IC8 Python API:RLPy RControl
From Reallusion Wiki!
Jump to: navigation, search
Contents
Main article: iC8 Modules.
Last modified: 10/21/2026
Description
Controllers are used to manage animations and create animation effects, which will give a key value when fed a time. This is the base class for all controller related classes which are distinguished according to different data types that they record and deal with: RTransformControl dealing with transform data types and RFloatControl for float data types. Controllers mainly use key-frames to record animations and create keys; and has the ability to interpolate values between keys.
Use GetKeyCount, GetKeyIndex, GetKeyTimeAt, and MaxControlTime to retrieve key data within controllers. Use AddKey, ClearKeys, MoveKey, RemoveKey, and RemoveKeyAt to delete or change key data. Additional functions are available for managing key transition data.
Class Methods
RLPy.RControl.AddKey(self, pKey)
Add one key.
Parameters
pKey[IN] The key to be added - RLPy.RKey
fFps[IN] Frame per second.
Returns
RLPy.RStatus.Success - Succeed
RLPy.RStatus.Failure - Fail
1 control = avatar.GetControl("Transform")
2 key = RLPy.RTransformKey()
3 key.SetTime(RLPy.RTime(0))
4 key.SetTransform(RLPy.RTransform.IDENTITY)
5 control.AddKey(key, RLPy.RGlobal.GetFps())
RLPy.RControl.ClearKeys(self)
Clear (remove) all keys.
Returns
1 # clear keys
2 control = avatar.GetControl("Transform")
3 control.ClearKeys()
4 print(control.HasKeys())        # False
RLPy.RControl.Clone(self)
Clone the control.
Supports cloning, which creates a new instance of a class with the same value as an existing instance.
Returns
Pointer to RControl - RLPy. RControl
1 # clone control
3 cloned_control = control.Clone()
RLPy.RControl.GetDataBlock(self)
Get data block from the control.
Returns
Pointer to data block of the control - RLPy.RDataBlock
1 # get datablock
3 datablock = control.GetDataBlock()
RLPy.RControl.GetKeyCount(self)
Get the number of keys of the control.
Returns
The number of keys of the control - int
1 # get key count
3 key_count = control.GetKeyCount();
RLPy.RControl.GetKeyIndex(self, kTick, nIdx)
Get key index by time.
Parameters
kTime[IN] Specifies the time to get key index.
nIdx[OUT] Index of the key - int
Returns
1 # get key count
3 key_index = -1
4 ret_list = control.GetKeyIndex(RLPy.RTime(1000), key_index)
5 key_index = ret_list[1]
6 print(key_index)
RLPy.RControl.GetKeyTimeAt(self, uIndex, kTick)
Get key's time by index.
Parameters
uIndex[IN] Index of the key. (starting from zero) - int
kTime[OUT] Time of the key specified by uIndex.
Returns
1 # get key time
3 time = RLPy.RTime()
4 control.GetKeyTimeAt(1, time)
5 print(time.GetValue())
RLPy.RControl.HasKeys(self)
Check whether the control has key.
Returns
trueControl has at least one key. falseControl has no key.
1 # get transition strength
3 has_key = control.HasKeys();
RLPy.RControl.MaxControlTime(self)
Get maximum time of the control.
Returns
The maximum time of the control - RLPy.RLTime
1 # get last key time
3 key_time = control.MaxControlTime();
RLPy.RControl.MoveKey(self, kTick, kOffsetTick)
Move one key by an offset time.
If there is a key in target time (kTime + kOffstTime) already, it will be replaced by the key in source time (kTime).
Parameters
kTime[IN] Specifies the time to move key.
kOffsetTime[IN] The offset time.
Returns
1 # move key
3
4 control.MoveKey(RLPy.RTime(0), RLPy.RTime(100))
5 control.GetKeyAt(0, key1)
6 print(key1.GetTime().GetValue())    #100
RLPy.RControl.RemoveKey(self, kTick)
Remove one key from the control by time.
Parameters
kTime[IN] Specifies the time to remove key.
Returns
1 # remove key
3 control.RemoveKey(RLPy.RTime(100))
4 print(control.GetKeyCount())
RLPy.RControl.RemoveKeyAt(self, nIndex)
Remove one key by index.
Parameters
nIndex[IN] Index of the key. (starting from zero) - int
Returns
1 # remove key
RLPy.RControl.SetKeyTransition(self, kTick, eType, fStrength)
Set transition type and strength of the key.
Parameters
kTime[IN] Specifies the time to set transition type.
eType[IN] Transition type of the key - RLPy.ETransitionType
  • RLPy.ETransitionType_Invalid Invalid value.
  • RLPy.ETransitionType_None None.
  • RLPy.ETransitionType_Linear Linear.
  • RLPy.ETransitionType_Step Step.
  • RLPy.ETransitionType_Ease_Out Ease out.
  • RLPy.ETransitionType_Ease_In Ease in.
  • RLPy.ETransitionType_Ease_Out_In Ease out in.
  • RLPy.ETransitionType_Ease_In_Out Ease in out.
  • RLPy.ETransitionType_Ease_In_Sine Ease in sine.
  • RLPy.ETransitionType_Ease_Out_Sine Ease out sine.
  • RLPy.ETransitionType_Ease_In_Out_Sine Ease in out sine.
  • RLPy.ETransitionType_Ease_In_Quad Ease in quad.
  • RLPy.ETransitionType_Ease_Out_Quad Ease out quad.
  • RLPy.ETransitionType_Ease_In_Out_Quad Ease in out quad.
  • RLPy.ETransitionType_Ease_In_Cubic Ease in cubic.
