IC8 Python API:RLPy RMatrix4
Contents
- 1 Description
- 2 Public Methods
- 2.1 RLPy.RMatrix4.AccuRotate(self, rkRotate)
- 2.2 RLPy.RMatrix4.AccuScale(self, rkScale)
- 2.3 RLPy.RMatrix4.AccuTranslate(self, rkTranslate)
- 2.4 RLPy.RMatrix4.Adjoint(self)
- 2.5 RLPy.RMatrix4.AdjointTranspose(self)
- 2.6 RLPy.RMatrix4.AlmostSame(self, kM, fThreshold)
- 2.7 RLPy.RMatrix4.Determinant(self)
- 2.8 RLPy.RMatrix4.E(self, args)
- 2.9 RLPy.RMatrix4.FromEulerAngle(self, Oreder, rx, ry, rz)
- 2.10 RLPy.RMatrix4.GetColumn(self, nC)
- 2.11 RLPy.RMatrix4.GetRow(self, nR)
- 2.12 RLPy.RMatrix4.GetSR(self)
- 2.13 RLPy.RMatrix4.GetTranslate(self)
- 2.14 RLPy.RMatrix4.InfNorm(self)
- 2.15 RLPy.RMatrix4.Inverse(self)
- 2.16 RLPy.RMatrix4.InverseTranspose(self)
- 2.17 RLPy.RMatrix4.M(self, args)
- 2.18 RLPy.RMatrix4.MakeIdentity(self)
- 2.19 RLPy.RMatrix4.MaxColumn(self)
- 2.20 RLPy.RMatrix4.MaxRow(self)
- 2.21 RLPy.RMatrix4.OneNorm(self)
- 2.22 RLPy.RMatrix4.RotateAxisAngle(self, rkAxis, fAngle)
- 2.23 RLPy.RMatrix4.RotationX(self, fAngle)
- 2.24 RLPy.RMatrix4.RotationY(self, fAngle)
- 2.25 RLPy.RMatrix4.RotationZ(self, fAngle)
- 2.26 RLPy.RMatrix4.SetSR(self, mSR)
- 2.27 RLPy.RMatrix4.SetTranslate(self, vTranslate)
- 2.28 RLPy.RMatrix4.TimesTranspose(self, mM)
- 2.29 RLPy.RMatrix4.Transpose(self)
- 2.30 RLPy.RMatrix4.TransposeTimes(self, mM)
- 3 Description
- 4 Constructor & Destructor
- 5 Member Functions
- 5.1 AccuRotate (self, rkRotate)
- 5.2 AccuScale (self, rkScale)
- 5.3 AccuTranslate (self, rkTranslate)
- 5.4 Adjoint (self)
- 5.5 AdjointTranspose (self)
- 5.6 AlmostSame (self, kM, fThreshold)
- 5.7 Determinant (self)
- 5.8 E (self, *args)
- 5.9 FromEulerAngle (self, Oreder, rx, ry, rz)
- 5.10 FromRTS (self, kRotate, kTranslate, kScale)
- 5.11 GetColumn (self, nC)
- 5.12 GetRow (self, nR)
- 5.13 GetSR (self)
- 5.14 GetSimpleRTS (self, rkRotate, rkTranslate, rkScale)
- 5.15 GetSimpleRotate (self, rkRotate)
- 5.16 GetTranslate (self)
- 5.17 InfNorm (self)
- 5.18 Inverse (self)
- 5.19 InverseTranspose (self)
- 5.20 M (self, *args)
- 5.21 MakeIdentity (self)
- 5.22 MaxColumn (self)
- 5.23 MaxRow (self)
- 5.24 OneNorm (self)
- 5.25 RotateAxisAngle (self, rkAxis, fAngle)
- 5.26 RotationX (self, fAngle)
- 5.27 RotationY (self, fAngle)
- 5.28 RotationZ (self, fAngle)
- 5.29 SetSR (self, mSR)
- 5.30 SetTranslate (self, vTranslate)
- 5.31 SetTranslateZero (self)
- 5.32 TimesTranspose (self, mM)
- 5.33 Transpose (self)
- 5.34 TransposeTimes (self, mM)
- 5.35 __add__ (self, mM)
- 5.36 __eq__ (self, mM)
- 5.37 __ge__ (self, mM)
- 5.38 __gt__ (self, mM)
- 5.39 __iadd__ (self, mM)
- 5.40 __imul__ (self, *args)
- 5.41 __isub__ (self, mM)
- 5.42 __itruediv__ (self, *args)
- 5.43 __le__ (self, mM)
- 5.44 __lt__ (self, mM)
- 5.45 __mul__ (self, *args)
- 5.46 __ne__ (self, mM)
- 5.47 __neg__ (self)
- 5.48 __sub__ (self, mM)
- 5.49 __truediv__ (self, *args)
- 6 Properties
- 7 Constants
- Main article: iC8 Modules.
