IC8 Python API:RLPy RMatrix3
Contents
- 1 Description
- 2 Constructor & Destructor
- 3 Member Functions
- 3.1 AccuScale (self, rkScale)
- 3.2 Adjoint (self)
- 3.3 AdjointTranspose (self)
- 3.4 Determinant (self)
- 3.5 DiagonalElements (self)
- 3.6 E (self, *args)
- 3.7 FromAxisAngle (self, rkAxis, fAngle)
- 3.8 FromEulerAngle (Oreder, rx, ry, rz)
- 3.9 FromSpereUnitVec (self, rkVec)
- 3.10 GetColumn (self, nCol)
- 3.11 GetRow (self, nRow)
- 3.12 InfNorm (self)
- 3.13 Inverse (self)
- 3.14 InverseTranspose (self)
- 3.15 IsRightHandCoordinate (self)
- 3.16 M (self, *args)
- 3.17 MakeIdentity (self)
- 3.18 MaxColumn (self)
- 3.19 MaxRow (self)
- 3.20 OneNorm (self)
- 3.21 RotationX (self, fAngle)
- 3.22 RotationY (self, fAngle)
- 3.23 RotationZ (self, fAngle)
- 3.24 TimesTranspose (self, mM)
- 3.25 ToEulerAngle (self, *args)
- 3.26 Transpose (self)
- 3.27 TransposeTimes (self, mM)
- 3.28 __add__ (self, mM)
- 3.29 __eq__ (self, mM)
- 3.30 __ge__ (self, mM)
- 3.31 __gt__ (self, mM)
- 3.32 __iadd__ (self, mM)
- 3.33 __imul__ (self, *args)
- 3.34 __isub__ (self, mM)
- 3.35 __itruediv__ (self, *args)
- 3.36 __le__ (self, mM)
- 3.37 __lt__ (self, mM)
- 3.38 __mul__ (self, *args)
- 3.39 __ne__ (self, mM)
- 3.40 __neg__ (self)
- 3.41 __sub__ (self, mM)
- 3.42 __truediv__ (self, *args)
- 4 Properties
- 5 Constants
Description
This class represent a standard 3x3 matrix. This class provides access to RLPy's internal 3x3 matrix operators and related functions. iClone uses row-major order where consecutive elements of a row reside next to each other, and the data is read from left to right, top to bottom, in a vertical zig-zag: [0, 1, 2] [3, 4, 5] [6, 7, 8]
__init__ (self, *args)
The constructor. Initialize a new 3x3 matrix with another RMatrix3 object.
Parameters
- args
Member Functions
Accumulate 3x3 matrix with scale vector.
Parameters
- rkScale
Adjoint (self)
Adjugate this 3x3 matrix.
Sample code
Calls `RLPy.RMatrix3.Adjoint` with the inputs shown in the example.
def run_script():
import RLPy
matrix3_value = RLPy.RMatrix3( 1, 2, 3,
2, 3, 4,
4, 2, 1 )
matrix3_Adjoint = matrix3_value.Adjoint()
row0 = matrix3_Adjoint.GetRow(0)
print(row0[0])
print(row0[1])
print(row0[2])
Adjugate and transpose this 3x3 matrix.
Sample code
Calls `RLPy.RMatrix3.AdjointTranspose` with the inputs shown in the example.
def run_script():
import RLPy
2, 3, 4,
4, 2, 1 )
matrix3_Adjoint_transpose = matrix3_value.AdjointTranspose()
col0_Adjoint_transpose = matrix3_Adjoint_transpose.GetColumn(0)
print(col0_Adjoint_transpose[0])
print(col0_Adjoint_transpose[1])
print(col0_Adjoint_transpose[2])
Determinant (self)
Obtain the scalar value for this 3x3 matrix (|A|).
Sample code
Calls `RLPy.RMatrix3.Determinant` with the inputs shown in the example.
def run_script():
import RLPy
2, 3, 4,
4, 2, 1 )
print(matrix3_value.Determinant())
Returns the diagonal elements of this matrix.
