IC8 Python API:RLPy RInsertBoneInfo
From Reallusion Wiki!
Jump to: navigation, search
Description
This class stores the names used to insert a bone, including its new name and its parent and child bones.
Constructor & Destructor
__init__ (self)
Initializes a new insert bone info instance.
Member Functions
GetChildBoneName (self)
Returns the child bone name.
Sample code
Demonstrates calls to `RLPy.RInsertBoneInfo.GetChildBoneName`, `RLPy.RInsertBoneInfo.GetNewBoneName`, `RLPy.RInsertBoneInfo.GetParentBoneName`, `RLPy.RInsertBoneInfo.SetInfo`, and `RLPy.RInsertBoneInfo.__eq__` using the example's inputs.
import RLPy
def run_script():
    info = RLPy.RInsertBoneInfo()
    info.SetInfo("Parent", "NewBone", "Child")
    same = RLPy.RInsertBoneInfo()
    same.SetInfo("Parent", "NewBone", "Child")
    different = RLPy.RInsertBoneInfo()
    different.SetInfo("Parent", "OtherBone", "Child")
    return (
        info.GetParentBoneName(),
        info.GetNewBoneName(),
        info.GetChildBoneName(),
        info == same,
        info == different,
GetNewBoneName (self)
Returns the new bone name.
Sample code
import RLPy
def run_script():
    return (
        info == same,
        info == different,
GetParentBoneName (self)
Returns the parent bone name.
Sample code
import RLPy
def run_script():
    return (
        info == same,
        info == different,
SetInfo (self, strParentName, strNewBoneName, strChildName)
Sets the info.
Parameters
  • strParentName
  • strNewBoneName
  • strChildName
Sample code
import RLPy
def run_script():
    return (
        info == same,
        info == different,
__eq__ (self, rhs)
Reports whether this value equals another value.
Parameters
  • rhs
Sample code
import RLPy
def run_script():
    return (
        info == same,
        info == different,
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
