IC8 Python API:RLPy RICamera
Contents
- 1 Description
- 2 Class Methods
- 2.1 RLPy.RICamera.AddDofKey(self, kKey, kDofData)
- 2.2 RLPy.RICamera.GetAngleOfView(self, kTime)
- 2.3 RLPy.RICamera.GetAperture(self, fWidth, fHeight)
- 2.4 RLPy.RICamera.GetDOFData(self)
- 2.5 RLPy.RICamera.GetDofKeyCount(self)
- 2.6 RLPy.RICamera.GetFarClippingPlane(self)
- 2.7 RLPy.RICamera.GetFitFovType(self)
- 2.8 RLPy.RICamera.GetFitRenderRegionType(self)
- 2.9 RLPy.RICamera.GetFocalLength(self, kTime)
- 2.10 RLPy.RICamera.GetFocalLengthKeyCount(self)
- 2.11 RLPy.RICamera.GetNearClippingPlane(self)
- 2.12 RLPy.RICamera.IsLookAtMode(self, kTime)
- 2.13 RLPy.RICamera.RemoveDofKey(self, kKey)
- 2.14 RLPy.RICamera.RemoveDofKeys(self)
- 2.15 RLPy.RICamera.RemoveFocalLengthKey(self, kTime)
- 2.16 RLPy.RICamera.RemoveFocalLengthKeys(self)
- 2.17 RLPy.RICamera.SetFarClippingPlane(self, nFarPlane)
- 2.18 RLPy.RICamera.SetFocalLength(self, kTime, fFocalLength)
- 2.19 RLPy.RICamera.SetNearClippingPlane(self, nNearPlane)
- 3 Description
- 4 Constructor & Destructor
- 5 Member Functions
- 5.1 AddDofKey (self, kKey, kDofData)
- 5.2 GetAngleOfView (self, kTime)
- 5.3 GetAperture (self, fWidth, fHeight)
- 5.4 GetDOFData (self)
- 5.5 GetDofKeyCount (self)
- 5.6 GetFarClippingPlane (self)
- 5.7 GetFarClippingPlaneF (self)
- 5.8 GetFitFovType (self)
- 5.9 GetFitRenderRegionType (self)
- 5.10 GetFocalLength (self, kTime)
- 5.11 GetFocalLengthKeyCount (self)
- 5.12 GetNearClippingPlane (self)
- 5.13 GetNearClippingPlaneF (self)
- 5.14 GetProjectMode (self)
- 5.15 IsLookAtMode (self, kTime)
- 5.16 RemoveDofKey (self, kKey)
- 5.17 RemoveDofKeys (self)
- 5.18 RemoveFocalLengthKey (self, kTime)
- 5.19 RemoveFocalLengthKeys (self)
- 5.20 SetCameraLocation (self, eType)
- 5.21 SetFarClippingPlane (self, nFarPlane)
- 5.22 SetFarClippingPlaneF (self, fFarPlane)
- 5.23 SetFocalLength (self, kTime, fFocalLength)
- 5.24 SetNearClippingPlane (self, nNearPlane)
- 5.25 SetNearClippingPlaneF (self, fNearPlane)
- 5.26 SetProjectMode (self, bPerspective)
- 5.27 SetWorldView (self, vWorldPosition, vWorldView, vWorldUp)
- 6 Properties
- Main article: iC8 Modules.
- Last modified: 10/21/2026
Description
This class is the interface to cameras in the scene. It provides methods to access various parts of a camera such as FOV, transformation, etc. All methods of this class are implemented by the system.
Class Methods
Add a depth of field key in camera.
Experimental API
Parameters
- kKey[IN] The key for time and transition control, now only supports linear - RLPy.RKey
- kDofData[IN] The dof setting for key - RLPy.RCameraDofData
Returns
- RLPy.RStatus.Success - Succeed
- RLPy.RStatus.Failure - Fail
1 camera = RLPy.RScene.FindObject(RLPy.EObjectType_Camera, "Camera")
3 #add dof key
4 new_data = RLPy.RCameraDofData()
5 new_data.SetEnable( True )
6 new_data.SetFocus(20)
7 data.SetRange(80)
8 dof_key = RLPy.RKey()
9 dof_key.SetTime(RLPy.RTime(66))
10 dof_key.SetTransitionType(RLPy.ETransitionType_Linear)
11 dof_key.SetTransitionStrength(50)
12 camera.AddDofKey(dof_key, new_data)
Get the angle view of the camera.
