IC8 Python API:RLPy RQuaternion
Contents
- 1 Description
- 2 Constructor & Destructor
- 3 Member Functions
- 3.1 AlmostEqual (self, qQ)
- 3.2 AlmostSame (self, qQ, tThreshold)
- 3.3 Conjugate (self)
- 3.4 Dot (self, qQ)
- 3.5 FindQuatBetweenHelper (A, B, NormAB)
- 3.6 FindQuatBetweenInternal (An, Bn)
- 3.7 FindQuatBetweenNormals (NormalA, NormalB)
- 3.8 FindQuatBetweenVectors (VectorA, VectorB)
- 3.9 FromAxisAngle (self, rkAxis, fAngle)
- 3.10 FromRotationMatrix (self, rkRot)
- 3.11 Inverse (self)
- 3.12 Multiply (self, qQ)
- 3.13 MultiplyAssign (self, qQ)
- 3.14 MultiplyVector (self, vPoint)
- 3.15 Normalize (self)
- 3.16 Rotate180 (self)
- 3.17 SetW (self, tW)
- 3.18 SetX (self, tX)
- 3.19 SetY (self, tY)
- 3.20 SetZ (self, tZ)
- 3.21 ToAxisAngle (self, rkAxis, rfAngle)
- 3.22 ToRotationMatrix (self)
- 3.23 W (self, *args)
- 3.24 X (self, *args)
- 3.25 Y (self, *args)
- 3.26 Z (self, *args)
- 3.27 __add__ (self, qQ)
- 3.28 __eq__ (self, qQ)
- 3.29 __ge__ (self, qQ)
- 3.30 __gt__ (self, qQ)
- 3.31 __iadd__ (self, qQ)
- 3.32 __imul__ (self, *args)
- 3.33 __isub__ (self, qQ)
- 3.34 __itruediv__ (self, *args)
- 3.35 __le__ (self, qQ)
- 3.36 __lt__ (self, qQ)
- 3.37 __mul__ (self, *args)
- 3.38 __ne__ (self, qQ)
- 3.39 __neg__ (self)
- 3.40 __sub__ (self, qQ)
- 3.41 __truediv__ (self, *args)
- 4 Properties
- 5 Constants
Description
This class represents a quaternion in mathematics. Quaternions represetn directions as a single rotation, just as rectangular coordinates represent positions as single vector. RQuaternion also defines some constants that can be used directly: {| class="wikitable" !Constant !Description |- |RQuaternion.IDENTITY |4D zero vector: (0, 0, 0, 1) |- |RQuaternion.ZERO |4D x unit vector: (0, 0, 0, 0) initialization value |}
__init__ (self, *args)
The constructor. Initialize a new RQuaternion object without initialization.
Parameters
- args
Member Functions
Determine if two quaternions are almost the same within a tolerance of 0.00001.
Parameters
Reports whether this quaternion is approximately equal to another quaternion.
Parameters
- tThreshold
Conjugate (self)
Get the conjugate of this quaternion. The result is a quaternion whose x, y, and z values have been negated.
Dot (self, qQ)
Calculate the dot product of two quaternions.
Parameters
Computes a quaternion from vectors A and B using the supplied NormAB value.
Parameters
- A
- B
- NormAB
Computes an intermediate quaternion from the normalized vectors An and Bn.
Parameters
- An
- Bn
Computes the quaternion that rotates one normal direction to another.
Parameters
- NormalA
- NormalB
Computes the quaternion that rotates one vector direction to another.
Parameters
- VectorA
- VectorB
Create a quaternion from axis angle.
Parameters
- rkAxis
- fAngle
Create a quaternion from a rotation matrix.
Parameters
- rkRot
Inverse (self)
Get the inverse of this quaternion.
Multiply (self, qQ)
Multiply this quaternion by another quaternion.
Parameters
Multiplies this quaternion by the supplied quaternion in place.
Parameters
Rotates a vector by this quaternion.
Parameters
- vPoint
Normalize (self)
Normalize this quaternion, e.g. with a magnitude of 2.
Rotate180 (self)
Rotate this quaternion by 180 degrees.
SetW (self, tW)
Set the value of the w-axis.
Parameters
- tW
SetX (self, tX)
Set the value of the x-axis.
Parameters
- tX
SetY (self, tY)
Set the value of the y-axis.
Parameters
- tY
SetZ (self, tZ)
Set the value of the z-axis.
Parameters
- tZ
Converts this quaternion to an axis-and-angle representation.
Parameters
- rkAxis
- rfAngle
Converts this quaternion to a rotation matrix.
W (self, *args)
Returns the w component of this quaternion.
Parameters
- args
X (self, *args)
Returns the x component of this quaternion.
Parameters
- args
Y (self, *args)
Returns the y component of this quaternion.
Parameters
- args
Z (self, *args)
Returns the z component of this quaternion.
Parameters
- args
__add__ (self, qQ)
The "addition" operator. Perform quaternion addition. See Also: +=
Parameters
__eq__ (self, qQ)
Reports whether this value equals another value.
Parameters
__ge__ (self, qQ)
Reports whether this value is greater than or equal to another value.
Parameters
__gt__ (self, qQ)
Reports whether this value is greater than another value.
Parameters
__iadd__ (self, qQ)
Adds another value to this value in place.
Parameters
Multiplies this value by another value in place.
Parameters
- args
__isub__ (self, qQ)
Subtracts another value from this value in place.
Parameters
Divides this value by another value in place.
Parameters
- args
__le__ (self, qQ)
Reports whether this value is less than or equal to another value.
Parameters
__lt__ (self, qQ)
Reports whether this value is less than another value.
Parameters
The "multiplication" operator. Perform a scalar multiplication when the second operand is an integer or float. If the second operand is another quaternion, then the respective elements are multiplied. See Also: *=
Parameters
- args
__ne__ (self, qQ)
The "not equal to" operator. See Also: ==
Parameters
__neg__ (self)
Returns the negated value.
__sub__ (self, qQ)
The "subtraction" operator. Perform quaternion subtraction. See Also: -=
Parameters
The "division" operator. Perform a scalar division with a int or float value which the second operand is limited to. See Also: /=
Parameters
- args
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
w
The quaternion's W component.
x
The quaternion's X component.
y
The quaternion's Y component.
z
The quaternion's Z component.
Constants
IDENTITY (*args)
Parameters
- args
ZERO (*args)
Parameters
- args
