IC8 Python API:RLPy RDataBlock
From Reallusion Wiki!
Jump to: navigation, search
Description
RDataBlock is used to save and access a collection of parameters. A data block can contain multiple parameter with each having its own ID and corresponding data type. In order to make it easier for developers to organize their own parameters, they can generate a composite (tree) structured data type according to their specific needs. This class is similar in concept to 3ds Max's ParamBlock, Maya's MDataBlock, and Cinema4D's BaseContainer. Each plugin may have it's own custom parameters. For example, Path Control needs the Path Position parameter to indicate the progress of an object along a path. So if Path Position equals zero then the object position is at the start of the path and a value of one means it is at the end of the said path. Of course, a developer can create this variable in a class, but they would have to implement locks reading, saving, etc on their own. Even more troublesome is how to attach the corresponding controls when this variable needs to be animated and how to go about correctly displaying it in the Timeline or Curve Editor. Therefore, it's apparent that these tasks are nearly impossible to implement and that RDataBlock is there to help us solve these problems. One would only need to create the required parameters via this class, and other things will be left to the system to handle. The data types in RDataBlock are mainly divided into element data and composite data. Element data is a single built-in data type with the following available values: *RLPy.EAttribute_Float - Float data. *RLPy.EAttribute_Int - Integer data. Composite data is composed of sub-data and the following attributes can be set for hierarchical parameters: *RLPy.EAttribute_GroupXYZ - Creates a x, y, z float value data. The ID of the child data will be named after the ID of the parent plus x, y, z. For example, when creating an ID called "Reallusion", three sub-parameters "ReallusionX", "ReallusionY", and "ReallusionZ" will be automatically generated. In addition, the attributes of the parameters can be specified during creation, as follows: RLPy.EAttributeFlag_Keyable indicates that the animation parameters can be set, if not set, then the value will be a constant. In order to make the parameters animate-able, you must deploy an animation controller. The system will automatically mount the corresponding control types for different data types. For example, if the parameter is a floating point number (like the Path Position attribute of the Path Control mentioned earlier), RFloatControl is required. During animation, parameter values can be obtained at any time via control interpolation. When RLPy.EAttributeFlag_Keyable is set, RLPy.EAttributeFlag_Storable is set as well. This flag indicates that the parameter can be stored to a file and will be serialized accordingly. When the file is read, the data for the requested IDs will be loaded, if an ID is not found then the data will be ignored. Developers can construct data blocks through the RIPlugin class and use CreateAttriute to create the parameters. For example, CurveRTSControl uses the following code to create all of its necessary parameters: frame|Data created by [[IC_Python_API:RLPy_RDataBlock|RDataBlock]] frame|The CurveRTSControl shown in the Curve Editor. After a DataBlock is created, its data can be inspected inside the Timeline and Curve Editor. GetData can be used to get the data value at a given time. If the data in question is a composite data, then a "/" can be used to link together the parent attribute with its child attributes. For example, the Position/PositionX ID for CurveRTSControl can gather data for the corresponding time. For consistency data blocks uses RVariant to save data. SetData is used to change the value of the data block. If RLPy.EAttributeFlag_Keyable is set, then a key will be set at the requested time. If more control over the key is desired, like getting the number of keys, moving keys, clearing all keys, etc. then use GetControl to retrieve the controller for more operations. There is currently no open interface for creating RDataBlock, nor functions for browsing a data block's existing parameters.These function will be provided in future versions.
Constructor & Destructor
__init__ (self, *args, **kwargs)
Initializes a new data block instance.
Parameters
  • args
  • kwargs
Member Functions
AddAttribute (self, spAttribute)
Adds attribute to data block.
Parameters
  • spAttribute
Clone (self)
Copy this data block and return a new identical object. This function is meant for internal usage and should not be called.
Create (kAttributes)
Generates data block according to the incoming attribute list.
Parameters
  • kAttributes
GetAttributes (self)
Returns the attributes.
GetBlockData (self, strName)
Returns the block data.
Parameters
  • strName
GetControl (self, *args)
Get the control on this data block according to the provided string ID. If the given ID is not found or if the RLPy.EAttributeFlag_Keyable is not set, then None will be returned.
Parameters
  • args
GetData (self, *args)
Get the data block value at the given time. If the ID is not found then return None and pReturnStatus will return RLPy.RStatus.Failure. If RLPy.EAttributeFlag_Keyable is not set, then the data is a constant and the value returned will be fixed and does not change according to the kTime value. This function will return a RVariantand with RLPy.RVariant.GetType() one can retrieve the data type and use a corresponding function to convert it to the correct type.
Parameters
  • args
LoadFromFile (self, strPath)
Loads this data block from the specified file.
Parameters
  • strPath
RemoveAttribute (self, spAttribute)
Removes attribute from data block.
Parameters
  • spAttribute
SaveToFile (self, strPath)
Saves image to file.
Parameters
  • strPath
SetData (self, *args)
Set the data block value at the requested time. If the given ID is not found then return RLPy.RStatus.Failure. If the RLPy.EAttributeFlag_Keyable attribute is not set, then the data is a constant and the key will not be set.
Parameters
  • args
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