E (self, *args)
Get the value of an element in a 3x3 matrix by index number (from 0 to 8);
Parameters
- args
Sample code
Calls `RLPy.RMatrix3.E` with the inputs shown in the example.
def run_script():
import RLPy
matrix3 = RLPy.RMatrix3()
matrix3.MakeIdentity()
print(matrix3.E(0)) #
Rotation matrix from axis angle.
Parameters
- rkAxis
- fAngle
Convert Euler angle to a 3x3 matrix according to a rotation axis order.
Parameters
- Oreder
- rx
- ry
- rz
Creates a rotation matrix that aligns the z-axis with the supplied direction; a near-zero vector produces the identity matrix.
Parameters
- rkVec
Retreive a column inside a 3x3 matrix.
Parameters
- nCol
Sample code
Calls `RLPy.RMatrix3.TimesTranspose` with the inputs shown in the example.
def run_script():
import RLPy
matrix3_orgin = RLPy.RMatrix3( 1, 2, 3,
4, 5, 6,
7, 8, 9 )
matrix3_transpose_value = RLPy.RMatrix3( 3, 0, 0,
0, 3, 0,
0, 0, 3 )
matrix3_times_transpose = matrix3_orgin.TimesTranspose(matrix3_transpose_value)
row0 = matrix3_orgin.GetColumn(0)
col0 = matrix3_times_transpose.GetColumn(0)
print(row0[0]*3 == col0[0])
print(row0[1]*3 == col0[1])
print(row0[2]*3 == col0[2])
Sample code
Calls `RLPy.RMatrix3.GetColumn` with the inputs shown in the example.
def run_script():
import RLPy
col0 = matrix3.GetColumn(0)
print(col0[0])
print(col0[1])
print(col0[2])
GetRow (self, nRow)
Retreive a row inside a 3x3 matrix.
Parameters
- nRow
Sample code
Calls `RLPy.RMatrix3.Transpose` with the inputs shown in the example.
def run_script():
import RLPy
4, 5, 6,
7, 8, 9 )
matrix3_transpose = matrix3_orgin.Transpose()
row0 = matrix3_orgin.GetRow(0)
col0 = matrix3_transpose.GetColumn(0)
print(row0[0] == col0[0])
print(row0[1] == col0[1])
print(row0[2] == col0[2])
Sample code
Calls `RLPy.RMatrix3.TransposeTimes` with the inputs shown in the example.
def run_script():
import RLPy
4, 5, 6,
7, 8, 9 )
matrix3_transpose_value = RLPy.RMatrix3( 2, 0, 0,
0, 2, 0,
0, 0, 2 )
matrix3_transpose_times = matrix3_orgin.TransposeTimes(matrix3_transpose_value)
col0 = matrix3_transpose_times.GetColumn(0)
print(row0[0]*2 == col0[0])
print(row0[1]*2 == col0[1])
print(row0[2]*2 == col0[2])
Sample code
Calls `RLPy.RMatrix3.GetRow` with the inputs shown in the example.
def run_script():
import RLPy
row0 = matrix3.GetRow(0)
print(row0[0])
print(row0[1])
print(row0[2])
InfNorm (self)
Return the sum of the row elements that contain the largest absolute values.
Sample code
Calls `RLPy.RMatrix3.InfNorm` with the inputs shown in the example.
def run_script():
import RLPy
matrix3_column_value = RLPy.RMatrix3( 10, 20, -30,
0, 0, 0,
0, 0, 0 )
print(matrix3_column_value.InfNorm()) # 10+20+abs(-30) = 60
Inverse (self)
Obtain the inverse (reciprocal) of this 3x3 matrix (A^-1).
