IC8 Python API:RLPy RExportCommonParameter
From Reallusion Wiki!
Jump to: navigation, search
Description
This class stores settings shared by file export operations.
Constructor & Destructor
__init__ (self)
Initializes a new export common parameter instance.
Properties
bBurnMetadata
Indicates whether metadata is burned into the output.
bFinalRender
Indicates whether export uses final-render settings.
bHighQualityDof
Indicates whether high-quality depth of field is enabled for export.
bLockRatio
Indicates whether the output aspect ratio is locked.
bPanoramaOutput
Indicates whether panoramic output is enabled.
bStereoOutput
Indicates whether stereoscopic output is enabled.
kFps
Frame-rate setting selected for export.
nAntiAliasType
Anti-aliasing type selected for export.
nOutputSizeHeight
Output height in pixels.
nOutputSizeWidth
Output width in pixels.
nPixelAspect
Pixel-aspect setting for the output.
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
