IC8 Python API:RLPy RFps
From Reallusion Wiki!
Jump to: navigation, search
Contents
Description
This class provides frame-rate utilities for converting seconds, frame indices, frame times, and timecode strings.
Constructor & Destructor
__init__ (self, tFps)
Initializes a new frame-rate helper instance.
Parameters
  • tFps
Member Functions
BaseOneIndexedFrameTime (self, nFrameIndex)
Returns the time value for a one-based frame index.
Parameters
  • nFrameIndex
EqualFrameTime (self, kA, kB)
Reports whether two time values represent the same frame.
Parameters
  • kA
  • kB
FrameTimeFromSecond (self, fSecond)
Converts seconds to the corresponding frame time.
Parameters
  • fSecond
FromTimecodeFormattedString (self, strTimecode)
Parses a timecode string and returns the corresponding time value.
Parameters
  • strTimecode
GetFrameIndex (self, kTime)
Returns the frame index corresponding to the supplied time value.
Parameters
  • kTime
GetFrameTime (self, kTime)
Returns the time value for the supplied frame index.
Parameters
  • kTime
GetNextFrameTime (self, kTime)
Returns the time of the next frame after the supplied time.
Parameters
  • kTime
GetPreviousFrameTime (self, kTime)
Returns the time of the previous frame before the supplied time.
Parameters
  • kTime
Returns the time value for a zero-based frame index.
Parameters
  • nFrameIndex
IsSameFrame (self, kTime1, kTime2)
Reports whether two frame-time values fall on the same frame.
Parameters
  • kTime1
  • kTime2
LessEqualFrameTime (self, kA, kB)
Reports whether one frame time is less than or equal to another.
Parameters
  • kA
  • kB
LessFrameTime (self, kA, kB)
Reports whether one frame time precedes another.
Parameters
  • kA
  • kB
RoundFrameIndex (self, kTime)
Rounds a time value to the nearest frame index.
Parameters
  • kTime
SecondFromFrameTime (self, kTime)
Converts a frame time to seconds.
Parameters
  • kTime
TickPerFrame (self)
Returns the number of time ticks in one frame.
ToDouble (self)
Returns this frame rate as a double-precision number.
ToFloat (self)
Returns this frame rate as a floating-point number.
ToInt (self)
Returns this frame rate as an integer.
ToInt64 (self)
Returns this frame rate as a 64-bit integer.
ToLong (self)
Returns this frame rate as a long integer.
ToTimecodeFormattedString (self, kTime)
Formats a time value as a timecode string.
Parameters
  • kTime
ToUInt32 (self)
Returns this frame rate as an unsigned 32-bit integer.
UpFrameIndex (self, kTime)
Advances a frame index to the next frame.
Parameters
  • kTime
__eq__ (self, kFps)
Reports whether this value equals another value.
Parameters
  • kFps
__ge__ (self, kFps)
Reports whether this value is greater than or equal to another value.
Parameters
  • kFps
__gt__ (self, kFps)
Reports whether this value is greater than another value.
Parameters
  • kFps
__le__ (self, kFps)
Reports whether this value is less than or equal to another value.
Parameters
  • kFps
__lt__ (self, kFps)
Reports whether this value is less than another value.
Parameters
  • kFps
__ne__ (self, kFps)
Reports whether this value differs from another value.
Parameters
  • kFps
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
Constants
ByTick
Fps1
Fps10
Fps100
Fps1000
Fps12
Fps120
Fps1200
Fps125
Fps15
Fps150
Fps1500
Fps16
Fps2
Fps20
Fps200
Fps2000
Fps24
Fps240
Fps25
Fps250
Fps3
Fps30
Fps300
Fps3000
Fps375
Fps4
Fps40
Fps400
Fps48
Fps5
Fps50
Fps500
Fps6
Fps60
Fps600
Fps6000
Fps75
Fps750
Fps8
Fps80
Unknown
