IC8 Python API:RLPy RIMaterialComponent
From Reallusion Wiki!
Jump to: navigation, search
Contents
Description
This class is used to manipulate material surface properties. The main material properties are Ambient color, Diffuse color, Specular color, Glossiness value, Self-illumination value, Opacity value, textures, and more. A material is affiliated with an object, therefore, member functions of this class must specify a mesh and material name.
Constructor & Destructor
__init__ (self, *args, **kwargs)
Initializes a new ri material component instance.
Parameters
  • args
  • kwargs
Member Functions
AddAmbientKey (self, kKey, strMeshName, strMaterialName, kColor)
Add an Ambient key for the material according to the time and Transition Type of kKey. See Also: AddDiffuseKey, AddGlossinessKey, AddOpacityKey, AddSelfIlluminationKey, AddSpecularKey, AddTextureWeightKey, AddUvDataKey, AddVideoVolumeKey
Parameters
  • kKey
  • strMeshName
  • strMaterialName
  • kColor
AddDiffuseKey (self, kKey, strMeshName, strMaterialName, kColor)
Add a Diffuse key for the material according to the time and Transition Type of kKey. See Also: AddAmbientKey, AddGlossinessKey, AddOpacityKey, AddSelfIlluminationKey, AddSpecularKey, AddTextureWeightKey, AddUvDataKey, AddVideoVolumeKey
Parameters
  • kKey
  • strMeshName
  • strMaterialName
  • kColor
AddGlossinessKey (self, kKey, strMeshName, strMaterialName, fWeight)
Add a Glossiness key for the material according to the time and Transition Type of kKey. See Also: AddAmbientKey, AddDiffuseKey, AddOpacityKey, AddSelfIlluminationKey, AddSpecularKey, AddTextureWeightKey, AddUvDataKey, AddVideoVolumeKey
Parameters
  • kKey
  • strMeshName
  • strMaterialName
  • fWeight
AddOpacityKey (self, kKey, strMeshName, strMaterialName, fWeight)
Add an Opacity key for the material according to the time and Transition Type of kKey. See Also: AddAmbientKey, AddDiffuseKey, AddGlossinessKey, AddSelfIlluminationKey, AddSpecularKey, AddTextureWeightKey, AddUvDataKey, AddVideoVolumeKey
Parameters
  • kKey
  • strMeshName
  • strMaterialName
  • fWeight
AddReflectionKey (self, kKey, strMeshName, strMaterialName, fWeight)
Adds an reflection key.
Parameters
  • kKey
  • strMeshName
  • strMaterialName
  • fWeight
AddRefractionKey (self, kKey, strMeshName, strMaterialName, fWeight)
Adds an refraction key.
Parameters
  • kKey
  • strMeshName
  • strMaterialName
  • fWeight
AddSelfIlluminationKey (self, kKey, strMeshName, strMaterialName, fWeight)
Add a Self-illumination key for the material according to the time and Transition Type of kKey. See Also: AddAmbientKey, AddDiffuseKey, AddGlossinessKey, AddOpacityKey, AddSpecularKey, AddTextureWeightKey, AddUvDataKey, AddVideoVolumeKey
Parameters
  • kKey
  • strMeshName
  • strMaterialName
  • fWeight
AddSpecularKey (self, *args)
Add a Specular key for the material according to the time and Transition Type of kKey. See Also: AddAmbientKey, AddDiffuseKey, AddGlossinessKey, AddOpacityKey, AddSelfIlluminationKey, AddTextureWeightKey, AddUvDataKey, AddVideoVolumeKey
Parameters
  • args
AddTextureWeightKey (self, kKey, strMeshName, strMaterialName, eChannel, fWeight)
Add a Texture Channel Weight key for the material according to the time and Transition Type of kKey. See Also: AddAmbientKey, AddDiffuseKey, AddGlossinessKey, AddOpacityKey, AddSelfIlluminationKey, AddSpecularKey, AddTextureWeightKey, AddUvDataKey, AddVideoVolumeKey
Parameters
  • kKey
  • strMeshName
  • strMaterialName
  • eChannel
  • fWeight
AddUvDataKey (self, kKey, strMeshName, strMaterialName, eChannel, kUvOffset, kUvTile, fUvRotate)
Add an UV Texture Coordinates key for the material according to the time and Transition Type of kKey. This key can be used to set the texture channel's UV offset, tile, and rotate values. See Also: AddAmbientKey, AddDiffuseKey, AddGlossinessKey, AddOpacityKey, AddSelfIlluminationKey, AddSpecularKey, AddTextureWeightKey, AddVideoVolumeKey
Parameters
  • kKey
  • strMeshName
  • strMaterialName
  • eChannel
  • kUvOffset
  • kUvTile
  • fUvRotate
AddVideoVolumeKey (self, kKey, strMeshName, strMaterialName, eChannel, fVol, bMute)
Add a Video Volume key for the material according to the time and Transition Type of kKey. This key can be used to set the video material's channel video volume. See Also: AddAmbientKey, AddDiffuseKey, AddGlossinessKey, AddOpacityKey, AddSelfIlluminationKey, AddSpecularKey, AddTextureWeightKey, AddUvDataKey
Parameters
  • kKey
  • strMeshName
  • strMaterialName
  • eChannel
  • fVol
  • bMute
AddWrinkleWeightKey (self, kKey, strMeshName, strMaterialName, uRuleIndex, nWeight)
Adds wrinkle weight key for this ri material component.
