IC8 Python API:RLPy RRealtimeRenderOptions
From Reallusion Wiki!
Jump to: navigation, search
Description
This class stores options used for real-time rendering.
Constructor & Destructor
__init__ (self)
Initializes a new realtime render options instance.
Properties
bBump
Indicates whether bump mapping is enabled in real-time rendering.
bCubemap
Indicates whether cubemap rendering is enabled in real-time rendering.
bDisplacementMap
Indicates whether displacement mapping is enabled in real-time rendering.
bDofTransparent
Indicates whether transparent-object depth-of-field behavior is enabled in real-time rendering.
bDofViewportType
Indicates whether viewport-type depth-of-field behavior is enabled in real-time rendering.
bGlow
Indicates whether glow rendering is enabled in real-time rendering.
bHdr
Indicates whether HDR rendering is enabled in real-time rendering.
bLod
Indicates whether level-of-detail rendering is enabled in real-time rendering.
bMipmap
Indicates whether mipmapping is enabled in real-time rendering.
bRealtimeSmooth
Indicates whether real-time smoothing is enabled in real-time rendering.
bReflection
Indicates whether reflection rendering is enabled in real-time rendering.
bRefraction
Indicates whether refraction rendering is enabled in real-time rendering.
bShadowMap
Indicates whether shadow-map rendering is enabled in real-time rendering.
bShadowTessellation
Indicates whether shadow tessellation is enabled in real-time rendering.
bSubstance
Indicates whether Substance material rendering is enabled in real-time rendering.
bViewportLessUpdate
Indicates whether updating while the viewport is hidden is enabled in real-time rendering.
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
