IC8 Python API:RLPy RISkeletonComponent
Contents
- 1 Description
- 2 Class Methods
- 2.1 RLPy.RISkeletonComponent.AddClip(self, kTime)
- 2.2 RLPy.RISkeletonComponent.BakeFkToIk(self, kTime, bAllClip)
- 2.3 RLPy.RISkeletonComponent.BreakClip(self, kTime)
- 2.4 RLPy.RISkeletonComponent.ConvertBoneAxisAndParent(self, kAxisMaps, kReParentMaps, bIncludeDummyNode = True)
- 2.5 RLPy.RISkeletonComponent.ConvertToMotionBoneWorldTransforms(self)
- 2.6 RLPy.RISkeletonComponent.ConvertToOriginalBoneAxis(self, bIncludeDummyNode = True)
- 2.7 RLPy.RISkeletonComponent.FlattenMotionClip(self, spClip)
- 2.8 RLPy.RISkeletonComponent.GetBoneTPosePosition(self, spBone)
- 2.9 RLPy.RISkeletonComponent.GetClip(self, uIndex)
- 2.10 RLPy.RISkeletonComponent.GetClipByTime(self, kHitTime)
- 2.11 RLPy.RISkeletonComponent.GetClipCount(self)
- 2.12 RLPy.RISkeletonComponent.GetEffector(self, eEffector)
- 2.13 RLPy.RISkeletonComponent.GetReach(self, eEffector)
- 2.14 RLPy.RISkeletonComponent.GetRootBone(self)
- 2.15 RLPy.RISkeletonComponent.GetSelectedBones(self)
- 2.16 RLPy.RISkeletonComponent.GetSkinBones(self)
- 2.17 RLPy.RISkeletonComponent.IsBoneAnimated(self, spBone)
- 2.18 RLPy.RISkeletonComponent.MergeClips(self, spClip1, spClip2)
- 2.19 RLPy.RISkeletonComponent.SampleMotionClip(self, spClip, bOptimize = True)
- 2.20 RLPy.RISkeletonComponent.SetBoneTPosePosition(self, spBone, kPos)
- 3 Description
- 4 Constructor & Destructor
- 5 Member Functions
- 5.1 AddClip (self, kTime)
- 5.2 AutoPosition (self, spBone)
- 5.3 BakeFkToIk (self, kTime, bAllClip)
- 5.4 BreakClip (self, kTime)
- 5.5 ConvertBoneAxisAndParent (self, kAxisMaps, kReParentMaps, kInsertBoneInfo, bIncludeDummyNode=True)
- 5.6 ConvertFramesToMotionBoneWorldTransforms (self, _from, to)
- 5.7 ConvertToMotionBoneWorldTransforms (self)
- 5.8 ConvertToOriginalBoneAxis (self, bIncludeDummyNode=True, bIncludeMeshNode=True)
- 5.9 DeleteClip (self, spClip)
- 5.10 FlattenMotionClip (self, spClip)
- 5.11 GetAllAnimationBone (self)
- 5.12 GetBoneQniqueNames (self)
- 5.13 GetBoneTPosePosition (self, spBone)
- 5.14 GetClip (self, uIndex)
- 5.15 GetClipByTime (self, kHitTime)
- 5.16 GetClipCount (self)
- 5.17 GetEffector (self, eEffector)
- 5.18 GetFacialBone (self, eFacialBone)
- 5.19 GetLookAtComponent (self)
- 5.20 GetReach (self, eEffector)
- 5.21 GetRootBone (self)
- 5.22 GetSelectedBones (self)
- 5.23 GetSkinBones (self)
- 5.24 IsBoneAnimated (self, spBone)
- 5.25 MergeClips (self, spClip1, spClip2)
- 5.26 MirrorClip (self, spClip)
- 5.27 SampleMotionClip (self, spClip, bOptimize=True)
- 5.28 SetBoneTPosePosition (self, spBone, kPos)
- 6 Properties
- Main article: iC8 Modules.
- Last modified: 10/21/2026
Description
Class Methods
Add body motion clip.
Experimental API
Parameters
- kTime[IN] The time at which to add the clip - RLPy.RLTime
Returns
Pointer to the clip - RLPy.RIClip
1 # No example
Bake the FK result to IK.
Experimental API
Parameters
- kTime[IN] time to bake - RLPy.RLTime
- bAllClip[IN] if bAllClip is true, it will bake all keys in the range of the clip. otherwise it will only set the IK key on kTime - bool
Returns
- RLPy.RStatus.Success - Succeed
- RLPy.RStatus.Failure - Fail
1 # No example
Break the clip at that time according to the specified time.
Experimental API
Parameters
- kTime[IN] specified time - RLPy.RLTime
Returns
1 # No example
This function can calculate new transform based on axis matrix maps and parent maps.
Experimental API
Parameters
- kAxisMaps[IN] The axis conversion of the bone according to this axis map - RLPy.RMatrix4f
- kReParentMaps[IN] Define the new parent of the skeleton, calculate the new local transform will get according to the new parent - string
- bIncludeDummyNode[IN] Decide if this conversion wants to include dummy nodes - bool
Returns
Each Bone transform calculated from the Axis map and the paren map - list
1 # No example
Convert to motion bone world transforms.
Returns
Motion bone world transforms - string
1 # No example
This function can calculate all the skin bones based on the original bone's axis to calculate the current local transform.
Experimental API
Parameters
Returns
Local transform calculated from the original axis of the bone. If the return is empty, it means that the object has no original axial direction - list
1 # No example
The Flatten function merges all of the Layer Keys into the motion clip.
Experimental API
Parameters
- spClip[IN] Flatten the specified clip - RLPy.RIClip
Returns
1 # No example
Get TPose of the specify bone.
