IC8 Python API:RLPy RKey
Contents
- 1 Description
- 2 Class Methods
- 3 Description
- 4 Constructor & Destructor
- 5 Member Functions
- 6 Properties
- Main article: iC8 Modules.
- Last modified: 10/21/2026
Description
This is the base class for keys which stores the time of the keys. Rkey can be inserted into RControl.
Class Methods
RLPy.RKey.__init__(self, args )
The copy constructor of the class. Initialize a new RKey object with the values from another RKey object.
Parameters
- kRhs[IN] The source RKey object - RLPy.RKey
1 # No example
RLPy.RKey.Clone(self)
Clone object. Supports cloning, which creates a new instance of a class with the same value as an existing instance.
1 # No example
RLPy.RKey.GetTime(self)
Get Time of the key.
Returns
Time of the key - RLPy.RLTime
1 # No example
RLPy.RKey.GetTransitionType(self)
Get transition type of the key.
Returns
Transition type of the key - RLPy.ETransitionType
- RLPy.ETransitionType_Invalid Invalid value.
- RLPy.ETransitionType_None None.
- RLPy.ETransitionType_Linear Linear.
- RLPy.ETransitionType_Step Step.
- RLPy.ETransitionType_Ease_Out Ease out.
- RLPy.ETransitionType_Ease_In Ease in.
- RLPy.ETransitionType_Ease_Out_In Ease out in.
- RLPy.ETransitionType_Ease_In_Out Ease in out.
- RLPy.ETransitionType_Ease_In_Sine Ease in sine.
- RLPy.ETransitionType_Ease_Out_Sine Ease out sine.
- RLPy.ETransitionType_Ease_In_Out_Sine Ease in out sine.
- RLPy.ETransitionType_Ease_In_Quad Ease in quad.
- RLPy.ETransitionType_Ease_Out_Quad Ease out quad.
- RLPy.ETransitionType_Ease_In_Out_Quad Ease in out quad.
- RLPy.ETransitionType_Ease_In_Cubic Ease in cubic.
- RLPy.ETransitionType_Ease_Out_Cubic Ease in out cubic.
- RLPy.ETransitionType_Ease_In_Out_Cubic Ease in out cubic.
- RLPy.ETransitionType_Ease_In_Quart Ease in quart.
- RLPy.ETransitionType_Ease_Out_Quart Ease out quart.
- RLPy.ETransitionType_Ease_In_Out_Quart Ease in out quart.
- RLPy.ETransitionType_Ease_In_Quint Ease in quint.
- RLPy.ETransitionType_Ease_Out_Quint Ease out quint.
- RLPy.ETransitionType_Ease_In_Out_Quint Ease in out quint.
- RLPy.ETransitionType_Ease_In_Expo Ease in expo.
- RLPy.ETransitionType_Ease_Out_Expo Ease out expo.
- RLPy.ETransitionType_Ease_In_Out_Expo Ease in out expo.
- RLPy.ETransitionType_Ease_In_Circ Ease in circ.
- RLPy.ETransitionType_Ease_Out_Circ Ease out circ.
- RLPy.ETransitionType_Ease_In_Out_Circ Ease in out circ.
- RLPy.ETransitionType_Ease_In_Back Ease in back.
- RLPy.ETransitionType_Ease_Out_Back Ease out back.
- RLPy.ETransitionType_Ease_In_Out_Back Ease in out back.
- RLPy.ETransitionType_Ease_In_Elastic Ease in elastic.
- RLPy.ETransitionType_Ease_Out_Elastic Ease out elastic.
- RLPy.ETransitionType_Ease_In_Out_Elastic Ease in out elastic.
- RLPy.ETransitionType_Ease_In_Bounce Ease in bounce.
- RLPy.ETransitionType_Ease_Out_Bounce Ease out bounce.
- RLPy.ETransitionType_Ease_In_Out_Bounce Ease in out bounce.
- RLPy.ETransitionType_Last Last.
- RLPy.ETransitionType_Count
1 # No example
RLPy.RKey.SetTime(self, kTick )
Set time of the key.
Parameters
- kTime[IN] Time of the key.
1 key = RLPy.RTransformKey()
2 key.SetTime(RLPy.RTime(0))
RLPy.RKey.SetTransitionStrength(self, fTransitionStrength )
Set transition strength of the key.
Parameters
- fTransitionStrength[IN] Transition strength of the key - float
2 key.SetTransitionStrength(90)
RLPy.RKey.SetTransitionType(self, eTransitionType )
Set transition type of the key.
Parameters
- eTransitionType[IN] Transition type of the key - RLPy.ETransitionType
2 key.SetTransitionType(RLPy.ETransitionType_Ease_Out)
Description
Keyframes are used to record transition points in an animation. Keyframe values are called "keys". These keys mainly record time and transition data and are managed by controls which are responsible for changing and deleting key values. This box object's PositionX animation is controlled by [[IC_Python_API:RLPy_RFloatControl|RFloatControl. Thus, this object's timeline transitions are recorded in RFloatKey]] See also: RFloatControl, RTransformControl.
__init__ (self, *args)
Create a new RKey object using an existing RKey object.
Parameters
- args
Member Functions
Clone (self)
Copy this key's data and return a new RKey object.
GetTime (self)
Get this key's time value.
GetTransitionStrength (self)
Get this key's transition strength. This value lies between 1 and 100 (default: 50). This function will only take effect when the transition type for this key is ETransitionType_EASE_OUT, ETransitionType_EASE_IN, ETransitionType_EASE_OUT_IN or ETransitionType_EASE_IN_OUT. See Also: SetTransitionStrength
GetTransitionType (self)
Get this key's transition type. See Also: SetTransitionType
SetTime (self, kTick)
Set the time value for this key.
Parameters
- kTick
SetTransitionStrength (self, fTransitionStrength)
Set the key's transition strength from 1 to 100 (default: 50). This function will only take effect when the transition type for this key is ETransitionType_EASE_OUT, ETransitionType_EASE_IN, ETransitionType_EASE_OUT_IN or ETransitionType_EASE_IN_OUT. See Also: GetTransitionStrength, RLPy.ETransitionType
Parameters
SetTransitionType (self, eTransitionType)
Set the key's transition type.
Parameters
- eTransitionType
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
