IC8 Python API:RLPy RIDirectionalLight
From Reallusion Wiki!
Jump to: navigation, search
Main article: iC8 Modules.
Last modified: 10/21/2026
Description
This class provides operations for Directional Lights, e.g. whether or not to cast shadows, the light's color, light strength, etc. You must first retrieve a directional light from the scene in order to use these operations.
Class Methods
RLPy.RIDirectionalLight.GetDarkenShadowStrength(self)
Get the light darken shadow strength.
Experimental API
Returns
The value of the "shadow strength" attribute of the light node - float
1 light_object = RLPy.RScene.FindObject(RLPy.EObjectType_Light, "Dir. Light")
3 if light_object:
4   result = light_object.SetDarkenShadowStrength(RLPy.RGlobal.GetTime(), 50)
5   print(light_object.GetDarkenShadowStrength())
RLPy.RIDirectionalLight.GetTransmission(self)
Get if light transmits through SSS (subsurface scattering) material.
Experimental API
Returns
True if light transmits, False if it doesn't - bool
1 # No example
RLPy.RIDirectionalLight.IsCastShadow(self)
Get the light if cast shadow enable.
Experimental API
Returns
True if light is cast shadow enable, False if not - bool
3 if light_object:
4     light_object.SetCastShadow(True)
5     print(light_object.IsCastShadow())
6
7     light_object.SetCastShadow(False)
8     print(light_object.IsCastShadow())
RLPy.RIDirectionalLight.SetCastShadow(self, bEnable)
Set the light's cast shadow is enable.
Experimental API
Parameters
bEnable[in] If light's cast shadow is enable - bool
Returns
RLPy.RStatus.Success - Succeed
RLPy.RStatus.Failure - Fail
3 if light_object:
5     light_object.SetCastShadow(False)
RLPy.RIDirectionalLight.SetDarkenShadowStrength(self, kTime, fStrength)
Set the light's shadow strength.
Experimental API
Parameters
fStrength[in] The Light shadow strength value - float
Returns
3 if light_object:
5   print(result)
RLPy.RIDirectionalLight.SetTransmission(self, b)
Set light to transmit through SSS (subsurfarce scattering) material.
Experimental API
Parameters
b[in] If light transmits through SSS matreial - bool
Returns
1 # No example
Description
Constructor & Destructor
__init__ (self, *args, **kwargs)
Initializes a new ri directional light instance.
Parameters
  • args
  • kwargs
Member Functions
GetDarkenShadowStrength (self)
Get the directional light's shadow strength at a given point in time (0 to 100).
GetTransmission (self)
Returns the transmission.
IsCastShadow (self)
Check whether or not the light is casting shadows.
SetCastShadow (self, bEnable)
Turn on or off the directional light's cast shadow.
Parameters
  • bEnable
SetDarkenShadowStrength (self, kTime, fStrength)
Set the directional light's shadow strength at a given point in time (0 to 100).
Parameters
  • kTime
  • fStrength
SetTransmission (self, b)
Sets the transmission.
Parameters
  • b
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
