IC8 Python API:RLPy RMath
Contents
- 1 Description
- 2 Public Methods
- 2.1 Abs (a)
- 2.2 ACos (fValue)
- 2.3 AlmostZero ( tValue )
- 2.4 ASin ( fValue )
- 2.5 ATan ( fValue )
- 2.6 ATan2 ( fY, fX )
- 2.7 Bezier3 ( a, b, c, d, t )
- 2.8 Clamp ( tMax, tMin, tValue )
- 2.9 CopySign ( fValue )
- 2.10 Cos ( fValue )
- 2.11 Equal ( tValue1, tValue2 )
- 2.12 Erf ( fX )
- 2.13 Erfc ( fX )
- 2.14 Exp ( fValue )
- 2.15 FAbs ( fValue )
- 2.16 FastCos0 ( fAngle )
- 2.17 FastCos1 ( fAngle )
- 2.18 FastInvCos ( fValue )
- 2.19 FastInvSin ( fValue )
- 2.20 FastInvSqrt_Walsh ( tValue )
- 2.21 FastInvTan0 ( fValue )
- 2.22 FastInvTan1 ( fValue )
- 2.23 FastSin0 ( fAngle )
- 2.24 FastSin1 ( fAngle )
- 2.25 FastSqrt_LogBase2 ( tValue )
- 2.26 FastSqrt_Walsh ( tValue )
- 2.27 FastTan0 ( fAngle )
- 2.28 FastTan1 ( fAngle )
- 2.29 FMod ( fX, fY )
- 2.30 Gamma ( fX )
- 2.31 IncompleteGamma ( fA, fX )
- 2.32 IntervalRandom ( args )
- 2.33 InvSqrt ( fValue )
- 2.34 Log ( fValue )
- 2.35 LogGamma ( fX )
- 2.36 Max ( a, b )
- 2.37 Min ( a, b )
- 2.38 ModBessel0 ( fX )
- 2.39 ModBessel1 ( fX )
- 2.40 Pow ( fBase, fExponent )
- 2.41 Round ( tValue )
- 2.42 RoundAlmostZero ( tValue )
- 2.43 RoundEpsilonZero ( tValue )
- 2.44 Sign ( fValue )
- 2.45 Sin ( fValue )
- 2.46 Sqr ( fValue )
- 2.47 Sqrt ( fValue )
- 2.48 SymmetricRandom ( args )
- 2.49 Tan ( fValue )
- 2.50 UnitRandom ( args )
- 3 Description
- 4 Constructor & Destructor
- 5 Member Functions
- 5.1 ACos (fValue)
- 5.2 ASin (fValue)
- 5.3 ATan (fValue)
- 5.4 ATan2 (fY, fX)
- 5.5 Abs (a)
- 5.6 AlmostZero (*args)
- 5.7 Bezier3 (a, b, c, d, t)
- 5.8 Clamp (tMax, tMin, tValue)
- 5.9 CopySign (fValue)
- 5.10 Cos (fValue)
- 5.11 Equal (*args)
- 5.12 Erf (fX)
- 5.13 Erfc (fX)
- 5.14 Exp (fValue)
- 5.15 FAbs (fValue)
- 5.16 FMod (fX, fY)
- 5.17 FastCos0 (fAngle)
- 5.18 FastCos1 (fAngle)
- 5.19 FastInvCos (fValue)
- 5.20 FastInvSin (fValue)
- 5.21 FastInvSqrt_Walsh (tValue)
- 5.22 FastInvTan0 (fValue)
- 5.23 FastInvTan1 (fValue)
- 5.24 FastSin0 (fAngle)
- 5.25 FastSin1 (fAngle)
- 5.26 FastSqrt_LogBase2 (tValue)
- 5.27 FastSqrt_Walsh (tValue)
- 5.28 FastTan0 (fAngle)
- 5.29 FastTan1 (fAngle)
- 5.30 Gamma (fX)
- 5.31 IncompleteGamma (fA, fX)
- 5.32 IntervalRandom (*args)
- 5.33 InvSqrt (fValue)
- 5.34 Log (fValue)
- 5.35 LogGamma (fX)
- 5.36 Max (a, b)
- 5.37 Min (a, b)
- 5.38 ModBessel0 (fX)
- 5.39 ModBessel1 (fX)
- 5.40 Pow (fBase, fExponent)
- 5.41 Round (tValue)
- 5.42 RoundAlmostZero (tValue)
- 5.43 RoundEpsilonZero (tValue)
- 5.44 Sign (fValue)
- 5.45 Sin (fValue)
- 5.46 Sqr (fValue)
- 5.47 Sqrt (fValue)
- 5.48 SymmetricRandom (*args)
- 5.49 Tan (fValue)
- 5.50 UnitRandom (*args)
- 6 Properties
- 7 Constants
- Main article: IC8 Modules.
