IC8 Python API:RLPy RExportFbxSetting
From Reallusion Wiki!
Jump to: navigation, search
Contents
Description
This class stores FBX export settings, including motion range, texture options, and bind-pose options.
Constructor & Destructor
__init__ (self)
Initializes a new export FBX setting instance.
Member Functions
EnableBakeDiffuseFromSkinColor (self, bEnable)
Enables or disables diffuse baking from skin color.
Parameters
  • bEnable
EnableBakeDiffuseSpecularFromShader (self, bEnable)
Enables or disables diffuse and specular baking from the shader.
Parameters
  • bEnable
EnableBakeSubdivision (self, bEnable)
Enables or disables subdivision baking for FBX export.
Parameters
  • bEnable
EnableBasicBindPose (self, bEnable)
Enables or disables the basic bind pose for FBX export.
Parameters
  • bEnable
EnableExportMotion (self, bEnable)
Enables or disables motion export for FBX.
Parameters
  • bEnable
GetExportLevel (self)
Returns the FBX export detail level.
GetExportMotionFps (self)
Returns the frame rate used for FBX motion export.
GetExportMotionRange (self)
Returns the frame range used for FBX motion export.
GetIncludeMotionPath (self)
Returns the motion path included in FBX export.
GetOption (self)
Returns the primary FBX export option value.
GetOption2 (self)
Returns the value stored in FBX export option slot 2.
GetOption3 (self)
Returns the value stored in FBX export option slot 3.
GetTextureFormat (self)
Returns the texture format configured for FBX export.
GetTextureSize (self)
Returns the texture size configured for FBX export.
GetUnrealBoneStructure (self)
Returns the selected Unreal bone-structure setting.
IsBakeDiffuseFromSkinColorEnabled (self)
Reports whether diffuse baking from skin color is enabled.
IsBakeDiffuseSpecularFromShaderEnabled (self)
Reports whether diffuse and specular baking from the shader is enabled.
IsBakeSubdivisionEnabled (self)
Reports whether subdivision baking is enabled for FBX export.
IsBasicBindPoseEnabled (self)
Reports whether the basic bind pose is included in FBX export.
IsEmbedTimecode (self)
Reports whether timecode is embedded in the FBX export.
IsExportMotionEnabled (self)
Reports whether motion export is enabled for FBX.
SetEmbedTimecode (self, bEmbed)
Sets whether timecode is embedded in the FBX export.
Parameters
  • bEmbed
SetExportLevel (self, nExportLevel)
Sets the FBX export detail level.
Parameters
  • nExportLevel
SetExportMotionFps (self, kFps)
Sets the frame rate used for FBX motion export.
Parameters
  • kFps
SetExportMotionRange (self, kRange)
Sets the frame range used for FBX motion export.
Parameters
  • kRange
SetIncludeMotionPath (self, strPath)
Sets the motion path included in FBX export.
Parameters
  • strPath
SetOption (self, eOptions)
Sets the option.
Parameters
  • eOptions
SetOption2 (self, eOptions)
Sets the value stored in FBX export option slot 2.
Parameters
  • eOptions
SetOption3 (self, eOptions)
Sets the value stored in FBX export option slot 3.
Parameters
  • eOptions
SetTextureFormat (self, eFormat)
Sets the texture format used for FBX export.
Parameters
  • eFormat
SetTextureSize (self, eSize)
Sets the texture size used for FBX export.
Parameters
  • eSize
SetUnrealBoneStructure (self, eUnrealBoneStructure)
Sets the Unreal bone-structure option.
Parameters
  • eUnrealBoneStructure
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