  • RLPy.ETransitionType_Ease_Out_Cubic Ease in out cubic.
  • RLPy.ETransitionType_Ease_In_Out_Cubic Ease in out cubic.
  • RLPy.ETransitionType_Ease_In_Quart Ease in quart.
  • RLPy.ETransitionType_Ease_Out_Quart Ease out quart.
  • RLPy.ETransitionType_Ease_In_Out_Quart Ease in out quart.
  • RLPy.ETransitionType_Ease_In_Quint Ease in quint.
  • RLPy.ETransitionType_Ease_Out_Quint Ease out quint.
  • RLPy.ETransitionType_Ease_In_Out_Quint Ease in out quint.
  • RLPy.ETransitionType_Ease_In_Expo Ease in expo.
  • RLPy.ETransitionType_Ease_Out_Expo Ease out expo.
  • RLPy.ETransitionType_Ease_In_Out_Expo Ease in out expo.
  • RLPy.ETransitionType_Ease_In_Circ Ease in circ.
  • RLPy.ETransitionType_Ease_Out_Circ Ease out circ.
  • RLPy.ETransitionType_Ease_In_Out_Circ Ease in out circ.
  • RLPy.ETransitionType_Ease_In_Back Ease in back.
  • RLPy.ETransitionType_Ease_Out_Back Ease out back.
  • RLPy.ETransitionType_Ease_In_Out_Back Ease in out back.
  • RLPy.ETransitionType_Ease_In_Elastic Ease in elastic.
  • RLPy.ETransitionType_Ease_Out_Elastic Ease out elastic.
  • RLPy.ETransitionType_Ease_In_Out_Elastic Ease in out elastic.
  • RLPy.ETransitionType_Ease_In_Bounce Ease in bounce.
  • RLPy.ETransitionType_Ease_Out_Bounce Ease out bounce.
  • RLPy.ETransitionType_Ease_In_Out_Bounce Ease in out bounce.
  • RLPy.ETransitionType_Last Last.
  • RLPy.ETransitionType_Count
fStrength[IN] Transition strength of the key. The strength range is from 0 to 100, 50 is default value - float
Returns
1 # set transition
3 control.SetKeyTransition(RLPy.RTime(1000), RLPy.ETransitionType_Step, 1.0)
Description
Controllers are used to manage animations and create animation effects, which will give a key value when fed a time. This is the base class for all controller related classes which are distinguished according to different data types that they record and deal with: RTransformControl dealing with transform data types and RFloatControl for float data types. Controllers mainly use key-frames to record animations and create keys; and has the ability to interpolate values between keys. Use GetKeyCount, GetKeyIndex, GetKeyTimeAt, and MaxControlTime to retrieve key data within controllers. Use AddKey, ClearKeys, MoveKey, RemoveKey, and RemoveKeyAt to delete or change key data. Additional functions are available for managing key transition data.
Constructor & Destructor
__init__ (self, *args, **kwargs)
Initializes a new control instance.
Parameters
  • args
  • kwargs
Member Functions
AddKey (self, pKey)
Create a new key data at the designated time. If a key already exists at the given time, then it is replaced. See Also: ClearKeys, RemoveKey, RemoveKeyAt
Parameters
  • pKey
ClearKeys (self)
Remove all keys on this controller. See Also: RemoveKey, RemoveKeyAt, AddKey
Clone (self)
Copy this controller and return a duplicate.
GetDataBlock (self)
Get the data block on this controller.
GetKeyCount (self)
Get the total number of keys in this controller. To check for existence of a key use Haskey() instead. See Also: HasKeys
GetKeyIndex (self, kTick, nIdx)
Get the key index at a given time (starting from 0). If the controller does not contain key data or the corresponding key is not found then return RStatus.Failure. See Also: GetKeyTimeAt
Parameters
  • kTick
  • nIdx
GetKeyTimeAt (self, uIndex, kTick)
Get the key time at a given key index. See Also: GetKeyIndex
Parameters
  • uIndex
  • kTick
GetKeyTransitionStrength (self, *args)
Get the transition strength on this controller at a given time. See Also: GetKeyTransitionStrength, RKey.SetTransitionStrength()
Parameters
  • args
GetKeyTransitionType (self, *args)
Get the transition type on this controller at a given time. See Also: SetKeyTransition, RKey.GetTransitionType()
Parameters
  • args
HasKeys (self)
Check if this controller has a key. See Also: GetKeyCount
LoadDataBlockData (self, rkStream, pkLink, pProgress)
Loads data block data.
Parameters
  • rkStream
  • pkLink
  • pProgress
MaxControlTime (self)
Get this controller's final key time. If a key does not exist then return 0.
MoveAllKey (self, kTick)
Moves all key.
Parameters
  • kTick
MoveKey (self, kTick, kOffsetTick)
Offset an animation key at a given time by a duration. The offset key will replace any existing key at the new position.
Parameters
  • kTick
  • kOffsetTick
RemoveKey (self, kTick)
Remove an animation key at a given time. See Also: ClearKeys, RemoveKeyAt
Parameters
  • kTick
RemoveKeyAt (self, nIndex)
Remove an animation key by index. See Also: ClearKeys, RemoveKey
Parameters
  • nIndex
RemoveKeys (self, kStartTime, kEndTime, bExcludeBound)
Removes keys for this control.
Parameters
  • kStartTime
  • kEndTime
  • bExcludeBound
SetKeyTransition (self, kTick, eType, fStrength)
Set the transition type and strength of a key at a given time. See Also: GetKeyTransitionType, GetKeyTransitionStrength
Parameters
  • kTick
  • eType
  • fStrength
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