- Last modified: 10/21/2026
Description
This class provides functions related to mathematics, including functions of trigonometric functions, exponents, logarithms, numerical ccomparisons, creation of random values, etc. It also provides some constant variables that can be referenced directly:
| Constant | Description |
| RMath.CONST_ALMOST_ZERO | Same as AlmostZero, used to determine whether the value is close to 0. |
| RMath.CONST_EPSILON | Used to determine if a value is close to epsilon 0. |
| RMath.CONST_MAX_T | Maximum allowable floating-point value. |
| RMath.CONST_MIN_T | Minimum allowable floating-point value. |
| RMath.CONST_PI | Value of pi: pi. |
| RMath.CONST_TWO_PI | Value of pi times two: 2pi. |
| RMath.CONST_HALF_PI | Value of pi divided by 2: pi/2. |
| RMath.CONST_INV_PI | 1 divided by the value of pi: 1/pi. |
| RMath.CONST_INV_TWO_PI | Inverse of 2 times the value of pi: 1/2pi. |
| RMath.CONST_DEG_TO_RAD | Conversion of 1 degree to radians. |
| RMath.CONST_RAD_TO_DEG | Conversion of 1 radian to degrees |
| RMath.CONST_SQRT_HALF | 1 divided by the square root of 2: 1/sqrt(2). |
| RMath.CONST_MM_TO_INCH | Conversion of 1 millimeter to inches. |
| RMath.CONST_INCH_TO_MM | Conversion of 1 inch to millimeters. |
Public Methods
Abs (a)
Computes the absolute number of a value.
Parameters
- a [IN] Floating-point value - float
Returns
- Absolute value of a - float
1 print( RLPy.RMath.Abs( -10 ) ) # 10
ACos (fValue)
Computes the arc-cosine of a value.
Parameters
- fValue [IN] Floating-point value - float
Returns
- Arc-cosine of fValue in radians - float [0,pi]
1 print( RLPy.RMath.ACos( 0.9 ) ) # 0.4510268568992615
Checks if a value is almost zero.
Parameters
- tValue [IN] Floating-point value - float
Returns
- True if the value is almost zero, else False - bool
1 print( RLPy.RMath.AlmostZero( 0.1 ) ) # False
2 print( RLPy.RMath.AlmostZero( 0.000000000000001 ) ) # True
ASin ( fValue )
Computes the arc-sine of a value.
Parameters
Returns
- Arc-sine of fValue in radians - float [-pi/2,pi/2]
1 print( RLPy.RMath.ASin( 0.9 ) ) # 1.1197694540023804
ATan ( fValue )
Computes the arc-tangent of a value.
Parameters
Returns
- Arc-cosine of fValue in radians - float [-pi/2,pi/2]
1 print( RLPy.RMath.ATan( 0.9 ) ) # 0.7328150868415833
ATan2 ( fY, fX )
Computes the arc-tangent of y/x using the signs of arguments to determine the correct quadrant.
Parameters
- fY [IN] Floating-point value - float
- fX [IN] Floating-point value - float
Returns
- The arc-tangent of fY and fX in radians - float [-pi,pi]
1 print( RLPy.RMath.ATan2( -7.0, 7.0 ) ) # -0.7853981852531433
Computes an interpolated value on a cubic bezier curve with 4 control points.
Parameters
- a [IN] 1st control point value - float
- b [IN] 2nd control point value - float
- c [IN] 3rd control point value - float
- d [IN] 4th control point value - float
- t [IN] Point along the curve - float [0,1]
Returns
- An interpolated value from the bezier curve - float
1 print( RLPy.RMath.Bezier3( 0.0,0.5,3.0,4.0,0.0 ) ) # 0.0
2 print( RLPy.RMath.Bezier3( 0.0,0.5,3.0,4.0,0.5 ) ) # 1.8125
3 print( RLPy.RMath.Bezier3( 0.0,0.5,3.0,4.0,1.0 ) ) # 4.0
Float result between a min and max values.