Parameters
  • kKey
  • strMeshName
  • strMaterialName
  • uRuleIndex
  • nWeight
CopyMaterial (self, strSrcMeshName, strSrcMaterialName, strDstMeshName, strDstMaterialName)
Copy material.
Parameters
  • strSrcMeshName
  • strSrcMaterialName
  • strDstMeshName
  • strDstMaterialName
GetAmbientColor (self, strMeshName, strMaterialName)
Get the material's Ambient color. See Also: GetDiffuseColor, GetGlossinessWeight, GetMaterialNames, GetOpacity, GetSelfIlluminationWeight, GetSpecularColor, GetSpecularWeight, GetTextureWeights, GetUvData, GetVideoVolume
Parameters
  • strMeshName
  • strMaterialName
GetAttributeValue (self, strMeshName, strMaterialName, strAttributeName)
Returns the attribute value.
Parameters
  • strMeshName
  • strMaterialName
  • strAttributeName
GetDiffuseColor (self, strMeshName, strMaterialName)
Get the material's Diffuse color. See Also: GetAmbientColor, GetGlossinessWeight, GetMaterialNames, GetOpacity, GetSelfIlluminationWeight, GetSpecularColor, GetSpecularWeight, GetTextureWeights, GetUvData, GetVideoVolume
Parameters
  • strMeshName
  • strMaterialName
GetGlossinessWeight (self, strMeshName, strMaterialName)
Get the material's Glossiness weight. See Also: GetMaterialNameParameters
Parameters
  • strMeshName
  • strMaterialName
GetImage (self, strMeshName, strMaterialName, eChannel)
Gets material image from channel.
Parameters
  • strMeshName
  • strMaterialName
  • eChannel
GetImageColor (self, strMeshName, strMaterialName, eChannel)
Gets image color.
Parameters
  • strMeshName
  • strMaterialName
  • eChannel
GetMaterialNames (self, strMeshName)
Get all the material names for the mesh. See Also: GetAmbientColor, GetDiffuseColor, GetGlossinessWeight, GetOpacity, GetSelfIlluminationWeight, GetSpecularColor, GetSpecularWeight, GetTextureWeights, GetUvData, GetVideoVolume
Parameters
  • strMeshName
GetOpacity (self, strMeshName, strMaterialName)
Get the material opacity value. See Also: GetAmbientColor, GetDiffuseColor, GetGlossinessWeight, GetMaterialNames, GetSelfIlluminationWeight, GetSpecularColor, GetSpecularWeight, GetTextureWeights, GetUvData, GetVideoVolume
Parameters
  • strMeshName
  • strMaterialName
GetReflection (self, strMeshName, strMaterialName)
Gets reflection.
Parameters
  • strMeshName
  • strMaterialName
GetRefraction (self, strMeshName, strMaterialName)
Gets refraction.
Parameters
  • strMeshName
  • strMaterialName
GetResourceMapImage (self, strMeshName, strMaterialName, strResourceMapName)
Returns the resource map image.
Parameters
  • strMeshName
  • strMaterialName
  • strResourceMapName
GetSelfIlluminationWeight (self, strMeshName, strMaterialName)
Get the material's self-illumination weight. See Also: GetAmbientColor, GetDiffuseColor, GetGlossinessWeight, GetMaterialNames, GetOpacity, GetSpecularColor, GetSpecularWeight, GetTextureWeights, GetUvData, GetVideoVolume
Parameters
  • strMeshName
  • strMaterialName
GetShader (self, strMeshName, strMaterialName)
Gets shader type of the specify material.
Parameters
  • strMeshName
  • strMaterialName
GetShaderNames (self)
Gets shader names.
