IC8 Python API:RLPy RIPointLight
From Reallusion Wiki!
Jump to: navigation, search
Contents
Main article: iC8 Modules.
Last modified: 10/21/2026
Description
This class provides operations specific to Point Lights. Besides the inherited member functions from RILight, the point light's range value can also be adjusted.
Class Methods
RLPy.RIPointLight.ClearRectTexture(self)
Clear rectangle texture of this light.
Experimental API
Returns
RLPy.RStatus.Success - Succeed
RLPy.RStatus.Failure - Fail
1 # No example
RLPy.RIPointLight.GetInverseSquare(self)
Get if light's intensity follows inverse-square law in physics.
Experimental API
Returns
True if light's intensity follows inverse-square law, False if it is not - bool
1 # No example
RLPy.RIPointLight.GetRange(self)
Get the light range.
Experimental API
Returns
The value of the "range" attribute of the light node - float
1 # use light name to find object
2 light_object = RLPy.RScene.FindObject(RLPy.EObjectType_Light, "Point light")
3 #get light range
4 print(light_object.GetRange())
RLPy.RIPointLight.GetRectWidthHeight(self)
Get the light's rectangle's width & height.
Experimental API
Returns
rectangle's width & height - RLPy.RVector2f
Parameters
kTime[in] The time at which to set the multiplier.
fMultiplier[in] The Light multiplier value.
Returns
1 # No example
RLPy.RIPointLight.GetTubeLength(self)
Get the light's tube length.
Experimental API
Returns
light's tube length - float
1 # No example
RLPy.RIPointLight.GetTubeRadius(self)
Get the light's tube Radius.
Experimental API
Returns
light's tube Radius - float
1 # No example
RLPy.RIPointLight.GetTubeSoftRadius(self)
Get the light's tube SoftRadius.
Experimental API
Returns
light's tube SoftRadius - float
1 # No example
RLPy.RIPointLight.IsCastShadow(self)
Get the light if cast shadow enable.
Experimental API
Returns
True if light is cast shadow enable, False if not - bool
1 # No example
RLPy.RIPointLight.IsRectangleShape(self)
Get if light's shape is a rectangle.
Experimental API
Returns
True if light's shape is a rectangle, False if it is not - bool
1 # No example
RLPy.RIPointLight.IsTubeShape(self)
Get if light's shape is a tube, sphere is also considered a tube with zero length.
Experimental API
Returns
True if light's shape is a tube, False if it is not - bool
1 # No example
RLPy.RIPointLight.LoadIes(self, strIesFilePath)
Load an IES file for this light.
Experimental API
Parameters
strIesFilePath[in] The IES file path you want to load - string
Returns
1 # No example
RLPy.RIPointLight.LoadRectTexture(self, strTexturePath)
Load a rectangle texture for this light.
Experimental API
Parameters
strTexturePath[in] The texture path you want to load - string
Returns
1 # No example
RLPy.RIPointLight.SaveIes(self, strIesFilePath)
Save the IES file of this light.
Experimental API
Parameters
strIesFilePath[in] The IES file path you want to save - string
Returns
1 # No example
RLPy.RIPointLight.SaveRectTexture(self, strTexturePath)
Save the rectangle texture of this light.
Experimental API
Parameters
strTexturePath[in] The texture path you want to save - string
Returns
1 # No example
RLPy.RIPointLight.SetCastShadow(self, bEnable)
Set the light's cast shadow is enable.
Experimental API
Parameters
bEnable[in] If light's cast shadow is enable - bool
Returns
1 # No example
RLPy.RIPointLight.SetInverseSquare(self, b)
Set light's intensity to follow inverse-square law in physics.
Experimental API
Parameters
b[in] If light's intensity follows inverse-square law - bool
Returns
1 # No example
RLPy.RIPointLight.SetRange(self, kTime, fRange)
Set the light range.