Parameters
- tMax [IN] Maximum possible value - float
- tMin [IN] Minimum possible value - float
- tValue [IN] Floating-point value to restrict inside the min-to-max range - float
Returns
- Float result between tMax and tMin - float [min,max]
1 print( RLPy.RMath.Clamp( 0.0, 255.0, 300.0 ) ) # 255.0
CopySign ( fValue )
Copies the sign of a floating-point value.
Parameters
Returns
- Return -1 if the input is negative, else 1 - float {-1,1}
1 print( RLPy.RMath.CopySign( 9.0 ) ) # 1.0
2 print( RLPy.RMath.CopySign( 0.0 ) ) # 1.0
3 print( RLPy.RMath.CopySign( -9.0 ) ) # -1.0
Cos ( fValue )
Computes the cosine of a value.
Parameters
- fValue [IN] Angle in radians - float
Returns
- Cosine of fValue - float [-1,1]
1 print( RLPy.RMath.Cos( RLPy.RMath.CONST_PI ) ) # -1.0
Check if 2 values are equal or not.
Parameters
- tValue1 [IN] Floating-point value - float
- tValue2 [IN] Floating-point value - float
Returns
- Return True if TValue1 and TValue2 are almost Equal, else False - bool
1 print( RLPy.RMath.Equal( 0.0000001, 0.0000002 ) ) # True
Erf ( fX )
Computes the polynomial approximation of a value.
Parameters
Returns
- Polynomial approximation of fX - float
1 print( RLPy.RMath.Erf( 0.9 ) ) # 0.7960618138313293
Erfc ( fX )
Computes 1-erf(x)
Parameters
Returns
- Erfc(x) = 1-erf(x) - float
1 print( RLPy.RMath.Erf( 0.9 ) ) # 0.20393820106983185
Exp ( fValue )
Returns e raised to a given power (ex)
Parameters
Returns
- The base-e exponential of arg is returned - float
1 print( RLPy.RMath.Exp( 2.0 ) ) # 7.389056205749512
FAbs ( fValue )
Absolute value of a floating-point value.
Parameters
Returns
- The absolute value of arg - float
1 print( RLPy.RMath.FAbs( -2.0 ) ) # 2.0
FastCos0 ( fAngle )
Fast evaluation of cos(angle) by polynomial approximations.
Parameters
- fAngle [IN] Angle in radians - float [0,pi/2]
Returns
- The sine of arg in the range of -1 and 1, is returned. The maximum absolute error is about 1.2e-03. This operation is about 2x faster than Cos - float
1 print( RLPy.RMath.Cos( 1.0 ) ) # 0.5403022766113281
2 print( RLPy.RMath.FastCos0( 1.0 ) ) # 0.5403500199317932
FastCos1 ( fAngle )
Parameters
Returns
- The sine of arg in the range of 1 and -1, is returned. The maximum absolute error is about 2.3e-09. This operation is about 1.5x faster than Cos - float
2 print( RLPy.RMath.FastCos1( 1.0 ) ) # 0.5403022766113281
Fast evaluation of acos(value) by a sqrt times a polynomial.
Parameters
- fValue [IN] Floating-point value - float [0,1]
Returns
- The sine of arg is returned. The maximum absolute error is about 6.8e-05. The speed up is about 2.5 - float
2 print( RLPy.RMath.FastInvCos( 0.9 ) ) # 0.45104315876960754
Fast evaluation of asin(value) by a sqrt times a polynomial.
Parameters
Returns
2 print( RLPy.RMath.FastInvSin( 0.9 ) ) # 1.1197532415390015
A fast approximation to 1/sqrt using The Quake 3 Walsh Method.
Parameters
Returns
- The inverse of square root - float
1 print( RLPy.RMath.InvSqrt( 0.9 ) ) # 1.054092526435852
2 print( RLPy.RMath.FastInvSqrt_Walsh( 0.9 ) ) # 1.053429365158081
Fast evaluation of atan(value) by polynomial approximations.
Parameters
- fValue [IN] Floating-point value - float [-1,1]
Returns
- The atan of arg is returned. The maximum absolute error is about 1.2e-05. The speed up is about 2.2 - float
2 print( RLPy.RMath.FastInvTan0( 0.9 ) ) # 0.7328156232833862
Parameters
Returns
- The atan of arg is returned. The maximum absolute error is about 1.43-08. The speed up is about 1.5 - float
2 print( RLPy.RMath.FastInvTan1( 0.9 ) ) # 0.7328150868415833
FastSin0 ( fAngle )
Fast evaluation of sin(angle) by polynomial approximations.