- Last modified: 10/21/2026
Description
This class represent the transform data of RTransform. This class provides access to RLPy's internal 4x4 matrix operators and related functions.
Public Methods
Accumulate matrix with rotation matrix.
Parameters
rkRotate[IN] Rotation matrix - RLPy.RMatrix3
Returns
Return a new matrix (*this) *= Accumulate - RLPy.RMatrix4
1 matrix4_orgin = RLPy.RMatrix4()
2 matrix4_orgin.MakeIdentity()
3 matrix3_orgin = RLPy.RMatrix3()
4 matrix3_orgin.FromAxisAngle( RLPy.RVector3( 0, 1, 0 ), 90 * RLPy.RMath.CONST_DEG_TO_RAD )
5 matrix4_orgin.AccuRotate(matrix3_orgin)
6 matrix4_orgin.AccuRotate(matrix3_orgin)
7
8 rotate = RLPy.RMatrix3()
9 matrix4_orgin.GetSimpleRotate( rotate )
10 row0 = rotate.GetRow(0)
11
12 print(row0[0])
13 print(row0[1])
14 print(row0[2])
Accumulate matrix with scale vector.
Parameters
rkScale[IN] Scale vector - RLPy.RVector3
Returns
3 matrix4_orgin.AccuScale(RLPy.RVector3( 2, 2, 2 ) )
4 matrix4_orgin.AccuScale(RLPy.RVector3( 3, 3, 3 ) )
5
6 result = matrix4_orgin.GetSR()
7
8 row0 = result.GetRow(0)
9 print(row0[0] == 2*3)
10
11 row1 = result.GetRow(1)
12 print(row1[1] == 2*3)
13
14 row2 = result.GetRow(2)
15 print(row2[2] == 2*3)
Accumulate matrix with translate vector.
Parameters
rkTranslate[IN] Translate vector - RLPy.RVector3
Returns
3 matrix4_orgin.AccuTranslate(RLPy.RVector3( 1, 2, 3 ) )
4 matrix4_orgin.AccuTranslate(RLPy.RVector3( 2, 2, 2 ) )
5
6 row3 = matrix4_orgin.GetRow(3)
7
8 print(row3[0] == 1+2)
9 print(row3[1] == 2+2)
10 print(row3[2] == 2+3)
Inverse times determinant.
Returns
Returns a new matrix containing this matrix's adjoint - RLPy.RMatrix4
1 matrix4_value = RLPy.RMatrix4( 1, 2, 1, 1,
2 1, 1,-1,-2,
3 1,-1,-1, 2,
4 1,-2, 1,-1 )
5
6 matrix4_Adjoint = matrix4_value.Adjoint()
7 row0_Adjoint = matrix4_Adjoint.GetRow(0)
8
9 print(row0_Adjoint[0])
10 print(row0_Adjoint[1])
11 print(row0_Adjoint[2])
12 print(row0_Adjoint[3])
Transpose of inverse times determinant.
