IC8 Python API:RLPy RFloatKey
Contents
Description
This class is used to store and access float data keys. Float keys are managed by RFloatControl via SetValue and GetValue for setting and getting the key value for the corresponding point in time. See Also: RKey, RFloatControl
Constructor & Destructor
__init__ (self, *args)
Initializes a new float key instance.
Parameters
- args
Member Functions
Clone (self)
Copy the float key data and return as a new float key object.
Sample code
Demonstrates calls to `RLPy.RFloatKey.Clone`, `RLPy.RFloatKey.GetValue`, and `RLPy.RFloatKey.SetValue` using the example's inputs.
import RLPy
def run_script():
key = RLPy.RFloatKey()
key.SetValue(7500.0)
clone = key.Clone()
return (
key.GetValue(),
clone.GetValue(),
type(clone).__name__,
GetValue (self)
Get the float key value. See Also: SetValue
Sample code
import RLPy
def run_script():
clone = key.Clone()
return (
key.GetValue(),
clone.GetValue(),
SetValue (self, fValue)
Set the float key value. See Also: GetValue
Parameters
- fValue
Sample code
import RLPy
def run_script():
clone = key.Clone()
return (
key.GetValue(),
clone.GetValue(),
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