Parameters
Returns
- The sine of fAngle. The maximum absolute error is about 1.7e-04. This operation is about 2x faster than Sin - float [-1,1]
1 print( RLPy.RMath.Sin( 0.9 ) ) # 0.7833269238471985
2 print( RLPy.RMath.FastSin0( 0.9 ) ) # 0.7834432125091553
FastSin1 ( fAngle )
Parameters
Returns
- The sine of arg in the range of -1 and 1, is returned. The maximum absolute error is about 2.3e-09. This operation is about 1.5x faster than Sin - float
2 print( RLPy.RMath.FastSin1( 0.9 ) ) # 0.7833268642425537
A fast approximation of Sqrt that is about 5x faster with slight errors.
Parameters
Returns
- The value of square root - float
1 print( RLPy.RMath.Sqrt( 0.9 ) ) # 0.9486832618713379
2 print( RLPy.RMath.FastSqrt_LogBase2( 0.9 ) ) # 0.949999988079071
A fast approximation to Sqrt using The Quake 3 Walsh method that is about 2x faster.
Parameters
Returns
2 print( RLPy.RMath.FastSqrt_Walsh( 0.9 ) ) # 0.9480863809585571
FastTan0 ( fAngle )
Fast evaluation of tan(angle) by polynomial approximations.
Parameters
- fAngle [IN] Angle in radians - float [0,pi/4]
Returns
- Tangent of fAngle. The maximum absolute error is about 8.1e-04. It is about 2.5x faster than Tan - float
1 print( RLPy.RMath.Tan( 0.9 ) ) # 1.2601581811904907
2 print( RLPy.RMath.FastTan0( 0.9 ) ) # 1.2515404224395752
FastTan1 ( fAngle )
Parameters
Returns
- The tangent of arg is returned. The maximum absolute error is about 1.9e-08. It is about 1.75x faster than Tan - float
2 print( RLPy.RMath.FastTan1( 0.9 ) ) # 1.2601404190063477
FMod ( fX, fY )
Remainder of the floating-point division operation.
Parameters
Returns
- The floating-point remainder of the division x/y as defined above - float
1 print( RLPy.RMath.FMod( 5, 3 ) ) # 2.0
Gamma ( fX )
Computes the gamma of a value.
Parameters
Returns
- The value of gamma - float
1 print( RLPy.RMath.Gamma( 0.9 ) ) # 1.0686286687850952
Computes incomplete gamma.
Parameters
- fA [IN] Floating-point value - float
Returns
1 print( RLPy.RMath.IncompleteGamma( 0.1, 0.9 ) ) # 0.9716073274612427
Generate a random number between a min and max value.
Parameters
- fMin [IN] Minimum value - float
- fSeed [IN] maximum value - float
- fSeed [IN] Seeded value - float
Returns
- The random number generator may be seeded by a first call to IntervalRandom with a positive seed - float
1 print( RLPy.RMath.IntervalRandom(0.0,255.0,5.0) ) # 0.4202398657798767
2 print( RLPy.RMath.IntervalRandom(0.0,255.0) ) # 223.2952423095703
InvSqrt ( fValue )
Computes inverse of square root (1/sqrt)
Parameters
Returns
Log ( fValue )
Computes natural (base e) logarithm.
Parameters
Returns
- The natural (base-e) logarithm of arg is returned - float
1 print( RLPy.RMath.Log( 5.5 ) ) # 1.7047480344772339
LogGamma ( fX )
Computes log gamma.
Parameters
Returns
- The value of log gamma - float
1 print( RLPy.RMath.LogGamma( 5.5 ) ) # 3.9578146934509277
Max ( a, b )
Larger of two floating-point values.
Parameters
- b [IN] Floating-point value - float
Returns
- The larger of two floating-point values - float
1 print( RLPy.RMath.Max( 8.0, 9.0 ) ) # 9.0
Min ( a, b )
Smaller of two floating-point values.
Parameters
Returns
- The smaller of two floating-point values - float
1 print( RLPy.RMath.Min( 8.0, 9.0 ) ) # 8.0
ModBessel0 ( fX )
Modified Bessel functions of order 0.