Returns
Returns a new matrix - RLPy.RMatrix4
2 1, 1,-1,-2,
3 1,-1,-1, 2,
4 1,-2, 1,-1 )
5
6 matrix4_Adjoint_transpose = matrix4_value.AdjointTranspose()
7 col0_Adjoint_transpose = matrix4_Adjoint_transpose.GetColumn(0)
8
9 print(col0_Adjoint_transpose[0] == row0_Adjoint[0])
10 print(col0_Adjoint_transpose[1] == row0_Adjoint[1])
11 print(col0_Adjoint_transpose[2] == row0_Adjoint[2])
12 print(col0_Adjoint_transpose[3] == row0_Adjoint[3])
compare each element of matrix with threshold(operator= is memory compare)
Parameters
kM[IN] Matrix to compare - RLPy.RMatrix4 fThreshold[IN] Threshold to compare - float
Returns
Return bool - bool
1 # No example
The matrix's determinant.
Returns
Returns the determinant of the matrix - float
2 1, 1,-1,-2,
3 1,-1,-1, 2,
4 1,-2, 1,-1 )
5
6 print(matrix4_value.Determinant())
Get the matrix element for the specified index(0~15).
Parameters
nEle[IN] Index of the matrix - int
Returns
Returns the matrix element specified by index - float
1 matrix4 = RLPy.RMatrix4()
2 matrix4.MakeIdentity()
3 print(matrix4.E(0))
Rotation matrix from Euler angle.
Parameters
Oreder[IN] Euler order - RLPy.Rotation_Order rx[IN] Angle of x-axis in radians - float ry[IN] Angle of y-axis in radians - float rz[IN] Angle of z-axis in radians - float
Returns
Return a new matrix from specified axis angle - RLPy.RMatrix4
1 # No example
Get the matrix element for the specified column.
Parameters
nC[IN] Index of the column in the matrix - int
Returns
Returns the column vector of the matrix - RLPy.RVector4
1 # No example
Get the matrix element for the specified row.
Parameters
nR[IN] Index of the row in the matrix - int
Returns
Returns the row vector of the matrix - RLPy.RVector4
3 row0 = matrix4.GetRow(0)
4
5 print(row0[0])
6 print(row0[1])
7 print(row0[2])
8 print(row0[3])
Get scale and rotation part of the matrix.
Returns
Return a 3x3 matrix - RLPy.RMatrix3
1 # No example
Get translate of the matrix.
Returns
Return a translate vector - RLPy.RVector3
1 # No example
InfNorm of the matrix.
Returns
Return InfNorm - float
1 # No example
Inverse of the matrix.
Returns
Returns a new matrix containing this matrix's inverse - RLPy.RMatrix4
1 # No example
Transpose of inverse.
Returns
2 1, 1,-1,-2,
3 1,-1,-1, 2,
4 1,-2, 1,-1 )
5
6 matrix4_inverse_transpose = matrix4_value.InverseTranspose()
7 col0_inverse_transpose = matrix4_inverse_transpose.GetColumn(0)
8
9 print(col0_inverse_transpose[0] == row0_inverse[0])
10 print(col0_inverse_transpose[1] == row0_inverse[1])
11 print(col0_inverse_transpose[2] == row0_inverse[2])
12 print(col0_inverse_transpose[3] == row0_inverse[3])
Get the matrix element for the specified row and column.
Parameters
nRow[IN] Index of the row in the matrix - int nCol[IN] Index of the column in the matrix - int
Returns
Returns the matrix element specified by row and col - float
3 print(matrix4.M(0,0)) #
Sets the matrix to the identity.
Returns
this object - RLPy.RMatrix4
Get maximum value of the column index in the matrix.