GetShaderParameter (self, strMeshName, strMaterialName, strParameter)
Gets the value of the shader parameter.
Parameters
  • strMeshName
  • strMaterialName
  • strParameter
GetShaderParameterNames (self, strMeshName, strMaterialName)
Gets parameter name list of the specify shader.
Parameters
  • strMeshName
  • strMaterialName
GetShaderTextureNames (self, strMeshName, strMaterialName)
Returns the shader texture names for the specified mesh and material.
Parameters
  • strMeshName
  • strMaterialName
GetSpecularColor (self, strMeshName, strMaterialName)
Get the material's Specular color. See Also: GetAmbientColor, GetDiffuseColor, GetGlossinessWeight, GetMaterialNames, GetOpacity, GetSelfIlluminationWeight, GetSpecularWeight, GetTextureWeights, GetUvData, GetVideoVolume
Parameters
  • strMeshName
  • strMaterialName
GetSpecularWeight (self, strMeshName, strMaterialName)
Get the material's Specular weight. See Also: GetAmbientColor, GetDiffuseColor, GetGlossinessWeight, GetMaterialNames, GetOpacity, GetSelfIlluminationWeight, GetSpecularColor, GetTextureWeights, GetUvData, GetVideoVolume
Parameters
  • strMeshName
  • strMaterialName
GetTextureWeights (self, strMeshName, strMaterialName)
Get all texture channel weights for the material. See Also: GetAmbientColor, GetDiffuseColor, GetGlossinessWeight, GetMaterialNames, GetOpacity, GetSelfIlluminationWeight, GetSpecularColor, GetSpecularWeight, GetUvData, GetVideoVolume
Parameters
  • strMeshName
  • strMaterialName
GetUvData (self, strMeshName, strMaterialName, eChannel, kUvOffset, kUvTile, fUvRotate)
Get all texture channel UV coordinates (offset, tiling, rotation) for the material. See Also: GetAmbientColor, GetDiffuseColor, GetGlossinessWeight, GetMaterialNames, GetOpacity, GetSelfIlluminationWeight, GetSpecularColor, GetSpecularWeight, GetTextureWeights, GetVideoVolume
Parameters
  • strMeshName
  • strMaterialName
  • eChannel
  • kUvOffset
  • kUvTile
  • fUvRotate
GetVideoVolume (self, strMeshName, strMaterialName, eChannel)
Get the video volume for all the video channels of the material. See Also: GetAmbientColor, GetDiffuseColor, GetGlossinessWeight, GetMaterialNames, GetOpacity, GetSelfIlluminationWeight, GetSpecularColor, GetSpecularWeight, GetTextureWeights, GetUvData
Parameters
  • strMeshName
  • strMaterialName
  • eChannel
HasImage (self, strMeshName, strMaterialName, eChannel)
Checks whether the specified material channel has an image.
Parameters
  • strMeshName
  • strMaterialName
  • eChannel
IsReflectionEnable (self, strMeshName, strMaterialName)
Gets the state of the reflection.
Parameters
  • strMeshName
  • strMaterialName
IsRefractionEnable (self, strMeshName, strMaterialName)
Gets the state of the refraction.
Parameters
  • strMeshName
  • strMaterialName
IsTwoSidedMaterial (self, strMeshName, strMaterialName)
Gets the Boolean that specifies if the material is set to two sides.
Parameters
  • strMeshName
  • strMaterialName
IsUnique (self, strMeshName, strMaterialName)
Checks whether a material is uniquely referenced in the scene.
Parameters
  • strMeshName
  • strMaterialName
LoadImageToTexture (self, strMeshName, strMaterialName, eChannel, strImagePath)
Import an image into a material texture channel. See Also: LoadVideoToTexture
Parameters
  • strMeshName
  • strMaterialName
  • eChannel
  • strImagePath
LoadMaterial (self, strMeshName, strMaterialName, strFilePath)
Loads the iMaterial file into the specified material.
Parameters
  • strMeshName
  • strMaterialName
  • strFilePath
LoadShaderTexture (self, strMeshName, strMaterialName, strName, strTexturePath)
Loads the texture from the specified file path into the named shader texture slot.
Parameters
  • strMeshName
  • strMaterialName
  • strName
  • strTexturePath
LoadVideoToTexture (self, kKey, strMeshName, strMaterialName, eChannel, strVideoPath)
Import a video into a material texture channel. See Also: LoadImageToTexture
Parameters
  • kKey
  • strMeshName
  • strMaterialName
  • eChannel
  • strVideoPath
MakeUnique (self, strMeshName, strMaterialName)
Make material unique.
