IC8 Python API:RLPy RIObject
Contents
- 1 Description
- 2 Class Methods
- 2.1 RLPy.RIObject.AlignTo(self, spTargetObject, eAlignAxis, bAlignToPivot)
- 2.2 RLPy.RIObject.Clone(self)
- 2.3 RLPy.RIObject.DeleteMesh(self, spMesh)
- 2.4 RLPy.RIObject.FollowPath(self, spPath, kAppTime)
- 2.5 RLPy.RIObject.GetBounds(self, kMaxPoint, kCenterPoint, kMinPoint)
- 2.6 RLPy.RIObject.GetControl(self, strKey)
- 2.7 RLPy.RIObject.GetDataBlock(self, strId)
- 2.8 RLPy.RIObject.GetID(self)
- 2.9 RLPy.RIObject.GetLinkedObject(self, kTime)
- 2.10 RLPy.RIObject.GetMeshes(self, bAll = True)
- 2.11 RLPy.RIObject.GetMeshNames(self, bAll = True)
- 2.12 RLPy.RIObject.GetName(self)
- 2.13 RLPy.RIObject.GetPivot(self, kPosition, kOrientation)
- 2.14 RLPy.RIObject.GetType(self)
- 2.15 RLPy.RIObject.IsSelected(self)
- 2.16 RLPy.RIObject.IsStatic(self)
- 2.17 RLPy.RIObject.LinkTo(self, spTargetObject, eAlignType, kTime)
- 2.18 RLPy.RIObject.LocalTransform(self)
- 2.19 RLPy.RIObject.ReleasePath(self, kTime)
- 2.20 RLPy.RIObject.RemoveDataBlock(self, strId)
- 2.21 RLPy.RIObject.RemoveLinkKey(self, kTime)
- 2.22 RLPy.RIObject.SetDataBlock(self, strId, spDataBlock)
- 2.23 RLPy.RIObject.SetName(self, strName)
- 2.24 RLPy.RIObject.SetParent(self, args)
- 2.25 RLPy.RIObject.SetStatic(self, bStatic)
- 2.26 RLPy.RIObject.UnLink(self, kTime)
- 2.27 RLPy.RIObject.Update(self)
- 2.28 RLPy.RIObject.WorldTransform(self)
- 3 Description
- 4 Constructor & Destructor
- 5 Member Functions
- 5.1 AlignTo (self, spTargetObject, eAlignAxis, bAlignToPivot)
- 5.2 Clone (self)
- 5.3 DeleteMesh (self, spMesh)
- 5.4 FollowPath (self, spPath, kAppTime)
- 5.5 GetBounds (self, kMaxPoint, kCenterPoint, kMinPoint)
- 5.6 GetControl (self, strKey)
- 5.7 GetDataBlock (self, strId)
- 5.8 GetID (self)
- 5.9 GetLinkedObject (self, kTime)
- 5.10 GetMeshNames (self, bAll=True)
- 5.11 GetMeshes (self, bAll=True)
- 5.12 GetName (self)
- 5.13 GetParent (self)
- 5.14 GetParentNode (self)
- 5.15 GetPivot (self, kPosition, kOrientation)
- 5.16 GetType (self)
- 5.17 IsSelected (self)
- 5.18 IsStatic (self)
- 5.19 LinkTo (self, *args)
- 5.20 LocalTransform (self)
- 5.21 ReleasePath (self, kTime)
- 5.22 RemoveDataBlock (self, strId)
- 5.23 RemoveLinkKey (self, kTime)
- 5.24 SetDataBlock (self, strId, spDataBlock)
- 5.25 SetName (self, strName)
- 5.26 SetParent (self, *args)
- 5.27 SetStatic (self, bStatic)
- 5.28 UnLink (self, kTime)
- 5.29 Update (self, *args)
- 5.30 WorldTransform (self)
- 5.31 __eq__ (self, kRhs)
- 6 Properties
- Main article: iC8 Modules.
- Last modified: 10/21/2026
Description
This class is used to access the bone node parameters in a character skeleton or object. Retrievable parameters include name, ID, parent node, list of child nodes, and more. Use Update to get the world-transform values of the bone node for the current point in time.
Class Methods
Attach object to another object with align axis.
Experimental API
Parameters
- spTargetObject[IN] Attach target object - RLPy.RIObject
- eAlignAxis[IN] Attach object with align axis - RLPy.EAlignAxis
- RLPy.EAlignAxis_INVALID
- RLPy.EAlignAxis_X_AXIS
- RLPy.EAlignAxis_Y_AXIS
- RLPy.EAlignAxis_Z_AXIS
- RLPy.EAlignAxis_ROTATE_AXIZ
- bAlignToPivot[IN] Align object pivot or align object world bound center - bool
Returns
- RLPy.RStatus.Success - Succeed
- RLPy.RStatus.Failure - Fail
1 # No example
Clones the object original and returns the clone.