Returns
Return index of column of M containing maximum abs entry, or -1 if M = 0 - int
1 matrix4_column_value = RLPy.RMatrix4( 1, 2, 3,-5,
2 0, 0, 0, 0,
3 0, 0, 0, 0,
4 0, 0, 0, 0 )
5
6 print(matrix4_column_value.MaxColumn()) # column:3 -> abs(-5)
Get maximum value of the row index in the matrix.
Returns
Return index of row of M containing maximum abs entry, or -1 if M = 0 - int
1 matrix4_row_value = RLPy.RMatrix4( 1, 0, 0, 0,
2 2, 0, 0, 0,
3 3, 0, 0, 0,
4 -5, 0, 0, 0 )
5
6 print(matrix4_value.MaxRow()) # Row:3 -> abs(-5)
Norm of the matrix.
Returns
Return Norm - float
1 # No example
Rotation matrix from axis angle.
Parameters
rkAxis[IN] axis vector - RLPy.RVector3 fAngle[IN] angle in radians - float
Returns
1 # No example
Rotation matrix for rotations around x-axis.
Parameters
Returns
Return a new matrix of for rotations around x-axis - RLPy.RMatrix4
1 # No example
Rotation matrix for rotations around y-axis.
Parameters
Returns
Return a new matrix of for rotations around y-axis - RLPy.RMatrix4
1 # No example
Rotation matrix for rotations around z-axis.
Parameters
Returns
Return a new matrix of for rotations around z-axis - RLPy.RMatrix4
1 # No example
Set scale and rotation part of the matrix.
Parameters
mSR[IN] 3x3 matrix - RLPy.RMatrix3
Returns
Return a new 4x4 matrix - RLPy.RMatrix4
1 # No example
Set translate of the matrix.
Parameters
vTranslate[IN] Translate vector - RLPy.RVector3
Returns
Return a new matrix with the specified translation - RLPy.RMatrix4
1 # No example
Multiplies of the transpose of the matrix.
Parameters
mM[IN] the matrix - RLPy.RMatrix4
Returns
Returns a new matrix. (this * M^T) - RLPy.RMatrix4
1 # No example
Transpose of the matrix.
Returns
Returns a new matrix containing this matrix's transpose - RLPy.RMatrix4
1 # No example
Parameters
Returns
Returns a new matrix. (this^T * mM) - RLPy.RMatrix4
1 # No example
Description
__init__ (self, *args)
The constructor. Initialize a new RMatrix4 with RMatrix4 Item Value.
Parameters
- args
Member Functions
Accumulate this 4x4 matrix with rotation matrix.
Parameters
- rkRotate
Accumulate this 4x4 matrix with scale vector.
Parameters
- rkScale
Accumulate this 4x4 matrix with translate vector.
Parameters
- rkTranslate
Adjoint (self)
Adjugate this 4x4 matrix.
Sample code
Calls `RLPy.RMatrix4.Adjoint` with the inputs shown in the example.
def run_script():
import RLPy
1, 1,-1,-2,
1,-1,-1, 2,
1,-2, 1,-1 )
Adjugate and transpose this 4x4 matrix.
Sample code
Calls `RLPy.RMatrix4.AdjointTranspose` with the inputs shown in the example.
def run_script():
import RLPy
1, 1,-1,-2,
1,-1,-1, 2,
1,-2, 1,-1 )
Reports whether this matrix is approximately equal to another matrix.
Parameters
- kM
- fThreshold
Determinant (self)
Obtain the scalar value for this 4x4 matrix (|A|). File:Rlpy_rmatrix4_determinant.jpg
Sample code
Calls `RLPy.RMatrix4.Determinant` with the inputs shown in the example.
def run_script():
import RLPy
1, 1,-1,-2,
1,-1,-1, 2,
1,-2, 1,-1 )
E (self, *args)
Get the value of an element in a 3x3 matrix by index number (from 0 to 15);
Parameters
- args
Sample code
Calls `RLPy.RMatrix4.E` with the inputs shown in the example.
def run_script():
import RLPy
print(matrix4.E(0)) #
Convert Euler angle to a 4x4 matrix according to a rotation axis order.
