IC8 Python API:RLPy RILight
Contents
- 1 Description
- 2 Class Methods
- 3 Description
- 4 Constructor & Destructor
- 5 Member Functions
- 6 Properties
- Main article: iC8 Modules.
- Last modified: 10/21/2026
Description
This is the base class for all light sources and provides settings for some basic properties, e.g. active states, strength, color values, etc. It also provides a Transform Control with the ability to set translation, rotation, and scale keys.
Class Methods
RLPy.RILight.GetActive(self)
Check if the light is active.
Experimental API
Returns
True if light is active, False if light is not active - bool
1 # Get light object
2 light_object = RLPy.RScene.FindObject(RLPy.EObjectType_Light, "Spotlight")
3
4 # Get light object active status
5 active_status = light_object.GetActive()
6
7 print(active_status)
RLPy.RILight.GetColor(self)
Get the light's color.
Experimental API
Returns
The value of the "color" attribute of the light node - RLPy.RRgb
3
4 # Set light object color value
5 light_color = light_object.GetColor()
6
7 print(light_color)
RLPy.RILight.GetMultiplier(self)
Get the light's multiplier.
Experimental API
Returns
The value of the "multiplier" attribute of the light node - float
3
4 # Get light object multiplier value
5 multiplier_value = light_object.GetMultiplier()
6
7 print(multiplier_value)
RLPy.RILight.SetActive(self, kTime, bActive)
Activate or deactivate the light.
Experimental API
Parameters
- bActive[in] If light is active - bool
Returns
- RLPy.RStatus.Success - Succeed
- RLPy.RStatus.Failure - Fail
3
4 # Set light object active status
5 light_object.SetActive(True)
RLPy.RILight.SetColor(self, kTime, kColor)
Set the light's color.
Experimental API
Parameters
- kTime[in] The time at which to set the color - RLPy.RLTime
- kColor[in] The Light RGB value - RLPy.RRgb
Returns
3
5 result = light_object.SetColor(RLPy.RTime(0), RLPy.RRgb.RED)
RLPy.RILight.SetMultiplier(self, kTime, fMultiplier)
Set the light's multiplier.
Experimental API
Parameters
- kTime[in] The time at which to set the multiplier - RLPy.RLTime
- fMultiplier[in] The Light multiplier value - float
Returns
3
4 # Set light object multiplier value
5 result = light_object.SetMultiplier(RLPy.RTime(0), 8.0)
Description
__init__ (self, *args, **kwargs)
Initializes a new ri light instance.
Parameters
- args
- kwargs
Member Functions
GetActive (self)
Get the active state of the light. See Also: SetActive
GetColor (self)
Get the light's color at a given time. See Also: SetColor
GetMultiplier (self)
Get the light's current strength. See Also: SetMultiplier
SetActive (self, kTime, bActive)
Set the active state for the light. See Also: GetActive
Parameters
- kTime
- bActive
SetColor (self, kTime, kColor)
Set the light's color at a given time. See Also: GetColor
Parameters
- kTime
- kColor
SetMultiplier (self, kTime, fMultiplier)
Set the light's strength value at a given time. See Also: GetMultiplier
Parameters
- kTime
- fMultiplier
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
