IC8 Python API:RLPy REventHandler
Contents
Description
Inside iClone, events are responsible for communicating various types of status changes. For recieving different types of events, one would need to inherit from the REventCallback base class, and use RegisterCallback to register it. Then, one is able to execute relevant commands for the corresponding events, i.e. refreshing user interfaces, etc. See Also: REventCallback
Constructor & Destructor
__init__ (self)
Initializes a new event handler instance.
Member Functions
RegisterCallback (pCallback)
Register an event callback and return an id which can be used when UnregisterCallback is called. See Also: UnregisterCallback
Parameters
- pCallback
SetListener (pListener)
Sets RIEventListener instance [internal].
Parameters
- pListener
UnregisterCallback (uId)
Unregister a callback event by id. When successful, the EventCallback will be removed and the system will no longer receive the event. If the id can not be found, then return RLPy.RStatus.Failure. See Also: UnregisterCallbacks
Parameters
- uId
UnregisterCallbacks (kIds)
Unregister several callback events at once. If an id in the list can not be found, then return RLPy.RStatus.Failure. See Also: UnregisterCallback
Parameters
- kIds
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