Parameters
- Oreder
- rx
- ry
- rz
Apply rotate, translate, and scale data to a 4x4 matrix.
Parameters
- kRotate
- kTranslate
- kScale
Retrieve a column inside a 4x4 matrix.
Parameters
- nC
Sample code
Calls `RLPy.RMatrix4.GetColumn` with the inputs shown in the example.
def run_script():
import RLPy
col0 = matrix4.GetColumn(0)
print(col0[0])
print(col0[1])
print(col0[2])
print(col0[3])
Sample code
Calls `RLPy.RMatrix4.TimesTranspose` with the inputs shown in the example.
def run_script():
import RLPy
matrix4_orgin = RLPy.RMatrix4( 1, 2, 3, 4,
5, 6, 7, 8,
9, 10, 11, 12,
13, 14, 15, 16 )
matrix4_transpose_value = RLPy.RMatrix4( 3, 0, 0, 0,
0, 3, 0, 0,
0, 0, 3, 0,
0, 0, 0, 3 )
matrix4_times_transpose = matrix4_orgin.TimesTranspose(matrix4_transpose_value)
row0 = matrix4_orgin.GetColumn(0)
col0 = matrix4_times_transpose.GetColumn(0)
print(row0[0]*3 == col0[0])
print(row0[1]*3 == col0[1])
print(row0[2]*3 == col0[2])
print(row0[3]*3 == col0[3])
GetRow (self, nR)
Retreive a row inside a 4x4 matrix.
Parameters
- nR
Sample code
Calls `RLPy.RMatrix4.TransposeTimes` with the inputs shown in the example.
def run_script():
import RLPy
5, 6, 7, 8,
9, 10, 11, 12,
13, 14, 15, 16 )
matrix4_transpose_value = RLPy.RMatrix4( 2, 0, 0, 0,
0, 2, 0, 0,
0, 0, 2, 0,
0, 0, 0, 2 )
matrix4_transpose_times = matrix4_orgin.TransposeTimes(matrix4_transpose_value)
row0 = matrix4_orgin.GetRow(0)
col0 = matrix4_transpose_times.GetColumn(0)
print(row0[0]*2 == col0[0])
print(row0[1]*2 == col0[1])
print(row0[2]*2 == col0[2])
print(row0[3]*2 == col0[3])
Sample code
Calls `RLPy.RMatrix4.GetRow` with the inputs shown in the example.
def run_script():
import RLPy
print(row0[0])
print(row0[1])
print(row0[2])
print(row0[3])
Sample code
Calls `RLPy.RMatrix4.Transpose` with the inputs shown in the example.
def run_script():
import RLPy
5, 6, 7, 8,
9, 10, 11, 12,
13, 14, 15, 16 )
matrix4_transpose = matrix4_orgin.Transpose()
col0 = matrix4_transpose.GetColumn(0)
print(row0[0] == col0[0])
print(row0[1] == col0[1])
print(row0[2] == col0[2])
print(row0[3] == col0[3])
GetSR (self)
Retrieve rotation, translation, and scale data from this 4x4 matrix.
Parameters
- rkRotate
- rkTranslate
- rkScale
Retrieve rotation data from this 4x4 matrix.
Parameters
- rkRotate
GetTranslate (self)
InfNorm (self)
Return the sum of the row elements that contain the largest absolute values.
Sample code
Calls `RLPy.RMatrix4.InfNorm` with the inputs shown in the example.
def run_script():
import RLPy
0, 0, 0, 0,
0, 0, 0, 0,
0, 0, 0, 0 )
print(matrix4_column_value.InfNorm()) # 11 -> 1+2+abs(-5)
Inverse (self)
Obtain the inverse (reciprocal) of this 4x4 matrix (A^-1).
