IC8 Python API:RLPy RISky
From Reallusion Wiki!
Jump to: navigation, search
Main article: iC8 Modules.
Last modified: 10/21/2026
Description
Represents a sky object. It exposes visibility controls and access to the sky material component.
Class Methods
RLPy.RISky.GetMaterialComponent(self)
Get material component of the object.
Returns
Pointer of the RIMaterialComponent object - RLPy.RIMaterialComponent
1 # No example
RLPy.RISky.IsVisible(self, kTime )
Check if the prop is visible.
Experimental API
Parameters
kTime[IN] Specifies the time to check if prop is visible - RLPy.RLTime
Returns
Bool value true if prop is visible; otherwise false.
1 # No example
RLPy.RISky.SetVisible(self, kTime, bVisible )
Sets the visible status.
Parameters
kTime[IN] Specifies the time to set visible - RLPy.RLTime
bVisible[IN] Visible status - bool
Returns
RLPy.RStatus.Success - Succeed
RLPy.RStatus.Failure - Fail
1 # No example
Description
Constructor & Destructor
__init__ (self, *args, **kwargs)
Initializes a new ri sky instance.
Parameters
  • args
  • kwargs
Member Functions
GetMaterialComponent (self)
Gets material component of the object.
IsVisible (self, kTime)
Checks if prop is visible.
Parameters
  • kTime
SetVisible (self, kTime, bVisible)
( Experimental Function ) Set visible status.
Parameters
  • kTime
  • bVisible
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