Parameters
  • strMeshName
  • strMaterialName
MergeMaterialUV (self, *args)
Merge material.
Parameters
  • args
RemoveMaterialTexture (self, strMeshName, strMaterialName, eChannel)
Removes material texture from the specified material.
Parameters
  • strMeshName
  • strMaterialName
  • eChannel
RemoveUvDataKey (self, kKey, strMeshName, strMaterialName, eChannel)
Remove an UV data key from a material texture channel. See Also: AddUvDataKey
Parameters
  • kKey
  • strMeshName
  • strMaterialName
  • eChannel
SetAttributeValue (self, strMeshName, strMaterialName, strAttributeName, fValue)
Sets the value of material attributes.
Parameters
  • strMeshName
  • strMaterialName
  • strAttributeName
  • fValue
SetImage (self, spImage, strMeshName, strMaterialName, eChannel)
Sets material image to channel.
Parameters
  • spImage
  • strMeshName
  • strMaterialName
  • eChannel
SetImageColor (self, strMeshName, strMaterialName, eChannel, fSoftness, kHsbc, kCmy)
Sets image color.
Parameters
  • strMeshName
  • strMaterialName
  • eChannel
  • fSoftness
  • kHsbc
  • kCmy
SetMaterialName (self, strMeshName, strOrgMatName, strNewMatName)
Sets material name.
Parameters
  • strMeshName
  • strOrgMatName
  • strNewMatName
SetMaterialSettings (self, kOptions, strMeshName, strMaterialName)
Sets material settings as ui.
Parameters
  • kOptions
  • strMeshName
  • strMaterialName
SetReflectionEnable (self, strMeshName, strMaterialName, bEnable)
Sets the state of the reflection.
Parameters
  • strMeshName
  • strMaterialName
  • bEnable
SetRefractionEnable (self, strMeshName, strMaterialName, bEnable)
Sets the state of the refraction.
Parameters
  • strMeshName
  • strMaterialName
  • bEnable
SetShader (self, strMeshName, strMaterialName, strShader)
Sets shader type of the specify material.
Parameters
  • strMeshName
  • strMaterialName
  • strShader
SetShaderParameter (self, strMeshName, strMaterialName, strParameter, kValue)
Sets the value of the shader parameter.
Parameters
  • strMeshName
  • strMaterialName
  • strParameter
  • kValue
SetTwoSidedMaterial (self, strMeshName, strMaterialName, bEnable)
Enable or disable two sided material.
Parameters
  • strMeshName
  • strMaterialName
  • bEnable
SetWrinkleActionToRule (self, strMeshName, strMaterialName, strActionName, strRuleName, strRuleRangeMin, strRuleRangeMax)
Sets the wrinkle action to rule.
Parameters
  • strMeshName
  • strMaterialName
  • strActionName
  • strRuleName
  • strRuleRangeMin
  • strRuleRangeMax
SetWrinkleDetailParameters (self, eWrinkleFacePart, eWrinkleLayerType, fStrength)
Sets strength of wrinkle AoCrease, Redness, NormalStrength.
Parameters
  • eWrinkleFacePart
  • eWrinkleLayerType
  • fStrength
SetWrinkleDetailStrength (self, eWrinkleFacePart, fStrength)
Sets total wrinkle strength.
Parameters
  • eWrinkleFacePart
  • fStrength
SetWrinkleFlattenTexture (self, eChannel, strImagePath)
Sets texture for all wrinkle channel.
Parameters
  • eChannel
  • strImagePath
SetWrinkleMaskFilePath (self, strMeshName, strMaterialName, strMaskPath, uMaskIndex)
Sets the wrinkle mask file path.
Parameters
  • strMeshName
  • strMaterialName
  • strMaskPath
  • uMaskIndex
SetWrinkleRule (self, strMeshName, strMaterialName, strRelateName, uMaskValueIndex, uMaskTextureIndex, strMaskChannel, fWeight)
Sets the wrinkle rule.
Parameters
  • strMeshName
  • strMaterialName
  • strRelateName
  • uMaskValueIndex
  • uMaskTextureIndex
  • strMaskChannel
  • fWeight
SetWrinkleTextureFilePath (self, strMeshName, strMaterialName, strDiffusePath, strNormalPath, strRoughnessPath, uWrinkleImageIndex)
Sets the wrinkle texture file path.
Parameters
  • strMeshName
  • strMaterialName
  • strDiffusePath
  • strNormalPath
  • strRoughnessPath
  • uWrinkleImageIndex
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
