IC8 Python API:RLPy RIAvatar
From Reallusion Wiki!
Jump to: navigation, search
Contents
Main article: iC8 Modules.
Last modified: 10/21/2026
Description
This class is the interface to avatars in the scene. It provides methods to access various parts of an avatar such as its name, bones, etc. All methods of this class are implemented by the system.
Class Methods
RLPy.RIAvatar.AutoAdjustFootHeight(self)
Auto adjust foot height.
Returns
RLPy.RStatus.Success - Succeed
RLPy.RStatus.Failure - Fail
1 avatar = RLPy.RScene.FindObject(RLPy.EObjectType_Avatar, "Jade")
2 result = avatar.AutoAdjustFootHeight()
RLPy.RIAvatar.ConvertTo(self, args)
Convert to actor build.
Experimental API
Returns
 3 # Convert to actor build
 4 '''
 5 EConvertCharacterLevel_ActorBuild
 6 EConvertCharacterLevel_LOD1
 7 EConvertCharacterLevel_LOD2
 8 '''
 9 convert_type = RLPy.EConvertCharacterLevel_ActorBuild
10 bakeExpression = False
11 bakeTexture = False
12 '''
13 RLPy.EReduceBonePose__None
14 RLPy.EReduceBonePose_TPose
15 RLPy.EReduceBonePose_Default
16 RLPy.EReduceBonePose_Current
17 RLPy.EReduceBonePose_Custom
18 '''
19 pose = RLPy.EReduceBonePose_Default
20 result = avatar.ConvertTo(convert_type, bakeExpression, bakeTexture, pose)
RLPy.RIAvatar.GetAccessories(self, bAll = True)
Get all accessory of the object.
Experimental API
Returns
List of pointer of RIAccessory - list
1 # No example
RLPy.RIAvatar.GetAvatarParts(self, args)
Get all parts of the avatar.
Experimental API
Parameters
eType[IN] specify the type of avatar part, if eType is EAvatarPartType::None, will return all avatar parts of the avatar - RLPy.EAvatarPartType::None
Returns
List of pointer of RIAvatarPart - list
1 # No example
RLPy.RIAvatar.GetAvatarShapingComponent(self)
Get avatar shaping component of the object.
Experimental API
Returns
Pointer of the RIAvatarShapingComponent object - RLPy.RIAvatarShapingComponent
1 # No example
RLPy.RIAvatar.GetAvatarType(self)
Get the current avatar type.
Experimental API
Returns
Avatar Type - RLPy.EAvatarType
  • RLPy.EAvatarType_None
  • RLPy.EAvatarType_Standard
  • RLPy.EAvatarType_NonStandard
  • RLPy.EAvatarType_NonHuman
  • RLPy.EAvatarType_StandardSeries
  • RLPy.EAvatarType_All
2 avatr_type = avatar.GetAvatarType()
3 print(avatar_generation == RLPy.EAvatarType_StandardSeries)
RLPy.RIAvatar.GetClothes(self)
Get all cloth of the object.
Experimental API
Returns
List of pointer of RICloth - list
1 # No example
RLPy.RIAvatar.GetFaceComponent(self)
Get face component of the object.
Experimental API
Returns
Pointer of the RIFaceComponent object - RLPy.RIFaceComponent
1 # No example
RLPy.RIAvatar.GetFacialProfileComponent(self)
Experimental API
Returns
Pointer of the RIFaceComponent object - RLPy.RIFacialProfileComponent
1 # No example
RLPy.RIAvatar.GetFloorContactValue(self, eType)
Get the value of the floor contact.
Experimental API
Parameters
eType[IN] specify the type of floor contect - RLPy.EFloorContactType
  • RLPy.EFloorContactType_HandBottom
  • RLPy.EFloorContactType_HandBack
  • RLPy.EFloorContactType_HandMiddle
  • RLPy.EFloorContactType_HandFront
  • RLPy.EFloorContactType_HandIn
  • RLPy.EFloorContactType_HandOut
  • RLPy.EFloorContactType_FootBottom
  • RLPy.EFloorContactType_FootBack
  • RLPy.EFloorContactType_FootMiddle
  • RLPy.EFloorContactType_FootFront
  • RLPy.EFloorContactType_FootIn
  • RLPy.EFloorContactType_FootOut
  • RLPy.EFloorContactType_All
Returns
The value of the floor contact - float
1 # No example
RLPy.RIAvatar.GetGeneration(self)
Get CharacterCreator avatar generation.
