IC8 Python API:RLPy RMorphSliderSetting
From Reallusion Wiki!
Jump to: navigation, search
Contents
Description
This class stores morph-slider configuration, including category, source, target, range, and display name.
Constructor & Destructor
__init__ (self)
Initializes a new morph slider setting instance.
Member Functions
GetAdjustBonesToFitMorph (self)
Gets whether to adjust bones to fit morph.
Sample code
Demonstrates calls to `RLPy.RMorphSliderSetting.GetAdjustBonesToFitMorph`, `RLPy.RMorphSliderSetting.GetAutoApplyToCurrentCharacter`, `RLPy.RMorphSliderSetting.GetAxisSettingForObj`, `RLPy.RMorphSliderSetting.GetCategory`, `RLPy.RMorphSliderSetting.GetMorphName`, `RLPy.RMorphSliderSetting.GetMorphValueRange`, `RLPy.RMorphSliderSetting.GetSliderPath`, `RLPy.RMorphSliderSetting.GetSourceBaseType`, `RLPy.RMorphSliderSetting.GetSourceFilePath`, `RLPy.RMorphSliderSetting.GetTargetFilePath`, `RLPy.RMorphSliderSetting.GetTargetMorphChecksumFilePath`, `RLPy.RMorphSliderSetting.GetThumbNailFilePath`, `RLPy.RMorphSliderSetting.SetAdjustBonesToFitMorph`, `RLPy.RMorphSliderSetting.SetAutoApplyToCurrentCharacter`, `RLPy.RMorphSliderSetting.SetAxisSettingForObj`, `RLPy.RMorphSliderSetting.SetCategory`, `RLPy.RMorphSliderSetting.SetMorphName`, `RLPy.RMorphSliderSetting.SetMorphValueRange`, `RLPy.RMorphSliderSetting.SetSliderPath`, `RLPy.RMorphSliderSetting.SetSourceBaseType`, `RLPy.RMorphSliderSetting.SetSourceFilePath`, `RLPy.RMorphSliderSetting.SetTargetFilePath`, `RLPy.RMorphSliderSetting.SetTargetMorphChecksumFilePath`, and `RLPy.RMorphSliderSetting.SetThumbNailFilePath` using the example's inputs.
def run_script():
    import RLPy
    value = RLPy.RMorphSliderSetting()
    value.SetMorphName("LocalSample")
    name = value.GetMorphName()
    category = value.GetCategory()
    value.SetCategory(category)
    value.SetSliderPath("slider.local")
    slider = value.GetSliderPath()
    value.SetMorphValueRange(-0.25, 1.25)
    value_range = value.GetMorphValueRange()
    source_base = value.GetSourceBaseType()
    value.SetSourceBaseType(source_base)
    value.SetSourceFilePath("source.local")
    source_path = value.GetSourceFilePath()
    value.SetTargetFilePath("target.local")
    target_path = value.GetTargetFilePath()
    value.SetTargetMorphChecksumFilePath("checksum.local")
    checksum_path = value.GetTargetMorphChecksumFilePath()
    axis = value.GetAxisSettingForObj()
    value.SetAxisSettingForObj(axis)
    adjust = value.GetAdjustBonesToFitMorph()
    value.SetAdjustBonesToFitMorph(not adjust)
    changed_adjust = value.GetAdjustBonesToFitMorph()
    value.SetAdjustBonesToFitMorph(adjust)
    value.SetThumbNailFilePath("thumbnail.local")
    thumbnail = value.GetThumbNailFilePath()
    apply_current = value.GetAutoApplyToCurrentCharacter()
    value.SetAutoApplyToCurrentCharacter(not apply_current)
    changed_apply = value.GetAutoApplyToCurrentCharacter()
    value.SetAutoApplyToCurrentCharacter(apply_current)
    return (name, category, slider, list(value_range), source_base, source_path, target_path, checksum_path, axis, adjust, changed_adjust, thumbnail, apply_current, changed_apply)
GetAutoApplyToCurrentCharacter (self)
Gets auto apply to current character.
Sample code
def run_script():
    import RLPy
GetAxisSettingForObj (self)
Gets axis setting for .obj.
Sample code
def run_script():
    import RLPy
GetCategory (self)
Gets category.
Sample code
def run_script():
    import RLPy
GetMorphName (self)
Gets morph slider name.
Sample code
def run_script():
    import RLPy
GetMorphValueRange (self)
Gets MorphValueRangeMin and MorphValueRangeMax.
Sample code
def run_script():
    import RLPy
GetSliderPath (self)
Gets slider path.
Sample code
def run_script():
    import RLPy
GetSourceBaseType (self)
Gets the type of source morph.
Sample code
def run_script():
    import RLPy
GetSourceFilePath (self)
Gets source file path.
Sample code
def run_script():
    import RLPy
GetTargetFilePath (self)
Gets target file path.
Sample code
def run_script():
    import RLPy
GetTargetMorphChecksumFilePath (self)
Gets target checksum file path.
Sample code
def run_script():
    import RLPy
GetThumbNailFilePath (self)
Gets thumbnail file path.
Sample code
def run_script():
    import RLPy
SetAdjustBonesToFitMorph (self, bAdjustBonesToFitMorph)
Sets whether to adjust bones to fit morph.
Parameters
  • bAdjustBonesToFitMorph
Sample code
def run_script():
    import RLPy
SetAutoApplyToCurrentCharacter (self, bAutoApplyToCurrentCharacter)
Sets auto apply to current character.
Parameters
  • bAutoApplyToCurrentCharacter
Sample code
def run_script():
    import RLPy
SetAxisSettingForObj (self, eAxisSettingForObj)
Sets axis setting for .obj.
Parameters
  • eAxisSettingForObj
Sample code
def run_script():
    import RLPy
SetCategory (self, eSetCategory)
Sets category.
Parameters
  • eSetCategory
Sample code
def run_script():
    import RLPy
SetMorphName (self, strMorphName)
Sets morph slider name.
Parameters
  • strMorphName
Sample code
def run_script():
    import RLPy
SetMorphValueRange (self, fMin, fMax)
Sets morph value range ( min, max).
Parameters
  • fMin
  • fMax
Sample code
def run_script():
    import RLPy
SetSliderPath (self, strSetSliderPath)
Sets slider path.
Parameters
  • strSetSliderPath
Sample code
def run_script():
    import RLPy
SetSourceBaseType (self, eSourceBaseType)
Sets the type of source morph.
Parameters
  • eSourceBaseType
Sample code
def run_script():
    import RLPy
SetSourceFilePath (self, strSourceMorphPath)
Sets source file path.
Parameters
  • strSourceMorphPath
Sample code
def run_script():
    import RLPy
SetTargetFilePath (self, strTargetMorphPath)
Sets target file path.
Parameters
  • strTargetMorphPath
Sample code
def run_script():
    import RLPy
SetTargetMorphChecksumFilePath (self, strTargetMorphChecksumFilePath)
Sets target checksum file path.
Parameters
  • strTargetMorphChecksumFilePath
Sample code
def run_script():
    import RLPy
SetThumbNailFilePath (self, strThumdNailFilePath)
Sets thumbnail file path.
Parameters
  • strThumdNailFilePath
Sample code
def run_script():
    import RLPy
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