Experimental API
Returns
the angle view value of the camera - float
Parameters
- kTime[IN] the time to get - RLPy.RLTime
2 #get camera angle of view
3 print(camera.GetAngleOfView(RLPy.RGlobal.GetTime()))
Get aperture data of the camera.
Experimental API
Parameters
- fWidth[IN] the Width to get - float
- fHeight[IN] the Height to get - float
Returns
3 #get camera aperture
4 width = 0
5 height = 0
6 result = camera.GetAperture(width,height)
7 print(result[0])
8 print(result[1])
9 print(result[2])
Get depth of field data of the camera.
Experimental API
Returns
Camera DOF data - RLPy.RCameraDofData
3 #get camera DOF data
4 data = camera.GetDOFData()
5 if(data!= None):
6 print(data.GetEnable())
7 print(data.GetFocus())
8 print(data.GetRange())
9 print(data.GetNearTransitionRegion())
10 print(data.GetFarTransitionRegion())
11 print(data.GetNearBlurScale())
12 print(data.GetFarBlurScale())
13 print(data.GetMinBlendDistance())
14 print(data.GetCenterColorWeight())
15 print(data.GetEdgeDecayPower())
Get the number of DOF keys of the control.
Experimental API
Returns
Number of DOF Keys - int
3 #get dof key count
4 dof_key_count = camera.GetDofKeyCount()
5 print(dof_key_count)
Get far clipping plane of the camera.
Experimental API
Returns
the far clipping plane of the camera - int
3 #set and get far clipping plane of the camera
4 camera.SetFarClippingPlane(25)
5 print(camera.GetFarClippingPlane())
Get field of view setting of the camera.
Experimental API
Returns
the type of setting(Horizontal / Vertical)- RLPy.ECameraFitResolution
- RLPy.ECameraFitResolution_None
- RLPy.ECameraFitResolution_Horizontal
- RLPy.ECameraFitResolution_Vertical
3 #get field of view setting of the camera
4 fov_type = camera.GetFitFovType()
5 print(fov_type)
Get fit resolution setting of the camera.
Experimental API
Returns
3 #get fit resolution setting of the camera
4 fov_type = camera.GetFitRenderRegionType()
5 print(fov_type)
Get the focal length of the camera.
Experimental API
Returns
the focal length of the camera - float
Parameters
3 # set and get focal length
4 camera.SetFocalLength(RLPy.RTime(60), 100.0)
5 print(camera.GetFocalLength(RLPy.RTime(60))) # 100
Get the number of Focal Length keys of the control.
Experimental API
Returns
Number of focal length Keys - int
2 print(camera.GetFocalLengthKeyCount())
Get near clipping plane of the camera.
Experimental API
Returns
the near clipping plane of the camera - int
2 print(camera.GetNearClippingPlane())
Check that this camera is in LookAt mode.
Experimental API
Parameters
- kTime[IN] time for check - RLPy.RLTime
Returns
True means that this camera is in Lookat mode at this time, False means not - bool
2 print(camera.IsLookAtMode(RLPy.RGlobal.GetTime()))
Remove a depth of field key in camera.
Experimental API
Parameters
- kKey[IN] Key to remove - RLPy.RKey
Returns
3 #add and remove DOF key
4 dof_key = RLPy.RKey()
5 dof_key.SetTime(RLPy.RTime(66))
6 dof_key.SetTransitionType(RLPy.ETransitionType_Linear)
7 dof_key.SetTransitionStrength(50)
8 camera.AddDofKey(dof_key, new_data)
9 #remove dof key
10 camera.RemoveDofKey(dof_key)
Remove all dof keys of this camera object.
