IC8 Python API:RLPy RRgb
From Reallusion Wiki!
Jump to: navigation, search
Description
Primary color class that stores data for red (R), green (G), and blue (B). The value stored in RRgb ranges from 0-1, which represents 0 to 255 in color value. You can swtich between these two representations in different ways; For example, the range of values retrieved by R is 0 to 1, and the range of values retrieved by Red is 0 to 255. In addition, preset colors are provided for direct usage: {|class="wikitable" !Constant !Value |- |RLPy.RRgb.BLACK |RLPy.RRgb(0, 0, 0) |- |RLPy.RRgb.WHITE |RLPy.RRgb(1, 1, 1) |- |RLPy.RRgb.RED |RLPy.RRgb(1, 0, 0) |- |RLPy.RRgb.GREEN |RLPy.RRgb(0, 1, 0) |- |RLPy.RRgb.BLUE |RLPy.RRgb(0, 0, 1) |- |RLPy.RRgb.YELLOW |RLPy.RRgb(1, 1, 0) |- |RLPy.RRgb.CYAN |RLPy.RRgb(0, 1, 1) |- |RLPy.RRgb.MAGENTA |RLPy.RRgb(1, 0, 1) |} RRgb does not include alpha data. Use RColor instead if alpha channel is needed. This class also provides ways to convert to other color formats: See Also: RColor
Constructor & Destructor
__init__ (self, *args)
Initializes a new RGB color value instance.
Parameters
  • args
Member Functions
B (self, *args)
Get the blue value of this color (0-1). See Also: Blue
Parameters
  • args
Sample code
Calls `RLPy.RRgb.B` with the inputs shown in the example.
def run_script():
    import RLPy
    color1 = RLPy.RRgb(0, 0, 1)
    print(color1.B())               # 1
Blue (self)
Get the blue value of this color (0-255). See Also: B
Sample code
Calls `RLPy.RRgb.Blue` with the inputs shown in the example.
def run_script():
    import RLPy
    print(color1.Blue())            # 255
From (self, r, g, b)
Adjust color using 32 bit (0-255).
Parameters
  • r
  • g
  • b
FromCOLORREF (self, arg2)
Adjust color using COLORREF (0xbbggrr). See Also: ToCOLORREF
Parameters
  • arg2
FromXRGB (self, arg2)
Assign this color using hexadecimal (0xrrggbb). See Also: ToXRGB
Parameters
  • arg2
G (self, *args)
Get the green value of this color (0-1). See Also: Green
Parameters
  • args
Sample code
Calls `RLPy.RRgb.G` with the inputs shown in the example.
def run_script():
    import RLPy
    color1 = RLPy.RRgb(0, 1, 0)
    print(color1.G())               # 1
Green (self)
Get the green value of this color (0-255). See Also: G
Sample code
Calls `RLPy.RRgb.Green` with the inputs shown in the example.
def run_script():
    import RLPy
    print(color1.Green())           # 255
Normalize (self)
Normalize RGB values so that their sum equals 1.
Sample code
Calls `RLPy.RRgb.Normalize` with the inputs shown in the example.
def run_script():
    import RLPy
    color1 = RLPy.RRgb(1, 1, 0)
    color1.Normalize()              # (0.5, 0.5, 0)
R (self, *args)
Get the red value of this color (0-1). See Also: Red
Parameters
  • args
Sample code
Calls `RLPy.RRgb.R` with the inputs shown in the example.
def run_script():
    import RLPy
    color1 = RLPy.RRgb(1, 0, 0)
    print(color1.R())               # 1
Red (self)
Get the red value of this color (0-255). See Also: R
Sample code
Calls `RLPy.RRgb.Red` with the inputs shown in the example.
def run_script():
    import RLPy
    print(color1.Red())            # 255
Saturate (self)
Clamp the RGB values to a range of 0 and 1. Values under 0 will become 0, and values over 1 will become 1.
Sample code
Calls `RLPy.RRgb.Saturate` with the inputs shown in the example.
def run_script():
    import RLPy
    color1 = RLPy.RRgb(1.2, -0.3, 0.5)
    color1.Saturate()              # (1, 0, 0.5)
ToCOLORREF (self)
Output COLORREF data from this color (0xbbggrr). See Also: FromCOLORREF
Sample code
Calls `RLPy.RRgb.ToCOLORREF` with the inputs shown in the example.
def run_script():
    import RLPy
    print(int(color1.ToCOLORREF()))          # 0xff0000
ToVector3f (self)
Output 3D vector data from this color.
Sample code
Calls `RLPy.RRgb.ToVector3f` with the inputs shown in the example.
def run_script():
    import RLPy
    print(color1.ToVector3f())
ToXRGB (self)
Output hexadecimal data from this color (0xrrggbb) See Also: FromXRGB
Sample code
Calls `RLPy.RRgb.ToXRGB` with the inputs shown in the example.
def run_script():
    import RLPy
    print(int(color1.ToXRGB()))              # 0xff
__add__ (self, arg2)
Adds another value to this value and returns the result.
Parameters
  • arg2
__eq__ (self, arg2)
Reports whether this value equals another value.
Parameters
  • arg2
__iadd__ (self, arg2)
Adds another value to this value in place.
Parameters
  • arg2
__imul__ (self, *args)
Multiplies this value by another value in place.
Parameters
  • args
__isub__ (self, arg2)
Subtracts another value from this value in place.
Parameters
  • arg2
__itruediv__ (self, *args)
Divides this value by another value in place.
Parameters
  • args
__lt__ (self, arg2)
Reports whether this value is less than another value.
Parameters
  • arg2
__mul__ (self, *args)
Multiplies this value by another value and returns the result.
Parameters
  • args
__ne__ (self, arg2)
Reports whether this value differs from another value.
Parameters
  • arg2
__neg__ (self)
Returns the negated value.
__sub__ (self, arg2)
Subtracts another value from this value and returns the result.
Parameters
  • arg2
__truediv__ (self, *args)
Divides this value by another value and returns the result.
Parameters
  • args
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
Constants
BLACK
BLUE
CYAN
GREEN
MAGENTA
RED
WHITE
YELLOW