Experimental API
Returns
clonedobject.
1 # No example
Delete the mesh of the object.
Parameters
- spMesh[IN] the mesh want to delete - RLPy.RIMesh
Returns
1 # No example
Experimental API
Parameters
- spPath[IN]Path you want to set.
- kTime[IN] Time of following path.
Returns
1 # No example
Get world bound of this object.
Experimental API
Parameters
kMaxPoint[OUT] The maximal point of the box - RLPy.RVector3f kCenterPoint[OUT] The center of the bounding box - RLPy.RVector3f kMinPoint[OUT] The minimal point of the box - RLPy.RVector3f
Returns
1 # No example
Get control of the object.
Parameters
- strKey[IN] Key of the controller, allowing use "Transform" to retrieve the transform control of the Transform track, use "PathPosition" to retrieve the float control of Path position track, and use "PathOffset" to retrieve the transform control of the Path Offset track, - string
Returns
The specified control - RLPy.RControl
1 # No example
Provide object to get data block.
Experimental API
Parameters
- strId[IN] DataBlock Id - string
Returns
data block - RLPy. RDataBlock
1 # No example
Get unique id of the object.
Returns
object id - int
1 # Get root bone node
2 avatar_list = RLPy.RScene.GetAvatars()
3 avatar = avatar_list[0]
4 skeleton_component = avatar.GetSkeletonComponent()
5 bone_node = skeleton_component.GetRootBone()
6
7 # Get root bone ID
8 bone_id = bone_node.GetID()
9 print(bone_id)
Get linked object by time.
Experimental API
Parameters
- kTime[IN] Time to get the linked object - RLPy.RLTime
Returns
Linkedobject or Linked Node. If it's null, there are no linked object.
1 # No example
Get all meshed of the object.
Parameters
- bAllChild[IN] bAll=true will get all meshes including child nodes.
Returns
mesh object list - list
1 # No example
Get all mesh names of the object.
Parameters
Returns
mesh name list - string
1 # No example
Get name of the object.
Returns
object name - string
6
7 # Get root bone name
8 bone_name = bone_node.GetName()
9 print(bone_name)
Get this object's pivot.
Experimental API
Parameters
kPosition[OUT] current pivot position - RLPy.RVector3f kOrientation[OUT] current pivot orientation - RLPy.RVector3f
Returns
1 # No example
Get object type of the object.
Returns
object type - RLPy.EObjectType
- RLPy.EObjectType_Object
- RLPy.EObjectType_Avatar
- RLPy.EObjectType_Hair
- RLPy.EObjectType_Cloth
- RLPy.EObjectType_Accessory
- RLPy.EObjectType_Prop
- RLPy.EObjectType_Camera
- RLPy.EObjectType_Particle
- RLPy.EObjectType_Light
- RLPy.EObjectType_SpotLight
- RLPy.EObjectType_PointLight
- RLPy.EObjectType_DirectionalLight
- RLPy.EObjectType_PopcornFX
- RLPy.EObjectType_Path
- RLPy.EObjectType_Sky
1 # No example
A Boolean value indicating whether the object is in the selected state.
Experimental API
Returns
selectedor not
1 # No example
Get animation status of the object.
Experimental API
Returns
trueStatic object without any animation falseKinetic object with animation
1 # No example
Simultaneously move or rotate link target object and this object.
Experimental API
Parameters
- spTargetObject[IN] Link target object - RLPy.RIObject
- eAlignType[IN] Link object align type - RLPy.ELinkObjectAlignType
- RLPy.ELinkObjectAlignType_None
- RLPy.ELinkObjectAlignType_Position
- RLPy.ELinkObjectAlignType_Position_And_Rotation
- kTime[IN] Time of link - RLPy.RLTime
Returns
1 # No example
Get local transform of the object.
Experimental API
Returns
object transform - RLPy.RTransformf
6
7 # Get root bone local transform
8 local_transform = bone_node.LocalTransform()
9 print(local_transform)
Release path key from object.
Experimental API
Parameters
- kTime[IN] Time of release path - RLPy.RLTime
Returns
1 # No example
Remove data block from object.
Experimental API
Parameters
Returns
1 # No example
Remove link key from object.
