IC8 Python API:RLPy RColor
Contents
- 1 Description
- 2 Constructor & Destructor
- 3 Member Functions
- 3.1 A (self, *args)
- 3.2 AdjustHSBC (self, fHue, fSaturate, fBrightness, fContrast, bInvert)
- 3.3 AdjustRGBA (self, fRed, fGreen, fBlue, fAlpha, bInvert)
- 3.4 Alpha (self)
- 3.5 B (self, *args)
- 3.6 Blue (self)
- 3.7 From (self, r, g, b, a)
- 3.8 FromARGB (self, arg2)
- 3.9 FromCOLORREF (self, arg2)
- 3.10 FromHSL (self, fHue, fSaturate, fLevel)
- 3.11 G (self, *args)
- 3.12 GammaCorrect (self, fGamma)
- 3.13 Green (self)
- 3.14 Normalize (self)
- 3.15 R (self, *args)
- 3.16 Red (self)
- 3.17 Saturate (self)
- 3.18 ToARGB (self)
- 3.19 ToCOLORREF (self)
- 3.20 ToGrayScale (self)
- 3.21 ToHSL (self, fHue, fSaturate, fLevel)
- 3.22 __add__ (self, arg2)
- 3.23 __eq__ (self, arg2)
- 3.24 __iadd__ (self, arg2)
- 3.25 __imul__ (self, *args)
- 3.26 __isub__ (self, arg2)
- 3.27 __itruediv__ (self, *args)
- 3.28 __lt__ (self, arg2)
- 3.29 __mul__ (self, *args)
- 3.30 __ne__ (self, arg2)
- 3.31 __neg__ (self)
- 3.32 __sub__ (self, arg2)
- 3.33 __truediv__ (self, *args)
- 4 Properties
- 5 Constants
Description
Primary color class that stores data for red (R), green (G), and blue (B). The value stored in RColor ranges from 0 to 1, which represents 0 to 255 in color value. You can swtich between these two representations in different ways; For example, the range of values retrieved by R is 0 to 1, and the range of values retrieved by Red is 0 to 255. In addition, preset colors are provided for direct usage: {| class="wikitable" !Constant !Value |- |RLPy.RColor.BLACK |RLPy.RColor(0, 0, 0) |- |RLPy.RColor.WHITE |RLPy.RColor(1, 1, 1) |- |RLPy.RColor.RED |RLPy.RColor(1, 0, 0) |- |RLPy.RColor.GREEN |RLPy.RColor(0, 1, 0) |- |RLPy.RColor.BLUE |RLPy.RColor(0, 0, 1) |- |RLPy.RColor.YELLOW |RLPy.RColor(1, 1, 0) |- |RLPy.RColor.CYAN |RLPy.RColor(0, 1, 1) |- |RLPy.RColor.MAGENTA |RLPy.RColor(1, 0, 1) |} This class also provides conversions to other color formats: See Also: RRgb
__init__ (self, *args)
Initializes a new color value instance.
Parameters
- args
Member Functions
A (self, *args)
Get the alpha value of this color (0-1). See Also: Alpha
Parameters
- args
Sample code
Demonstrates calls to `RLPy.RColor.__itruediv__` and `RLPy.RColor.__truediv__` using the example's inputs.
import RLPy
def run_script():
source = RLPy.RColor(0.2, 0.4, 0.6, 0.8)
divided = source / 2.0
inplace = RLPy.RColor(0.2, 0.4, 0.6, 0.8)
inplace /= 2.0
return {
"divided": (divided.R(), divided.G(), divided.B(), divided.A()),
"inplace_divided": (inplace.R(), inplace.G(), inplace.B(), inplace.A()),
Sample code
Calls `RLPy.RColor.A` with the inputs shown in the example.
def run_script():
import RLPy
color1 = RLPy.RColor(0,0,1,1)
print( color1.A() ) # 1
Use HSBC to adjust this color. H stands for hue, S stands for saturation, B for brightness, and C for contrast. The HSBC values range from 0 to 1. If the invert option is true, then the output RGB color will be inverted (1-R, 1-G, 1-B), otherwise known as complementary color. See Also: B
Parameters
- fHue
- fSaturate
- fBrightness
- fContrast
- bInvert
Sample code
Calls `RLPy.RColor.AdjustHSBC` with the inputs shown in the example.
def run_script():
import RLPy
color1 = RLPy.RColor()
color1.AdjustHSBC(0.5, 0.5, 0.5, 0.5, False)
Use RGBA (red, Green, Blue, alpha) to adjust this color. The RGBA values range from 0 to 1. When the invert option is true, then the output RGB color will be inverted (1-R, 1-G, 1-B), otherwise known as complementary color.
Parameters
- fRed
- fGreen
- fBlue
- fAlpha
- bInvert
Sample code
Calls `RLPy.RColor.AdjustRGBA` with the inputs shown in the example.
def run_script():
import RLPy
color1.AdjustRGBA(0.5, 0.5, 0.5, 1.0, False)
Alpha (self)
Get the alpha value of this color (0-255). See Also: A
Sample code
Calls `RLPy.RColor.Alpha` with the inputs shown in the example.
def run_script():
import RLPy
print( color1.Alpha() ) # 255
B (self, *args)
Get the blue value of this color (0-1). See Also: Blue
Parameters
- args
Sample code
import RLPy
def run_script():
inplace /= 2.0
return {
Sample code
Calls `RLPy.RColor.FromCOLORREF` with the inputs shown in the example.
def run_script():
import RLPy
color1.FromCOLORREF(0x0000ff)
print((color1.R(), color1.G(), color1.B())) # (1.0, 0.0, 0.0)
Sample code
Calls `RLPy.RColor.B` with the inputs shown in the example.
def run_script():
import RLPy
print( color1.B() ) # 1
Blue (self)
Get the blue value of this color (0-255). See Also: B
Sample code
Calls `RLPy.RColor.Blue` with the inputs shown in the example.
def run_script():
import RLPy
print( color1.Blue() ) # 255
Adjust color using 32 bit (0-255).