Experimental API
Parameters
kTime[in] The time at which to set the beam - RLPy.RLTime
fRange[in] The Light range value - float
Returns
1 light_object = RLPy.RScene.FindObject(RLPy.EObjectType_Light, "Point light") # use light name to find object
3 #set light range
4 light_object.SetRange(RLPy.RTime(0), 1000.0)
5 print(light_object.GetRange())
RLPy.RIPointLight.SetRectangleShape(self, bRectangle)
Set the light's shape to rectangle.
Experimental API
Parameters
bRectangle[in] If light's shape is a rectangle - bool
Returns
1 # No example
RLPy.RIPointLight.SetRectWidthHeight(self, vWidthHeight)
Set the light's rectangle's width & height.
Experimental API
Parameters
vWidthHeight[in] rectangle's width & height - RLPy.RVector2f
Returns
1 # No example
RLPy.RIPointLight.SetTubeLength(self, fLength)
Set the light's tube length.
Experimental API
Parameters
fLength[in] tube length - float
Returns
1 # No example
RLPy.RIPointLight.SetTubeRadius(self, radius)
Set the light's tube radius.
Experimental API
Parameters
radius[in] tube radius - float
Returns
1 # No example
RLPy.RIPointLight.SetTubeShape(self, bTube)
Set the light's shape to tube, sphere is also considered a tube with zero length.
Experimental API
Parameters
bTube[in] If light's shape is a tube - bool
Returns
1 # No example
RLPy.RIPointLight.SetTubeSoftRadius(self, softRadius)
Set the light's tube soft radius.
Experimental API
Parameters
softRadius[in] tube soft radius - float
Returns
1 # No example
Description
Constructor & Destructor
__init__ (self, *args, **kwargs)
Initializes a new ri point light instance.
Parameters
  • args
  • kwargs
Member Functions
ClearRectTexture (self)
Clears rectangle texture of this light.
GetInverseSquare (self)
Gets if light's intensity follows <a href="https://en.wikipedia.org/wiki/Inverse-square_law">inverse-square law in physics.</a> Its intensity is inversely proportional to the square of the distance from the source.
GetRange (self)
Get the point light range. See Also: SetRange
GetRectWidthHeight (self)
Gets the light's rectangle's width & height.
GetTubeLength (self)
Gets the light's tube length.
GetTubeRadius (self)
Gets the light's tube Radius.
GetTubeSoftRadius (self)
Gets the light's tube SoftRadius.
IsCastShadow (self)
Gets the light if cast shadow enable.
IsRectangleShape (self)
Gets if light's shape is a rectangle.
IsTubeShape (self)
Gets if light's shape is a tube, sphere is also considered a tube with zero length.
LoadIes (self, strIesFilePath)
Loads an IES file for this light.
Parameters
  • strIesFilePath
LoadRectTexture (self, strTexturePath)
Loads a rectangle texture for this light.
Parameters
  • strTexturePath
SaveIes (self, strIesFilePath)
Saves the IES file of this light.
Parameters
  • strIesFilePath
SaveRectTexture (self, strTexturePath)
Saves the rectangle texture of this light.
Parameters
  • strTexturePath
SetCastShadow (self, bEnable)
Sets the light's cast shadow is enable.
Parameters
  • bEnable
SetInverseSquare (self, b)
Sets light's intensity to follow <a href="https://en.wikipedia.org/wiki/Inverse-square_law">inverse-square law in physics.</a>.
Parameters
  • b
SetRange (self, kTime, fRange)
Set the point light range. See Also: GetRange
Parameters
  • kTime
  • fRange
SetRectWidthHeight (self, vWidthHeight)
Sets the light's rectangle's width & height.
Parameters
  • vWidthHeight
SetRectangleShape (self, bRectangle)
Sets the light's shape to rectangle.
Parameters
  • bRectangle
SetTubeLength (self, fLength)
Sets the light's tube length.
Parameters
  • fLength
SetTubeRadius (self, radius)
Sets the light's tube radius.
Parameters
  • radius
SetTubeShape (self, bTube)
Sets the light's shape to tube, sphere is also considered a tube with zero length.
Parameters
  • bTube
SetTubeSoftRadius (self, softRadius)
Sets the light's tube soft radius.
Parameters
  • softRadius
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