Experimental API
Returns
CharacterCreator Avatar generation - RLPy.EAvatarGeneration
  • RLPy.EAvatarGeneration_None
  • RLPy.EAvatarGeneration_CC_G1_Avatar
  • RLPy.EAvatarGeneration_CC_G3_Avatar
  • RLPy.EAvatarGeneration_CC_G3_Plus_Avatar
  • RLPy.EAvatarGeneration_CC_Game_Base_One
  • RLPy.EAvatarGeneration_CC_Game_Base_Multi
  • RLPy.EAvatarGeneration_ActorBuild
  • RLPy.EAvatarGeneration_ActorScan
2 avatar_generation = avatar.GetGeneration()
3 print(avatar_generation)
RLPy.RIAvatar.GetHairs(self)
Get all hair of the object.
Experimental API
Returns
List of pointer of RIHair - list
1 # No example
RLPy.RIAvatar.GetHikEffectorComponent(self)
Get human IK effector component of the object.
Returns
Pointer of the RIHikEffectorComponent object - RLPy.RIHikEffectorComponent
1 # No example
RLPy.RIAvatar.GetMaterialComponent(self)
Get material component of the object.
Returns
Pointer of the RIMaterialComponent object - RLPy.RIMaterialComponent
1 # No example
RLPy.RIAvatar.GetMorphComponent(self)
Get morph component of the object.
Returns
Pointer of the RIMorphComponent object - RLPy.RIMorphComponent
1 # No example
RLPy.RIAvatar.GetPhysicsComponent(self)
Get physics component of the object.
Returns
Pointer of the RIPhysicsComponentPtr object - RLPy.RIPhysicsComponent
1 # No example
RLPy.RIAvatar.GetSkeletonComponent(self)
Get bone component of the object.
Returns
Pointer of the RISkeletonComponent object - RLPy.RISkeletonComponent
1 # No example
RLPy.RIAvatar.GetVisemeComponent(self)
Get viseme component of the object.
Returns
Pointer of the RIVisemeComponent object - RLPy.RIVisemeComponent
1 # No example
RLPy.RIAvatar.IsVisible(self, kTime)
Check if avatar is visible.
Experimental API
Parameters
kTime[IN] Specifies the time to check if avatar is visible - RLPy.RLTime
Returns
Boolvalue true if avatar is visible; otherwise false.
2 isVisible = avatar.IsVisible(RLPy.RTime(600))
3 print(isVisible)
RLPy.RIAvatar.LoadAccessoryWithTransferSkinWeight(self, kFilePath, kTemplateType)
Load accessory and transfer skin weight automatically.
Experimental API
Parameters
kFilePath[IN] File path of accessory - string
kTemplateType[IN] Template type of transfer skin weight - string
Returns
3 # Load Accessory With Transfer Skin Weight
4 input_file_path = r"C:\test\T-shirt_TPose.obj"
5 type_of_input_clothe = "Default"
6 result = avatar.LoadAccessoryWithTransferSkinWeight( input_file_path, type_of_input_clothe )
7 if result == RLPy.RStatus.Success :
8     print("Success")
RLPy.RIAvatar.LoadHikProfile(self, strPath, bApplyTpose, bApplyBoneMapping, bSendUpdateEvent)
Load humanoid ik profile from path, may cause character turn to nonstandard.
Experimental API
Returns
2 save_hik_path = "./test_hik_profile.3dxProfile"
3 result = avatar.LoadHikProfile(save_hik_path)
RLPy.RIAvatar.SaveHikProfile(self, strPath)
Save humanoid ik profile to path.
Experimental API
Returns
2 # Save humanoid ik profile
3 save_hik_path = "./test_hik_profile.3dxProfile"
4 result = avatar.SaveHikProfile(save_hik_path)
RLPy.RIAvatar.SetFloorContactValue(self, eType, fValue)
Set the value of the floor contact.
Experimental API
Parameters
fValue[IN] the value of floor contect - float
Returns
1 # No example
RLPy.RIAvatar.SetVisible(self, kTime, bVisible)
Experimental Function)Set visible status
Parameters
kTime[IN] Specifies the time to set visible - RLPy.RLTime
bVisible[IN] Visible status - bool
Returns
2 # set visible key
3 avatar.SetVisible(RLPy.RTime(600), False)
Description
This class provides methods to access all components of a character, for example: RISkeletonComponent, RIVisemeComponent, RIFaceComponent, etc. Retrieved component operations are thus available for usage.