Parameters
Returns
- The value of modified bessel - float
1 print( RLPy.RMath.ModBessel0( 5.5 ) ) # 42.694644927978516
ModBessel1 ( fX )
Modified Bessel functions of order 1.
Parameters
Returns
1 print( RLPy.RMath.ModBessel1( 5.5 ) ) # 38.588165283203125
Raises a number to the given power.
Parameters
- fBase [IN] Base as a value of floating-point - float
- fExponent [IN] Exponent as a value of floating-point - float
Returns
- Base raised to the power of exp - float
1 print( RLPy.RMath.Pow( 2.0, 5.0 ) ) # 32.0
Round ( tValue )
Nearest floating-point.
Parameters
Returns
- The nearest flaoting value to arg - float
1 print( RLPy.RMath.Round( 8.49 ) ) # 8.989999771118164
2 print( RLPy.RMath.Round( 8.5 ) ) # 9.0
3 print( RLPy.RMath.Round( 8.52 ) ) # 9.020000457763672
Round Almost Zero.
Parameters
- tValue1 [IN] Floating-point value.
Returns
- Return RoundAlmostZero - float
1 print( RLPy.RMath.RoundAlmostZero( 0.0000001 ) ) # 0.0
Round Epsilon Zero.
Parameters
Returns
- Return RoundEpsilonZero - float
1 print( RLPy.RMath.RoundEpsilonZero( 0.0000001 ) ) # 0.0
Sign ( fValue )
Sign of a value. If the value is greater than 0, return 1; If the value is equal to 0, return 0; If the value is less than 0, return -1;
Parameters
Returns
- Return -1 if the input is negative, 0 if the input is zero, and 1 if the input is positive - float {-1,0,1}
1 print( RLPy.RMath.Sign( 9.0 ) ) # 1.0
2 print( RLPy.RMath.Sign( 0.0 ) ) # 0.0
3 print( RLPy.RMath.Sign( -9.0 ) ) # -1.0
Sin ( fValue )
Computes the sine of a value.
Parameters
Returns
- The sine of arg - float [-1,1]
Sqr ( fValue )
Computes square.
Parameters
Returns
- Square of arg, fValue * fValue - float
1 print( RLPy.RMath.Sqr( 0.9 ) ) # 0.809999942779541
Sqrt ( fValue )
Computes square root.
Parameters
Returns
- Square root of arg - float
Generate a random number between -1 and 1. The random number generator may be seeded by a first call to SymmetricRandom with a positive seed.
Parameters
Returns
- Random value - float [-1,1]
1 print( RLPy.RMath.SymmetricRandom( 5.0 ) ) # -0.9967039823532104
2 print( RLPy.RMath.SymmetricRandom() ) # 0.7513352036476135
Tan ( fValue )
Computes the tangent of a value.
Parameters
Returns
- Tangent of fValue - float
UnitRandom ( args )
Generate a random value between 0 and 1. The random number generator may be seeded by a first call to UnitRandom with a positive seed.
Parameters
Returns
- Random value - float [0,1]
1 print( RLPy.RMath.UnitRandom( 5.0 ) ) # 0.0016479995101690292
2 print( RLPy.RMath.UnitRandom() ) # 0.8756675720214844
Description
This class provides functions related to mathematics, including functions of trigonometric functions, exponents, logarithms, numerical ccomparisons, creation of random values, etc. It also provides some constant variables that can be referenced directly: {|class="wikitable" !Constant !Description |- |RMath.CONST_ALMOST_ZERO |Same as AlmostZero, used to determine whether the value is close to 0. |- |RMath.CONST_EPSILON |Used to determine if a value is close to epsilon 0. |- |RMath.CONST_MAX_T |Maximum allowable floating-point value. |- |RMath.CONST_MIN_T |Minimum allowable floating-point value. |- |RMath.CONST_PI |Value of pi: pi. |- |RMath.CONST_TWO_PI |Value of pi times two: 2pi. |- |RMath.CONST_HALF_PI |Value of pi divided by 2: pi/2. |- |RMath.CONST_INV_PI |1 divided by the value of pi: 1/pi. |- |RMath.CONST_INV_TWO_PI |Inverse of 2 times the value of pi: 1/2pi. |- |RMath.CONST_DEG_TO_RAD |Conversion of 1 degree to radians. |- |RMath.CONST_RAD_TO_DEG |Conversion of 1 radian to degrees |- |RMath.CONST_SQRT_HALF |1 divided by the square root of 2: 1/sqrt(2). |- |RMath.CONST_MM_TO_INCH |Conversion of 1 millimeter to inches. |- |RMath.CONST_INCH_TO_MM |Conversion of 1 inch to millimeters. |}
__init__ (self)
Initializes a new math instance.