Parameters
- spBone[IN] bone object - RLPy.RINode
Returns
Specify the TPose position of the bone - RLPy.RVector3f
1 # No example
Get clip of the bone.
Parameters
- uIndex[IN] Index of the clip - int
Returns
1 skeleton_component = avatar.GetSkeletonComponent()
2 print(skeleton_component.GetClip(0))
Get motion clip.
Parameters
- kHitTime[IN] time during clip range - RLPy.RLTime
Returns
1 # No example
Get number of clips.
Returns
Number of clips - int
2 print(skeleton_component.GetClipCount())
Get human IK effector component of the object.
Parameters
- eEffector[IN] Specify the effector you want to access - RLPy.EHikEffector
- RLPy.EHikEffector_Invalid
- RLPy.EHikEffector_Hip
- RLPy.EHikEffector_LeftFoot
- RLPy.EHikEffector_RightFoot
- RLPy.EHikEffector_LeftHand
- RLPy.EHikEffector_RightHand
- RLPy.EHikEffector_LeftKnee
- RLPy.EHikEffector_RightKnee
- RLPy.EHikEffector_LeftElbow
- RLPy.EHikEffector_RightElbow
- RLPy.EHikEffector_ChestOrigin
- RLPy.EHikEffector_Neck
- RLPy.EHikEffector_LeftToe
- RLPy.EHikEffector_RightToe
- RLPy.EHikEffector_LeftShoulder
- RLPy.EHikEffector_RightShoulder
- RLPy.EHikEffector_Head
- RLPy.EHikEffector_LeftHip
- RLPy.EHikEffector_RightHip
- RLPy.EHikEffector_Quantity
Returns
Pointer of the RIEffector object - RLPy.RIEffector
1 # No example
Get human IK reach of the object.
Parameters
Returns
Pointer of the RIReach object - RLPy.RIReach
1 # No example
Get root bone.
Returns
Pointer to root bone - RLPy.RINode
2 root_bone = skeleton_component.GetRootBone()
3 print(root_bone.GetName())
Get selected bone.
Returns
Selected bones - list
2 selected_bones = skeleton_component.GetSelectedBones()
3 print(len(selected_bones))
Get skin bones of avatar.
Returns
Skin bone nodes - list
2 motion_bones = skeleton_component.GetSkinBones()
3 print(len(motion_bones))
Check the bone can animate.
Experimental API
Parameters
- spBone[IN] bone node - RLPy.RINode
Returns
the bone can animate or not - bool
1 # No example
Merge two clips.
Experimental API
Parameters
- spClip1[IN] specified clip one - RLPy.RIClip
- spClip2[IN] specified clip two - RLPy.RIClip
Returns
1 # No example
The Sample function is used to expose the contents of a motion or animation clip as Layer Keys.
Experimental API
Parameters
- spClip[IN] Sample specified clip - RLPy.RIClip
- bOptimize[IN] Provide an optimized way to sample motion clips, otherwise every frame will be sampled, which is enabled by default - bool
Returns
1 # No example
Set TPose of the specify bone.
Parameters
- kPos[IN] specify the TPose position of the bone - RLPy.RVector3f
Returns
1 # No example
Description
frame|left|Motion bones are responsible for retargeting motion between different characters of different sizes and proportions. This class is mainly used to get all the bones, skeleton states, and animation clips inside an object. If the control object of this component is RIAvatar, then the motion bones will be retrieved. For other objects, the skin bones will be returned. For avatars, the motion bones will be present mainly for retargeting purchases, which are also responsible for driving the skin bones.
__init__ (self, *args, **kwargs)
Initializes a new ri skeleton component instance.
Parameters
- args
- kwargs
Member Functions
Adds body motion clip.
Parameters
- kTime
Automatically position a bone while adjusting the avatar T-Pose.
Parameters
- spBone
Bakes the FK result to IK.
Parameters
- kTime
- bAllClip
Parameters
- kTime
Parameters
- kAxisMaps
- kReParentMaps
- kInsertBoneInfo
- bIncludeDummyNode (default: True)
Converts frames to motion bone world transforms.
Parameters
- _from
- to
Converts to motion bone world transforms.
Parameters
- bIncludeMeshNode (default: True)
Deletes motion clip.
Parameters
- spClip
Parameters
- spClip
Gets only the animation bone.
Gets skeleton bone name processed by avoiding name.
Gets TPose of the specify bone.
Parameters
- spBone
Get the clip on the current object at the specified index. Currently, only works for body motion clips on the timeline for avatars and animation tracks for other object types. If the current object does not have a clip or if the index exceeds the number of existing clips then return None. See also: RIClip
Parameters
- uIndex
Gets motion clip.
Parameters
- kHitTime
GetClipCount (self)
Get the total clip count for the current object. Currently, only works for body motion clips on the timeline for avatars and animation tracks for other object types. If a clip does not exist then return 0. See also: RIClip
Gets human IK effector component of the object.
Parameters
- eEffector
Gets specified facial bone node of the avatar.
Parameters
- eFacialBone
Gets Look At component of the object.
Gets human IK reach of the object.
Parameters
- eEffector
GetRootBone (self)
Get the root bone of this skeleton component. See also: RINode
Get all of the selected bones on the current object. If no bones are selected for the current character, then an empty list is returned.
GetSkinBones (self)
Get the skin bones for the current object. Skin bones are the counterparts to the mesh skin, if this object is an avatar then the motion bones will drive the skin bones. See also: RINode
Checks the bone can animate.
Parameters
- spBone
Merge two clips. And only adjacent clips can be merged.
Parameters
- spClip1
- spClip2
Mirror clip.
Parameters
- spClip
Parameters
- spClip
- bOptimize (default: True)
Sets TPose of the specify bone.
Parameters
- spBone
- kPos
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