Sample code
Calls `RLPy.RMatrix3.Inverse` with the inputs shown in the example.
def run_script():
import RLPy
2, 3, 4,
4, 2, 1 )
matrix3_inverse = matrix3_value.Inverse()
row0 = matrix3_inverse.GetRow(0)
print(row0[0])
print(row0[1])
print(row0[2])
Invert and transpose this 3x3 matrix.
Sample code
Calls `RLPy.RMatrix3.InverseTranspose` with the inputs shown in the example.
def run_script():
import RLPy
2, 3, 4,
4, 2, 1 )
matrix3_inverse_transpose = matrix3_value.InverseTranspose()
row0_inverse_transpose = matrix3_inverse_transpose.GetRow(0)
print(row0_inverse_transpose[0])
print(row0_inverse_transpose[1])
print(row0_inverse_transpose[2])
Obtain this 3x3 matrix's coordinate system. True stands for right-handed coordinate system while False for left-handed.
Sample code
Calls `RLPy.RMatrix3.IsRightHandCoordinate` with the inputs shown in the example.
def run_script():
import RLPy
matrix3_value = RLPy.RMatrix3( 1, 0, 0,
0, 1, 0,
0, 0, 1 )
result = matrix3_value.IsRightHandCoordinate()
print(result)
M (self, *args)
Get the value of an element in a 3x3 matrix by row and column index.
Parameters
- args
Sample code
Calls `RLPy.RMatrix3.M` with the inputs shown in the example.
def run_script():
import RLPy
print(matrix3.M(0,0)) # <Swig Object of type 'float *' at 0x0000020316B015A0>
MakeIdentity (self)
This function can be used to initialize the 3x3 matrix. It is equivalent to setting the matrix to: [1 0 0] [0 1 0] [0 0 1]
Sample code
def run_script():
import RLPy
Sample code
def run_script():
import RLPy
print(row0[0])
print(row0[1])
print(row0[2])
Sample code
Calls `RLPy.RMatrix3.MakeIdentity` with the inputs shown in the example.
def run_script():
import RLPy
Sample code
def run_script():
import RLPy
Sample code
def run_script():
import RLPy
print(col0[0])
print(col0[1])
print(col0[2])
MaxColumn (self)
Find the maximum absolute value within this 3x3 matrix, and return the column in which the value is located. If all of the elements within the 3x3 matrix are 0 then return -1.
Sample code
Calls `RLPy.RMatrix3.MaxColumn` with the inputs shown in the example.
def run_script():
import RLPy
matrix3_value = RLPy.RMatrix3( 10, 20, -30,
0, 0, 0,
0, 0, 0 )
print(matrix3_value.MaxColumn()) # column:2 ->abs(-30)
MaxRow (self)
Find the maximum absolute value within this 3x3 matrix, and return the row in which the value is located. If all of the elements within the 3x3 matrix are 0 then return -1.
Sample code
Calls `RLPy.RMatrix3.MaxRow` with the inputs shown in the example.
def run_script():
import RLPy
matrix3_value = RLPy.RMatrix3( 10, 0, 0,
20, 0, 0,
-30, 0, 0 )
print(matrix3_value.MaxRow()) # Row:2 ->abs(-30)
OneNorm (self)
Return the sum of the column elements that contain the largest absolute values.
Sample code
Calls `RLPy.RMatrix3.OneNorm` with the inputs shown in the example.
def run_script():
import RLPy
matrix3_row_value = RLPy.RMatrix3( 10, 0, 0,
20, 0, 0,
-30, 0, 0 )
print(matrix3_row_value.OneNorm()) # 10+20+abs(-30) = 60
Rotate this 3x3 matrix around the x-axis.
Parameters
- fAngle
Rotate this 3x3 matrix around the y-axis.
Parameters
- fAngle
Rotation this 3x3 matrix around the z-axis.
Parameters
- fAngle
Multiply this 3x3 matrix with a transposed version of itself.
Parameters
- mM
Sample code
def run_script():
import RLPy
4, 5, 6,
7, 8, 9 )
0, 3, 0,
0, 0, 3 )
Convert 3x3 matrix to Euler angles.