Member Functions
ACos (fValue)
Parameters
- fValue
Sample code
Demonstrates calls to `RLPy.RMath.ACos`, `RLPy.RMath.ASin`, `RLPy.RMath.ATan`, `RLPy.RMath.ATan2`, `RLPy.RMath.Cos`, `RLPy.RMath.Sin`, and `RLPy.RMath.Tan` using the example's inputs.
def run_script():
import RLPy
RLPy.RMath.ACos(0.5)
RLPy.RMath.ASin(0.5)
RLPy.RMath.ATan(0.5)
RLPy.RMath.ATan2(1.0, 1.0)
RLPy.RMath.Cos(0.5)
RLPy.RMath.Sin(0.5)
RLPy.RMath.Tan(0.5)
ASin (fValue)
Parameters
- fValue
Sample code
def run_script():
import RLPy
RLPy.RMath.Cos(0.5)
RLPy.RMath.Sin(0.5)
RLPy.RMath.Tan(0.5)
ATan (fValue)
Parameters
- fValue
Sample code
def run_script():
import RLPy
RLPy.RMath.Cos(0.5)
RLPy.RMath.Sin(0.5)
RLPy.RMath.Tan(0.5)
ATan2 (fY, fX)
Parameters
- fY
- fX
Sample code
def run_script():
import RLPy
RLPy.RMath.Cos(0.5)
RLPy.RMath.Sin(0.5)
RLPy.RMath.Tan(0.5)
Abs (a)
Parameters
- a
Sample code
Demonstrates calls to `RLPy.RMath.Abs`, `RLPy.RMath.AlmostZero`, `RLPy.RMath.Clamp`, `RLPy.RMath.Equal`, `RLPy.RMath.FAbs`, `RLPy.RMath.Max`, `RLPy.RMath.Min`, `RLPy.RMath.Round`, `RLPy.RMath.RoundAlmostZero`, `RLPy.RMath.RoundEpsilonZero`, and `RLPy.RMath.Sign` using the example's inputs.
def run_script():
import RLPy
RLPy.RMath()
RLPy.RMath.Abs(-1.25)
RLPy.RMath.FAbs(-0.5)
RLPy.RMath.Sign(0.5)
RLPy.RMath.Min(1.0, 2.0)
RLPy.RMath.Max(1.0, 2.0)
RLPy.RMath.Clamp(1.0, 0.0, 0.5)
RLPy.RMath.AlmostZero(0.0)
RLPy.RMath.Equal(0.5, 0.5)
RLPy.RMath.Round(0.5)
RLPy.RMath.RoundAlmostZero(0.5)
RLPy.RMath.RoundEpsilonZero(0.5)
AlmostZero (*args)
Parameters
- args
Sample code
def run_script():
import RLPy
RLPy.RMath()
Parameters
- a
- b
- c
- d
- t
Sample code
Demonstrates calls to `RLPy.RMath.Bezier3`, `RLPy.RMath.CopySign`, `RLPy.RMath.Exp`, `RLPy.RMath.FMod`, `RLPy.RMath.FastInvSqrt_Walsh`, `RLPy.RMath.FastSqrt_LogBase2`, `RLPy.RMath.FastSqrt_Walsh`, `RLPy.RMath.InvSqrt`, `RLPy.RMath.Log`, `RLPy.RMath.Pow`, `RLPy.RMath.Sqr`, and `RLPy.RMath.Sqrt` using the example's inputs.