Constructor & Destructor
__init__ (self, *args, **kwargs)
Initializes a new avatar instance.
Parameters
  • args
  • kwargs
Member Functions
AutoAdjustFootHeight (self)
ChangeConstraintSet (self)
Change Facial Constraint Set (CC4 Extend to CCExtend+).
ConvertTo (self, *args)
Converts to actor build.
Parameters
  • args
DoCharacterization (self, strPath, bApplyTpose, bApplyBoneMapping, bSendUpdateEvent)
Runs characterization for this avatar.
Parameters
  • strPath
  • bApplyTpose
  • bApplyBoneMapping
  • bSendUpdateEvent
GetAccessories (self, bAll=True)
Returns the accessories.
Parameters
  • bAll (default: True)
GetAvatarParts (self, *args)
Gets all parts of the avatar.
Parameters
  • args
GetAvatarShapingComponent (self)
Gets avatar shaping component of the object.
GetAvatarType (self)
Get the character's avatar type.
GetClothes (self)
Returns the clothes.
GetFaceComponent (self)
Get the Face Component for the character. Face Component is used to control the facial and head settings for the character. See Also: RIFaceComponent
GetFacialProfileComponent (self)
Gets face component of the object.
GetFloorContactValue (self, eType)
Gets the value of the floor contact.
Parameters
  • eType
GetGeneration (self)
Get the CC avatar standard generation for the character.
GetHairs (self)
Returns the hairs.
GetHikEffectorComponent (self)
Get the character's HIK Effector Component, used for controlling and managing the IK skeleton. See Also: RIHikEffectorComponent
GetMaterialComponent (self)
Get the character's Material Component, used for setting material related parameter values. See Also: RIMaterialComponent
GetMaxSubdivMeshLevel (self)
Gets maximum value of the subdiv level.
GetMorphComponent (self)
Get the character's Morph Component, used to edit Morph Animation Keys or retrieve the current morph weighting. See Also: RIMorphComponent
GetMorpherConstraintsEnabled (self)
Checks if morpher constraint enabled, doesn't mean it has data.
GetPhysicsComponent (self)
Gets physics component of the object.
GetRenderSubdivMeshLevel (self)
Gets subdiv level used by render mesh.
GetSkeletonComponent (self)
Get the character's Skeleton Component, used for retrieving the entire skeleton. See Also: RISkeletonComponent
GetSubdivMeshLevel (self)
Gets subdiv level of avatar mesh.
GetVisemeComponent (self)
Get the character's Viseme Component, which provides operations related to lip-syncing. See Also: RIVisemeComponent
HasMorpherConstraintsSet (self)
Checks if avatar has morpher constraint data.
IsVisible (self, kTime)
Checks if avatar is visible.
Parameters
  • kTime
LoadAccessoryWithTransferSkinWeight (self, kFilePath, kTemplateType)
Loads accessory and transfer skin weight automatically.
Parameters
  • kFilePath
  • kTemplateType
ReplaceMesh (self, strMeshName, strObjFilePath, bSplitObjects=False, bAutoRig=False)
Replaces mesh by loading obj file.
Parameters
  • strMeshName
  • strObjFilePath
  • bSplitObjects (default: False)
  • bAutoRig (default: False)
SaveHikProfile (self, strPath)
Saves humanoid ik profile to path.
Parameters
  • strPath
SetFloorContactValue (self, eType, fValue)
Sets the value of the floor contact.
Parameters
  • eType
  • fValue
SetMorpherConstraintsEnabled (self, bEnabled)
Enable or disable morpher constraint, currently only for facial morphers, when enabled, the morph value will be clamped by the constraint profile, which is set in Character Creator, and the constraint profile will be automatically applied to the avatar when importing to iClone, user can also manually change the constraint profile in iClone if needed, when disabled, there is no constraint on morph value. This function is for user to preview the effect of morpher constraint in Character Creator.
Parameters
  • bEnabled
SetRenderSubdivMeshLevel (self, nLevel)
Sets subdiv level used by render mesh.
Parameters
  • nLevel
SetVisible (self, kTime, bVisible)
Set a visibility key by a given time.
Parameters
  • kTime
  • bVisible
SwitchSubdivMeshLevel (self, nLevel)
Switch subdiv level of avatar mesh.
Parameters
  • nLevel
UpdateWrinkle (self)
Refresh Wrinkle Textures.
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