Experimental API
Parameters
- kTime[IN] Time of remove link key - RLPy.RLTime
Returns
1 # No example
Provide object to store data through data block.
Experimental API
Parameters
- spDataBlock[IN] Store data - RLPy.RDataBlock
Returns
1 # No example
Set object's name.
Experimental API
Parameters
- strName[IN] object name - string
Returns
1 # No example
Experimental API
Parameters
- spParent[IN] If parent is null, this object will restore default parent - RLPy.RINode
Returns
RStatus - RLPy.RStatus
1 # No example
Set animation status of the object.
Experimental API
Returns
- bStatic[IN]Make the object stationary
1 # No example
Unlink object of time.
Experimental API
Parameters
- kTime[IN] Time of unlink - RLPy.RLTime
Returns
1 # No example
In iClone's 3D animation world, it works based on adding keys, so when you add a key, you need to call Update function when you need to update the key value to the object.
Experimental API
6
7 # Get root bone child node world transform rotation x-axis value
8 motion_bones = skeleton_component.GetMotionBones()
9 child = motion_bones[1]
10 child_world = child.WorldTransform()
11 child_rot_x = child_world.R().x
12
13 # Set float control rotation x-axis value
14 RLPy.RGlobal.SetTime(RLPy.RTime(0))
15 animation_clip = skeleton_component.GetClip(0)
16 root_control = animation_clip.GetControl("Layer", root)
17 data_block = root_control.GetDataBlock()
18 float_control_rotate_x = data_block.GetControl("Rotation/RotationX")
19 float_control_rotate_x.SetValue(RLPy.RGlobal.GetTime(), math.radians(60))
20
21 # Update root bone with float control
22 bone_node.Update()
23
24 # Get root bone child node world transform rotation x-axis value after updated
25 new_child_world = child.WorldTransform()
26 after_update_child_rot_x = new_child_world.R().x
Get world transform of the object.
Experimental API
Returns
6
7 # Get root bone world transform
8 world_transform = bone_node.WorldTransform()
9 print(world_transform)
Description
__init__ (self, *args, **kwargs)
Initializes a new ri object instance.
Parameters
- args
- kwargs
Member Functions
Attach object to another object with align axis. And allow to decide align object pivot or align object world bound center. This function works on RIAvatar, RIProp, RIParticle, RIPopcornFX, RIPointLight, RISpotLight.
Parameters
- spTargetObject
- eAlignAxis
- bAlignToPivot
Clone (self)
Deletes the mesh of the object.
Parameters
- spMesh
Sets the object move along the path.
Parameters
- spPath
- kAppTime
Returns the bounds.
Parameters
- kMaxPoint
- kCenterPoint
- kMinPoint
Gets control of the object.
Parameters
- strKey
Parameters
- strId
GetID (self)
Get the ID of the bone node in a character skeleton or scene object.
Gets linked object by time.
Parameters
- kTime
Gets all mesh names of the object.
Parameters
- bAll (default: True)
Returns the meshes.
Parameters
GetName (self)
Get the name of the bone node in a character skeleton or scene object.
GetParent (self)
Get the parent bone of the bone node in a character skeleton or scene object. If a parent does not exist, then return None. See Also: GetChildren
Gets the parent node of the object.
Gets this object's pivot.
Parameters
- kPosition
- kOrientation
GetType (self)
Gets object type of the object.
IsSelected (self)
IsStatic (self)
Reports whether this scene object is static.
Simultaneously move or rotate link target object and this object. And allowed to link your object to another one at a specific point of time. The Link never changes the Hierarchy Structure of the current object.
Parameters
- args
Get the local-transform for a bone node in a character skeleton or scene object. See Also: WorldTransform
Release path key from object. If object does not set path, it will return RO_FAILURE.
Parameters
- kTime
Removes data block from object. If object does not have data block, it will return RO_FAILURE.
Parameters
- strId
Removes link key from object. If object does not link object, it will return RO_FAILURE.
Parameters
- kTime
Provide object to store data through data block. If data block is null, it will return RO_FAILURE.
Parameters
- strId
- spDataBlock
Sets object's name.
Parameters
- strName
Sets the parent of this object.
Parameters
- args
Sets the static.
Parameters
- bStatic
Unlink object of time..
Parameters
- kTime
Update the Transform Control for a bone node in a character skelecton or scene object and update the scene. After the Update, the Transform Control's key values will reflect the world-transform values of the bone node for the current point in time.
Parameters
- args
Get the world-transform for a bone node in a character skeleton or scene object. See Also: LocalTransform
__eq__ (self, kRhs)
Reports whether this value equals another value.
Parameters
- kRhs
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
