IC8 Python API:RLPy RIDockWidget
From Reallusion Wiki!
Jump to: navigation, search
Description
Provides dock widget related functions such as creating dock widgets and dock-able window related properties. It also allows the registration and unregistration of dock widget callback events.
Constructor & Destructor
__init__ (self, *args, **kwargs)
Initializes a new ri dock widget instance.
Parameters
  • args
  • kwargs
Member Functions
Close (self)
Close this dock widget and release it from system memory. See Also: Show, Hide
Features (self)
Get all of the feature flags applied to this dock widget. See also: SetFeatures
GetTitle (self)
Get the QWidget address of this dock widget's title-bar, which can be used to deploy PySide operations.
GetWindow (self)
Get the QWidget address of this dock widget, which can be used to create a PySide representation and later accomodate a Qt ui or qml file.
GetWindowTitle (self)
Get this dock widget's title-bar label text. See Also: SetWindowTitle
Hide (self)
Hide this dock widget, but keep it in system memory. See Also: Show, Close
IsAreaAllowed (self, eArea)
Check if this dock widget can be docked into a certain region of the application. See Also: SetAllowedAreas
Parameters
  • eArea
IsFloating (self)
Check if this dock widget is floating (not docked to the application's main window). See also: SetFloating
IsVisible (self)
Check whether if this dock widget is visible or not. See Also: Show, Hide, Close
RegisterEventCallback (self, pfCallback)
Register a RDialogCallback to this dock widget and return its ID. See Also: UnregisterEventCallback, UnregisterEventCallbacks
Parameters
  • pfCallback
RegisterNativeEventCallback (self, pfCallback)
Register a RWinMessageCallback with this dock widget and returns its ID. See Also: UnregisterNativeEventCallback, UnregisterNativeEventCallbacks
Parameters
  • pfCallback
SetAllowedAreas (self, eArea)
Set the dockable areas for this dock widget. Bit-wise operations can be used to combine and exclude different dock-able areas See Also: IsAreaAllowed
Parameters
  • eArea
SetFeatures (self, eFeatures)
Allow this dock widget to be movable, closable, and floatable. The feature parameter can be treated with bit-wise operations. The available RLPy.EDockWidgetFeatures match those inside PySide2.QtCore.Qt. See Also: Features
Parameters
  • eFeatures
SetFloating (self, bFloating)
Set the floating state of this dock widget. Currently, only a value of True takes effect. See Also: IsFloating
Parameters
  • bFloating
SetParent (self, pWidget)
Set the parent widget for this dock widget according to its window address. Currently, the main window is the only viable option as the parent widget.
Parameters
  • pWidget
SetWidget (self, pWidget)
Insert another widget into this dock widget, by way of its window address, into this dock widget.
Parameters
  • pWidget
SetWindowTitle (self, strTitleName)
Set the label text for this dock widget's title-bar.
Parameters
  • strTitleName
Show (self)
Make this dock widget visible. See Also: Hide, Close
UnregisterAllEventCallbacks (self)
Unregister all RDialogCallback on this dock widget See Also: RegisterEventCallback, UnregisterEventCallback, UnregisterEventCallbacks
UnregisterEventCallback (self, uId)
Unregister a RDialogCallback from this dock widget. See Also: RegisterEventCallback, UnregisterEventCallbacks
Parameters
  • uId
UnregisterEventCallbacks (self, kIds)
Unregister a collection of RDialogCallback from this dock widget. If unregistration of one of the callbacks fails, it will still attempt to unregister the rest. See Also: RegisterEventCallback, UnregisterEventCallback, UnregisterEventCallbacks
Parameters
  • kIds
UnregisterNativeEventCallback (self, uId)
Unregister a RWinMessageCallback from this dock widget. See Also: RegisterNativeEventCallback, UnregisterNativeEventCallbacks
Parameters
  • uId
UnregisterNativeEventCallbacks (self, kIds)
Unregister a collection of RWinMessageCallback from this dock widget. If unregistration of one of the callbacks fails, it will still attempt to unregister the rest. See Also: RegisterNativeEventCallback, UnregisterNativeEventCallback
Parameters
  • kIds
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