Parameters
- args
Transpose (self)
Obtain the transposed matrix by transposing the current m * n matrix into an n * m matrix by row-column swapping.
Sample code
def run_script():
import RLPy
4, 5, 6,
7, 8, 9 )
Multiply a transposed version of a 3x3 matrix with itself.
Parameters
- mM
Sample code
def run_script():
import RLPy
4, 5, 6,
7, 8, 9 )
0, 2, 0,
0, 0, 2 )
__add__ (self, mM)
The "addition" operator. See Also: +=
Parameters
- mM
Sample code
Calls `RLPy.RMatrix3.__add__` with the inputs shown in the example.
def run_script():
import RLPy
matrix3_a = RLPy.RMatrix3( 1, 2, 3,
0, 0, 0,
0, 0, 0 )
matrix3_b = RLPy.RMatrix3( 2, 2, 2,
0, 0, 0,
0, 0, 0 )
matrix3_result = matrix3_a + matrix3_b
print( matrix3_result.GetRow(0)[0] == 1+2 ) # true
print( matrix3_result.GetRow(0)[1] == 2+2 ) # true
print( matrix3_result.GetRow(0)[2] == 3+2 ) # true
__eq__ (self, mM)
The "equal to" operator. Performs a one-by-one comparison of the matrix array. See Also: !=
Parameters
- mM
__ge__ (self, mM)
Reports whether this value is greater than or equal to another value.
Parameters
- mM
__gt__ (self, mM)
Reports whether this value is greater than another value.
Parameters
- mM
__iadd__ (self, mM)
Adds another value to this value in place.
Parameters
- mM
Multiplies this value by another value in place.
Parameters
- args
__isub__ (self, mM)
Subtracts another value from this value in place.
Parameters
- mM
Divides this value by another value in place.
Parameters
- args
__le__ (self, mM)
Reports whether this value is less than or equal to another value.
Parameters
- mM
__lt__ (self, mM)
Reports whether this value is less than another value.
Parameters
- mM
The "multiplication" operator. See Also: *=
Parameters
- args
Sample code
Calls `RLPy.RMatrix3.__mul__` with the inputs shown in the example.
def run_script():
import RLPy
0, 0, 0,
0, 0, 0 )
matrix3_b = RLPy.RMatrix3( 2, 0, 0,
2, 0, 0,
2, 0, 0 )
matrix3_result = matrix3_a * matrix3_b
print( matrix3_result.GetRow(0)[0] == 1*2 + 2*2 + 3*2 ) # true
__ne__ (self, mM)
The "not equal to" operator. Performs a one-by-one comparison of the matrix array. See Also: ==
Parameters
- mM
__neg__ (self)
Returns the negated value.
__sub__ (self, mM)
The "subtraction" operator. See Also: -=
Parameters
- mM
Sample code
Calls `RLPy.RMatrix3.__sub__` with the inputs shown in the example.
def run_script():
import RLPy
0, 0, 0,
0, 0, 0 )
0, 0, 0,
0, 0, 0 )
matrix3_result = matrix3_a - matrix3_b
print( matrix3_result.GetRow(0)[0] == 1-2 ) # true
print( matrix3_result.GetRow(0)[1] == 2-2 ) # true
print( matrix3_result.GetRow(0)[2] == 3-2 ) # true
The "division" operator. See Also: /=
Parameters
- args
Sample code
Calls `RLPy.RMatrix3.__truediv__` with the inputs shown in the example.
def run_script():
import RLPy
0, 0, 0,
0, 0, 0 )
matrix3_result = matrix3_a / 2
print( matrix3_result.GetRow(0)[0] == 1/2 ) # true
print( matrix3_result.GetRow(0)[1] == 2/2 ) # true
print( matrix3_result.GetRow(0)[2] == 3/2 ) # true
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
Constants
COUNT
DIMENSION
IDENTITY (*args)
Parameters
- args
ZERO (*args)
Parameters
- args