Parameters
- r
- g
- b
- a
Sample code
Calls `RLPy.RColor.From` with the inputs shown in the example.
def run_script():
import RLPy
color1.From(255,0,0,255)
Adjust color using ARGB (0xaarrggbb).
Parameters
- arg2
Sample code
Calls `RLPy.RColor.FromARGB` with the inputs shown in the example.
def run_script():
import RLPy
color = color1.FromARGB(0xff0000ff)
print((color.R(), color.G(), color.B(), color.A()))
Adjust color using COLORREF (0xbbggrr).
Parameters
- arg2
Sample code
def run_script():
import RLPy
Adjust color using HSL (Hue, Saturation, Lightness).
Parameters
- fHue
- fSaturate
- fLevel
Sample code
Calls `RLPy.RColor.FromHSL` with the inputs shown in the example.
def run_script():
import RLPy
color1.FromHSL(0.5,0.5,0.5)
G (self, *args)
Get the green value of this color (0-1). See Also: Green
Parameters
- args
Sample code
import RLPy
def run_script():
inplace /= 2.0
return {
Sample code
def run_script():
import RLPy
Sample code
Calls `RLPy.RColor.G` with the inputs shown in the example.
def run_script():
import RLPy
color1 = RLPy.RColor(0,1,0,1)
print( color1.G() ) # 1
Output this color with gamma correction.
Parameters
- fGamma
Sample code
Calls `RLPy.RColor.GammaCorrect` with the inputs shown in the example.
def run_script():
import RLPy
color1 = RLPy.RColor(0.5, 0, 0, 1)
corrected = color1.GammaCorrect(1.0 / 2.2)
print((corrected.R(), corrected.G(), corrected.B(), corrected.A()))
# (0.7297400236, 0.0, 0.0, 1.0)
Green (self)
Get the green value of this color (0-255). See Also: G
Sample code
Calls `RLPy.RColor.Green` with the inputs shown in the example.
def run_script():
import RLPy
print( color1.Green() ) # 1
Normalize (self)
Normalize RGB values so that their sum equals 1.
Sample code
Calls `RLPy.RColor.Normalize` with the inputs shown in the example.
def run_script():
import RLPy
color1 = RLPy.RColor(0, 1, 0, 1)
normalized = color1.Normalize()
print((normalized.R(), normalized.G(), normalized.B(), normalized.A()))
# (0.0, 0.707106769..., 0.0, 0.707106769...)
R (self, *args)
Get the red value of this color (0-1). See Also: Red
Parameters
- args
Sample code
import RLPy
def run_script():
inplace /= 2.0
return {
Sample code
Calls `RLPy.RColor.R` with the inputs shown in the example.
def run_script():
import RLPy
color1 = RLPy.RColor(1,0,0,1)
print( color1.R() ) # 1
Sample code
def run_script():
import RLPy
Red (self)
Get the red value of this color (0-255). See Also: R
Sample code
Calls `RLPy.RColor.Red` with the inputs shown in the example.
def run_script():
import RLPy
print( color1.Red() ) # 255
Saturate (self)
Clamp the RGB values to a range of 0 and 1. Values under 0 will become 0, and values over 1 will become 1.
Sample code
Calls `RLPy.RColor.Saturate` with the inputs shown in the example.
def run_script():
import RLPy
color1 = RLPy.RColor(1.2,-0.3,0.5, 1.0)
color1.Saturate() # (1, 0, 0.5, 1.0)
ToARGB (self)
Output ARGB data from this color (0xaarrggbb). See Also: FromARGB
Sample code
Calls `RLPy.RColor.ToARGB` with the inputs shown in the example.
def run_script():
import RLPy
color1 = RLPy.RColor(0, 0, 1, 1)
print(hex(int(color1.ToARGB()))) # 0xff0000ff
ToCOLORREF (self)
Output COLORREF data from this color (0xbbggrr). See Also: FromCOLORREF
Sample code
Calls `RLPy.RColor.ToCOLORREF` with the inputs shown in the example.
def run_script():
import RLPy
print( int(color1.ToCOLORREF()) ) # 0xff0000
ToGrayScale (self)
Output grayscale data from this color (0-1).
Sample code
Calls `RLPy.RColor.ToGrayScale` with the inputs shown in the example.
def run_script():
import RLPy
print( color1.ToGrayScale() ) # 0.11400000005960464
Converts the rgba data to HSL data.
Parameters
- fHue
- fSaturate
- fLevel
Adds another value to this value and returns the result.
Parameters
- arg2
__eq__ (self, arg2)
Reports whether this value equals another value.
Parameters
- arg2
Adds another value to this value in place.
Parameters
- arg2
Multiplies this value by another value in place.
Parameters
- args
Subtracts another value from this value in place.
Parameters
- arg2
Divides this value by another value in place.
Parameters
- args
Sample code
import RLPy
def run_script():
inplace /= 2.0
return {
__lt__ (self, arg2)
Reports whether this value is less than another value.
Parameters
- arg2
Multiplies this value by another value and returns the result.
Parameters
- args
__ne__ (self, arg2)
Reports whether this value differs from another value.
Parameters
- arg2
__neg__ (self)
Returns the negated value.
Subtracts another value from this value and returns the result.
Parameters
- arg2
Divides this value by another value and returns the result.
Parameters
- args
Sample code
import RLPy
def run_script():
inplace /= 2.0
return {
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
