
- fFocusData
Sample code
def run_script():
import RLPy
Sample code
Calls `RLPy.RCameraDofData.SetFocus` with the inputs shown in the example.
def run_script():
import RLPy
Set the camera DOF Min Blend Distance.
Parameters
- fMinBlendDistance
Sample code
def run_script():
import RLPy
Sample code
Calls `RLPy.RCameraDofData.SetMinBlendDistance` with the inputs shown in the example.
def run_script():
import RLPy
Parameters
- fNearBlurScale
Sample code
Calls `RLPy.RCameraDofData.SetNearBlurScale` with the inputs shown in the example.
def run_script():
import RLPy
Sample code
def run_script():
import RLPy
Parameters
- fNearTransitionRegion
Sample code
Calls `RLPy.RCameraDofData.SetNearTransitionRegion` with the inputs shown in the example.
def run_script():
import RLPy
Sample code
def run_script():
import RLPy
Set the camera DOF range value.
Parameters
- fRangeData
Sample code
Calls `RLPy.RCameraDofData.SetRange` with the inputs shown in the example.
def run_script():
import RLPy
Sample code
def run_script():
import RLPy
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