def run_script():
import RLPy
RLPy.RMath.Bezier3(0.0, 1.0, 1.0, 2.0, 0.5)
RLPy.RMath.CopySign(0.5)
RLPy.RMath.Exp(0.5)
RLPy.RMath.FMod(5.5, 2.0)
RLPy.RMath.InvSqrt(4.0)
RLPy.RMath.Log(2.0)
RLPy.RMath.Pow(2.0, 3.0)
RLPy.RMath.Sqr(2.0)
RLPy.RMath.Sqrt(4.0)
RLPy.RMath.FastInvSqrt_Walsh(4.0)
RLPy.RMath.FastSqrt_Walsh(4.0)
RLPy.RMath.FastSqrt_LogBase2(4.0)
Parameters
- tMax
- tMin
- tValue
Sample code
def run_script():
import RLPy
RLPy.RMath()
CopySign (fValue)
Parameters
- fValue
Sample code
def run_script():
import RLPy
RLPy.RMath.Exp(0.5)
RLPy.RMath.Log(2.0)
RLPy.RMath.Sqr(2.0)
Cos (fValue)
Parameters
- fValue
Sample code
def run_script():
import RLPy
RLPy.RMath.Cos(0.5)
RLPy.RMath.Sin(0.5)
RLPy.RMath.Tan(0.5)
Equal (*args)
Parameters
- args
Sample code
def run_script():
import RLPy
RLPy.RMath()
Erf (fX)
Parameters
- fX
Sample code
Demonstrates calls to `RLPy.RMath.Erf`, `RLPy.RMath.Erfc`, `RLPy.RMath.Gamma`, `RLPy.RMath.IncompleteGamma`, `RLPy.RMath.IntervalRandom`, `RLPy.RMath.LogGamma`, `RLPy.RMath.ModBessel0`, `RLPy.RMath.ModBessel1`, `RLPy.RMath.SymmetricRandom`, and `RLPy.RMath.UnitRandom` using the example's inputs.
def run_script():
import RLPy
RLPy.RMath.Erf(0.5)
RLPy.RMath.Erfc(0.5)
RLPy.RMath.Gamma(2.0)
RLPy.RMath.IncompleteGamma(2.0, 1.0)
RLPy.RMath.LogGamma(2.0)
RLPy.RMath.ModBessel0(0.5)
RLPy.RMath.ModBessel1(0.5)
RLPy.RMath.UnitRandom(0.5)
RLPy.RMath.SymmetricRandom(0.5)
RLPy.RMath.IntervalRandom(0.0, 1.0, 0.5)
Erfc (fX)
Computes 1-erf(x)
Parameters
- fX
Sample code
def run_script():
import RLPy
RLPy.RMath.Erf(0.5)
Exp (fValue)
Parameters
- fValue
Sample code
def run_script():
import RLPy
RLPy.RMath.Exp(0.5)
RLPy.RMath.Log(2.0)
RLPy.RMath.Sqr(2.0)
FAbs (fValue)
Parameters
- fValue
Sample code
def run_script():
import RLPy
RLPy.RMath()
FMod (fX, fY)
Parameters
- fX
- fY
Sample code
def run_script():
import RLPy
RLPy.RMath.Exp(0.5)
RLPy.RMath.Log(2.0)
RLPy.RMath.Sqr(2.0)
FastCos0 (fAngle)
Parameters
- fAngle
Sample code
Demonstrates calls to `RLPy.RMath.FastCos0`, `RLPy.RMath.FastCos1`, `RLPy.RMath.FastInvCos`, `RLPy.RMath.FastInvSin`, `RLPy.RMath.FastInvTan0`, `RLPy.RMath.FastInvTan1`, `RLPy.RMath.FastSin0`, `RLPy.RMath.FastSin1`, `RLPy.RMath.FastTan0`, and `RLPy.RMath.FastTan1` using the example's inputs.