Sample code
Calls `RLPy.RMatrix4.Inverse` with the inputs shown in the example.
def run_script():
import RLPy
1, 1,-1,-2,
1,-1,-1, 2,
1,-2, 1,-1 )
matrix4_inverse = matrix4_value.Inverse()
row0_inverse = matrix4_inverse.GetRow(0)
print(row0_inverse[0])
print(row0_inverse[1])
print(row0_inverse[2])
print(row0_inverse[3])
Invert and transpose this 4x4 matrix.
Sample code
Calls `RLPy.RMatrix4.InverseTranspose` with the inputs shown in the example.
def run_script():
import RLPy
1, 1,-1,-2,
1,-1,-1, 2,
1,-2, 1,-1 )
M (self, *args)
Get the value of an element in a 4x4 matrix by row and column index.
Parameters
- args
Sample code
Calls `RLPy.RMatrix4.M` with the inputs shown in the example.
def run_script():
import RLPy
MakeIdentity (self)
This function can be used to initialize the 3x3 matrix. It is equivalent to setting the matrix to: [1 0 0 0] [0 1 0 0] [0 0 1 0] [0 0 0 1]
Sample code
def run_script():
import RLPy
Sample code
def run_script():
import RLPy
print(col0[0])
print(col0[1])
print(col0[2])
print(col0[3])
Sample code
def run_script():
import RLPy
print(row0[0])
print(row0[1])
print(row0[2])
print(row0[3])
Sample code
def run_script():
import RLPy
Sample code
Calls `RLPy.RMatrix4.MakeIdentity` with the inputs shown in the example.
def run_script():
import RLPy
MaxColumn (self)
Find the maximum absolute value within this 4x4 matrix, and return the column in which the value is located. If all of the elements within the 4x4 matrix are 0 then return -1.
Sample code
Calls `RLPy.RMatrix4.MaxColumn` with the inputs shown in the example.
def run_script():
import RLPy
0, 0, 0, 0,
0, 0, 0, 0,
0, 0, 0, 0 )
MaxRow (self)
Find the maximum absolute value within this 4x4 matrix, and return the row in which the value is located. If all of the elements within the 4x4 matrix are 0 then return -1.
OneNorm (self)
Return the sum of the column elements that contain the largest absolute values.
Sample code
Calls `RLPy.RMatrix4.OneNorm` with the inputs shown in the example.
def run_script():
import RLPy
2, 0, 0, 0,
3, 0, 0, 0,
-5, 0, 0, 0 )
print(matrix4_row_value.OneNorm()) # 11 -> 1+2+abs(-5)
Parameters
- rkAxis
- fAngle
Parameters
- fAngle
Parameters
- fAngle
Parameters
- fAngle
SetSR (self, mSR)
Parameters
- mSR
Parameters
- vTranslate
Set the translation data in this 4x4 matrix to 0.
Multiply this 4x4 matrix with a transposed version of itself.
Parameters
- mM
Sample code
def run_script():
import RLPy
5, 6, 7, 8,
9, 10, 11, 12,
13, 14, 15, 16 )
0, 3, 0, 0,
0, 0, 3, 0,
0, 0, 0, 3 )
Transpose (self)
Obtain the transposed matrix by transposing the current m * n matrix into an n * m matrix by row-column swapping.
Sample code
def run_script():
import RLPy
5, 6, 7, 8,
9, 10, 11, 12,
13, 14, 15, 16 )
Multiply a transposed version of a 4x4 matrix with itself.
