IC8 Python API:RLPy RFacialSetting
Contents
- 1 Description
- 2 Class Methods
- 2.1 RLPy.RFacialSetting.GetBlend(self)
- 2.2 RLPy.RFacialSetting.GetMode(self)
- 2.3 RLPy.RFacialSetting.GetReplacePart(self, bHead, bLeftEye, bRightEye, kMorph, kCustom, kBone)
- 2.4 RLPy.RFacialSetting.SetBlend(self, bBlend)
- 2.5 RLPy.RFacialSetting.SetMode(self, eMode)
- 2.6 RLPy.RFacialSetting.SetReplacePart(self, bHead, bLeftEye, bRightEye, kMorph, kCustom, kBone)
- 3 Description
- 4 Constructor & Destructor
- 5 Member Functions
- 6 Properties
- Main article: iC8 Modules.
- Last modified: 10/21/2026
Description
This class is used to store the settings of facial motion capture.
Class Methods
Get facial blend status.
Returns
blend status - bool
1 # No example
Get facial animation mode.
Returns
animation mode - RLPy.EFacialAnimationMode
- RLPy.EFacialAnimationMode_CreateNew
- RLPy.EFacialAnimationMode_Replace
- RLPy.EFacialAnimationMode_Blend
1 # No example
If it is true, it means that the expression will be replaced.
1 # No example
Set facial blend status.
Parameters
- bBlend[IN] blend status - bool
1 # No example
Set facial animation mode.
Parameters
- eMode[IN] animation mode - RLPy.EFacialAnimationMode
1 # No example
Set to true if you want to replace expressions.
1 # No example
Description
__init__ (self, *args)
Initializes a new facial setting instance.
Parameters
- args
Member Functions
GetBlend (self)
Gets facial blend status.
GetMode (self)
Gets facial animation mode.
GetReplacePart (self, bHead, bLeftEye, bRightEye, kMorph, kCustom, kBone)
Returns the replace part.
Parameters
- bHead
- bLeftEye
- bRightEye
- kMorph
- kCustom
- kBone
SetBlend (self, bBlend)
Sets facial blend status.
Parameters
- bBlend
SetMode (self, eMode)
Sets facial animation mode.
Parameters
- eMode
SetReplacePart (self, bHead, bLeftEye, bRightEye, kMorph, kCustom, kBone)
Sets the replace part.
Parameters
- bHead
- bLeftEye
- bRightEye
- kMorph
- kCustom
- kBone
Properties
blend
Indicates whether facial animation is blended during import or application.
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