Experimental API
Returns
3 # remove focal length key
4 camera.RemoveFocalLengthKey(RLPy.RTime(60))
5 camera.RemoveFocalLengthKeys()
6 print(camera.GetFocalLengthKeyCount()) # 0
Remove a focal length key in camera.
Experimental API
Parameters
- kKey[IN] time to remove.
Returns
1 # remove focal length key
2 camera.RemoveFocalLengthKey(RLPy.RTime(60))
3 camera.RemoveFocalLengthKeys()
4 print(camera.GetFocalLengthKeyCount()) # 0
Remove all focal length keys of this camera object.
Experimental API
Returns
2 camera.RemoveFocalLengthKeys()
Set far clipping plane of the camera.
Experimental API
Parameters
- nFarPlane[IN] the far clipping plane value to set - int
Returns
2 camera.SetFarClippingPlane(25)
Set the focal length of the camera.
Experimental API
Parameters
- kTime[IN] the time to set - RLPy.RLTime
- fFocalLength[IN] The focal length value to be set - float
Returns
3 # set focal length
Set near clipping plane of the camera.
Experimental API
Parameters
- nNearPlane[IN] the near clipping plane value to set - int
Returns
2 camera.SetNearClippingPlane(50)
Description
This class is used to access camera objects in the scene. A camera can be divided into 3 main parts: the device body, camera lens, and viewing area. Therefore, the interfaces available are: aperture, focal length, angle of view, depth of field, near / far plane settings, and viewport fitting. See Also: RCameraDofData, RScene.
__init__ (self, *args, **kwargs)
Initializes a new ri camera instance.
Parameters
- args
- kwargs
Member Functions
Key the camera's Depth of Field (DOF) at a given time. Use RCameraDofData to adjust the DOF settings.
Parameters
- kKey
- kDofData
Get the camera's Angle of View (AOV) at a given time, in degrees (1° to 165°).
Parameters
- kTime
Get the camera's aperture dimensions, i.e. the width and height of the photo-sensitive capture plate.
Parameters
- fWidth
- fHeight
GetDOFData (self)
Get the camera's Depth of Field (DOF) data.
Gets the number of DOF keys of the control.
Get the camera's Far Clipping Plane distance.
Gets far clipping plane of the camera (float version).
Get the camera's Fit value for the Field of View. The possible values are the following: *RLPy.ECameraFitResolution_Horizontal - use the horizontal width value for fitting. *RLPy.ECameraFitResolution_Vertical - use the vertical height value for fitting.
Get the camera's Fit Resolution setting. The possible values are the following: *RLPy.ECameraFitResolution_Horizontal - use the horizontal width value for fitting. *RLPy.ECameraFitResolution_Vertical - use the vertical height value for fitting.
Get the camera's Focal Length distance at a given time.
Parameters
- kTime
Gets the number of Focal Length keys of the control.
Get the camera's Near Clipping Plane distance.
Gets near clipping plane of the camera (float version).
Gets the projection mode of the camera.
Checks that this camera is in LookAt mode.
Parameters
- kTime
Removes a depth of field key in camera.
Parameters
- kKey
Removes all dof keys of this camera object.
Removes a focal length key in camera.
Parameters
- kTime
Removes all focal length keys of this camera object.
Sets Camera to default location.
Parameters
- eType
Set the Far Clipping Plane distance. This value must be larger than the Near Clipping Plane distance.
Parameters
- nFarPlane
Sets far clipping plane of the camera (float version).
Parameters
- fFarPlane
Set the camera's Focal Length at a given point in time. The possible values lie between 2.5 and 3,500 mm. If the value set lies outside of this range, then the original Focal Length value remains unchanged.
Parameters
- kTime
- fFocalLength
Set the Near Clipping Plane distance, must be smaller than the Far Clipping Plane distance.
Parameters
- nNearPlane
Sets near clipping plane of the camera (float version).
Parameters
- fNearPlane
Sets the projection mode of the camera.
Parameters
- bPerspective
Sets the world-space position, view direction and up direction of the camera.
Parameters
- vWorldPosition
- vWorldView
- vWorldUp
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