def run_script():
import RLPy
RLPy.RMath.FastCos0(0.5)
RLPy.RMath.FastCos1(0.5)
RLPy.RMath.FastSin0(0.5)
RLPy.RMath.FastSin1(0.5)
RLPy.RMath.FastTan0(0.5)
RLPy.RMath.FastTan1(0.5)
RLPy.RMath.FastInvCos(0.5)
RLPy.RMath.FastInvSin(0.5)
RLPy.RMath.FastInvTan0(0.5)
RLPy.RMath.FastInvTan1(0.5)
FastCos1 (fAngle)
Parameters
- fAngle
Sample code
def run_script():
import RLPy
FastInvCos (fValue)
Parameters
- fValue
Sample code
def run_script():
import RLPy
FastInvSin (fValue)
Parameters
- fValue
Sample code
def run_script():
import RLPy
Parameters
- tValue
Sample code
def run_script():
import RLPy
RLPy.RMath.Exp(0.5)
RLPy.RMath.Log(2.0)
RLPy.RMath.Sqr(2.0)
Parameters
- fValue
Sample code
def run_script():
import RLPy
Parameters
- fValue
Sample code
def run_script():
import RLPy
FastSin0 (fAngle)
Parameters
- fAngle
Sample code
def run_script():
import RLPy
FastSin1 (fAngle)
Parameters
- fAngle
Sample code
def run_script():
import RLPy
Parameters
- tValue
Sample code
def run_script():
import RLPy
RLPy.RMath.Exp(0.5)
RLPy.RMath.Log(2.0)
RLPy.RMath.Sqr(2.0)
Parameters
- tValue
Sample code
def run_script():
import RLPy
RLPy.RMath.Exp(0.5)
RLPy.RMath.Log(2.0)
RLPy.RMath.Sqr(2.0)
FastTan0 (fAngle)
Parameters
- fAngle
Sample code
def run_script():
import RLPy
FastTan1 (fAngle)
Parameters
- fAngle
Sample code
def run_script():
import RLPy
Gamma (fX)
Parameters
- fX
Sample code
def run_script():
import RLPy
RLPy.RMath.Erf(0.5)
Parameters
- fA
- fX
Sample code
def run_script():
import RLPy
RLPy.RMath.Erf(0.5)
Parameters
- args
Sample code
def run_script():
import RLPy
RLPy.RMath.Erf(0.5)
InvSqrt (fValue)
Parameters
- fValue
Sample code
def run_script():
import RLPy
RLPy.RMath.Exp(0.5)
RLPy.RMath.Log(2.0)
RLPy.RMath.Sqr(2.0)
Log (fValue)
Parameters
- fValue
Sample code
def run_script():
import RLPy
RLPy.RMath.Exp(0.5)
RLPy.RMath.Log(2.0)
RLPy.RMath.Sqr(2.0)
LogGamma (fX)
Computes log gamma.
Parameters
- fX
Sample code
def run_script():
import RLPy
RLPy.RMath.Erf(0.5)
Max (a, b)
Parameters
- a
- b
Sample code
def run_script():
import RLPy
RLPy.RMath()
Min (a, b)
Parameters
- a
- b
Sample code
def run_script():
import RLPy
RLPy.RMath()
ModBessel0 (fX)
Parameters
- fX
Sample code
def run_script():
import RLPy
RLPy.RMath.Erf(0.5)
ModBessel1 (fX)
Parameters
- fX
Sample code
def run_script():
import RLPy
RLPy.RMath.Erf(0.5)
Parameters
- fBase
- fExponent
Sample code
def run_script():
import RLPy
RLPy.RMath.Exp(0.5)
RLPy.RMath.Log(2.0)
RLPy.RMath.Sqr(2.0)
Round (tValue)
Parameters
- tValue
Sample code
def run_script():
import RLPy
RLPy.RMath()
Round Almost Zero.
Parameters
- tValue
Sample code
def run_script():
import RLPy
RLPy.RMath()
Round Epsilon Zero.
Parameters
- tValue
Sample code
def run_script():
import RLPy
RLPy.RMath()
Sign (fValue)
Parameters
- fValue
Sample code
def run_script():
import RLPy
RLPy.RMath()
Sin (fValue)
Parameters
- fValue
Sample code
def run_script():
import RLPy
RLPy.RMath.Cos(0.5)
RLPy.RMath.Sin(0.5)
RLPy.RMath.Tan(0.5)
Sqr (fValue)
Computes square.
Parameters
- fValue
Sample code
def run_script():
import RLPy
RLPy.RMath.Exp(0.5)
RLPy.RMath.Log(2.0)
RLPy.RMath.Sqr(2.0)
Sqrt (fValue)
Parameters
- fValue
Sample code
def run_script():
import RLPy
RLPy.RMath.Exp(0.5)
RLPy.RMath.Log(2.0)
RLPy.RMath.Sqr(2.0)
Parameters
- args
Sample code
def run_script():
import RLPy
RLPy.RMath.Erf(0.5)
Tan (fValue)
Parameters
- fValue
Sample code
def run_script():
import RLPy
RLPy.RMath.Cos(0.5)
RLPy.RMath.Sin(0.5)
RLPy.RMath.Tan(0.5)
UnitRandom (*args)
Parameters
- args
Sample code
def run_script():
import RLPy
RLPy.RMath.Erf(0.5)
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