Parameters
- mM
Sample code
def run_script():
import RLPy
5, 6, 7, 8,
9, 10, 11, 12,
13, 14, 15, 16 )
0, 2, 0, 0,
0, 0, 2, 0,
0, 0, 0, 2 )
__add__ (self, mM)
The "addition" operator. See Also: +=
Parameters
- mM
Sample code
Calls `RLPy.RMatrix4.__add__` with the inputs shown in the example.
def run_script():
import RLPy
matrix4_a = RLPy.RMatrix4( 1, 2, 3, 4,
0, 0, 0, 0,
0, 0, 0, 0,
0, 0, 0, 0 )
matrix4_b = RLPy.RMatrix4( 2, 2, 2, 2,
0, 0, 0, 0,
0, 0, 0, 0,
0, 0, 0, 0 )
matrix4_result = matrix4_a + matrix4_b
print( matrix4_result.GetRow(0)[0] == 1+2 ) # true
print( matrix4_result.GetRow(0)[1] == 2+2 ) # true
print( matrix4_result.GetRow(0)[2] == 3+2 ) # true
print( matrix4_result.GetRow(0)[3] == 4+2 ) # true
__eq__ (self, mM)
The "equal to" operator. Performs a one-by-one comparison of the matrix array. See Also: !=
Parameters
- mM
__ge__ (self, mM)
Reports whether this value is greater than or equal to another value.
Parameters
- mM
__gt__ (self, mM)
Reports whether this value is greater than another value.
Parameters
- mM
__iadd__ (self, mM)
Adds another value to this value in place.
Parameters
- mM
Multiplies this value by another value in place.
Parameters
- args
__isub__ (self, mM)
Subtracts another value from this value in place.
Parameters
- mM
Divides this value by another value in place.
Parameters
- args
__le__ (self, mM)
Reports whether this value is less than or equal to another value.
Parameters
- mM
__lt__ (self, mM)
Reports whether this value is less than another value.
Parameters
- mM
The "multiplication" operator. See Also: *=
Parameters
- args
Sample code
Calls `RLPy.RMatrix4.__mul__` with the inputs shown in the example.
def run_script():
import RLPy
0, 0, 0, 0,
0, 0, 0, 0,
0, 0, 0, 0 )
matrix4_b = RLPy.RMatrix4( 2, 0, 0, 0,
2, 0, 0, 0,
2, 0, 0, 0,
2, 0, 0, 0 )
matrix4_result = matrix4_a * matrix4_b
print( matrix4_result.GetRow(0)[0] == 1*2 + 2*2 + 3*2 + 4*2 ) # true
__ne__ (self, mM)
The "not equal to" operator. Performs a one-by-one comparison of the matrix array. See Also: ==
Parameters
- mM
__neg__ (self)
Returns the negated value.
__sub__ (self, mM)
The "subtraction" operator. See Also: -=
Parameters
- mM
Sample code
Calls `RLPy.RMatrix4.__sub__` with the inputs shown in the example.
def run_script():
import RLPy
0, 0, 0, 0,
0, 0, 0, 0,
0, 0, 0, 0 )
0, 0, 0, 0,
0, 0, 0, 0,
0, 0, 0, 0 )
matrix4_result = matrix4_a - matrix4_b
print( matrix4_result.GetRow(0)[0] == 1-2 ) # true
print( matrix4_result.GetRow(0)[1] == 2-2 ) # true
print( matrix4_result.GetRow(0)[2] == 3-2 ) # true
print( matrix4_result.GetRow(0)[3] == 4-2 ) # true
The "division" operator. See Also: /=
Parameters
- args
Sample code
Calls `RLPy.RMatrix4.__truediv__` with the inputs shown in the example.
def run_script():
import RLPy
0, 0, 0, 0,
0, 0, 0, 0,
0, 0, 0, 0 )
matrix4_result = matrix4_a / 2
print( matrix4_result.GetRow(0)[0] == 1/2 ) # true
print( matrix4_result.GetRow(0)[1] == 2/2 ) # true
print( matrix4_result.GetRow(0)[2] == 3/2 ) # true
print( matrix4_result.GetRow(0)[3] == 4/2 ) # true
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
Constants
COUNT
DIMENSION
IDENTITY (*args)
Parameters
- args
ZERO (*args)
Parameters
- args
