IC8 Python API:RLPy RIAccessory
Contents
- 1 Description
- 2 Class Methods
- 3 Description
- 4 Constructor & Destructor
- 5 Member Functions
- 5.1 ConvertToFaceHair (self, eFaceHairType)
- 5.2 ConvertToHair (self, eHairType)
- 5.3 GetMaterialComponent (self)
- 5.4 GetPhysicsComponent (self)
- 5.5 IsDummy (self)
- 5.6 IsVisible (self, kTime)
- 5.7 SetDummy (self, bIsDummy)
- 5.8 SetPivot (self, kPosition, kOrientation)
- 5.9 SetVisible (self, kTime, bVisible)
- 5.10 TransferSkinWeight (self, strTemplateType)
- 6 Properties
- Main article: iC8 Modules.
- Last modified: 10/21/2026
Description
Represents an accessory object in the scene. It provides controls for visibility and dummy state, pivot placement, skin-weight transfer, access to material and physics components, and conversion to hair or face-hair types.
Class Methods
RLPy.RIAccessory.TransferSkinWeight(self, strTemplateType )
Transfer skin weight.
Returns
- RLPy.RStatus.Success - Succeed
- RLPy.RStatus.Failure - Fail
1 # No example
Description
__init__ (self, *args, **kwargs)
Initializes a new ri accessory instance.
Parameters
- args
- kwargs
Member Functions
Converts to different facehair type.
Parameters
- eFaceHairType
Converts to different hair type.
Parameters
- eHairType
Gets material component of the object.
Gets physics component of the object.
IsDummy (self)
Checks if prop state is dummy.
Checks if prop is visible.
Parameters
- kTime
Sets the prop state whether its dummy or not.
Parameters
- bIsDummy
This function lets you re-position and re-orient the current object's pivot.
Parameters
- kPosition
- kOrientation
( Experimental Function ) Set visible status.
Parameters
- kTime
- bVisible
Parameters
- strTemplateType
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
