IC8 Python API:RLPy RSaveFileSetting
Contents
- 1 Description
- 2 Examples
- 3 Member Functions
- 4 Description
- 5 Constructor & Destructor
- 6 Member Functions
- 7 Properties
- Main article: iC8 Modules.
- Last modified: 10/21/2026
Description
Creates a file data for RLPy.RFileIO.SaveFile(), making it possible to save different file types.
Examples
iAvatar
1 # save iAvatar
2 avatar = RLPy.RScene.GetAvatars()[0]
3 save_avatar_path = "C:\\Temp\\avatar.iAvatar"
4 setting = RLPy.RSaveFileSetting()
5 setting.SetSaveType(RLPy.ESaveFileType_Character)
6 result = RLPy.RFileIO.SaveFile(avatar, setting, save_avatar_path)
iProp
1 # save iProp
2 prop= RLPy.RScene.GetProps()[0]
3 save_prop_path = "C:\\Temp\\prop.iProp"
5 setting.SetSaveType(RLPy.ESaveFileType_Prop)
6 result = RLPy.RFileIO.SaveFile(prop, setting, save_prop_path)
rlMotion
1 # save rlMotion
3 save_motion_path = "C:\\Temp\\motion.rlMotion"
5 setting.SetSaveType(RLPy.ESaveFileType_Motion)
6 setting.SetSaveRange(RLPy.RTick.FromMilliSecond(0), RLPy.RTick.FromMilliSecond(1000))
7 result = RLPy.RFileIO.SaveFile(avatar, setting, save_motion_path)
rlMotionPlus
1 # save iMotionPlus
3 save_motion_path = "C:\\Temp\\motion.iMotionPlus"
5 setting.SetSaveType(RLPy.ESaveFileType_MotionPlus)
6 setting.SetSaveRange( RLPy.RTick.FromMilliSecond(0), RLPy.RTick.FromMilliSecond(1000) )
7 motion_plus_option = RLPy.RSaveMotionPlusOption()
8 motion_plus_option.SetMotionPlusOption(RLPy.ESaveMotionPlusOption_Avatar_Talk | RLPy.ESaveMotionPlusOption_Avatar_Motion)
9 setting.SetSaveFileOption( motion_plus_option )
10 result = RLPy.RFileIO.SaveFile(avatar, setting, save_motion_path)
iTalk (Expression Only)
1 # save iTalk (Expression only)
3 save_expression_path= "C:\\Temp\\talk.iTalk"
4
5 iTalkOption = RLPy.RSaveFacialAnimationOption()
6 iTalkOption.SetFlag(RLPy.ESaveFacialAnimationOption_Expression)
7
8 setting = RLPy.RSaveFileSetting()
9 setting.SetSaveRange(RLPy.RTick.FromMilliSecond(0), RLPy.RTick.FromMilliSecond(1000) )
10 setting.SetSaveType( RLPy.ESaveFileType_Talk )
11 setting.SetSaveFileOption( iTalkOption )
12 result = RLPy.RFileIO.SaveFile(avatar, setting, save_expression_path)
iTalk (Expression and Viseme)
1 # save iTalk (Expression and Viseme)
4
6 iTalkOption.SetFlag(RLPy.ESaveFacialAnimationOption_All)
7
Member Functions
SetSaveType (self, eType)
Sets the file type for saving.
Parameters
- eType - The file type to save.
- iAvatar RLPy.ESaveFileType_Character
- rlMotion RLPy.ESaveFileType_Motion
- iProp RLPy.ESaveFileType_Prop
- iTalk RLPy.ESaveFileType_Talk
- iMotionPlus RLPy.ESaveFileType_MotionPlus
GetSaveType(self)
Retrieves the configured save file type, as set by SetSaveType().
Returns
- File Type: RLPy.ESaveFileType
SetSaveRange(self, kStart, kEnd)
Sets the save range, applicable only to animation files (rlMotion, iMotionPlus, iTalk).
Parameters
- kStart: Start time (RTime)
- kEnd: End time (RTime)
GetSaveRangeStart(self)
Retrieves the start time of the configured save range, as set by SetSaveRange().
Returns
- Start Time: RTime
GetSaveRangeEnd(self)
Retrieves the end time of the configured save range, as set by SetSaveRange().
Returns
- End Time: RTime
SetSaveFileOption(self, pSaveFileOption)
Configures file-specific options depending on the file type.
Parameters
- pSaveFileOption: Configuration object tailored for specific file types.
File-Specific Configurations
- iTalk (RSaveFacialAnimationOption):
- RLPy.RSaveFacialAnimationOption().SetFlag() accepts:
- RLPy.ESaveFacialAnimationOption_Expression: Saves Expression animation
- RLPy.ESaveFacialAnimationOption_Viseme: Saves Viseme animation
- RLPy.ESaveFacialAnimationOption_All: Saves both Expression and Viseme animations
- iMotionPlus (RSaveMotionPlusOption):
- RLPy.RSaveMotionPlusOption().SetMotionPlusOption() accepts:
- RLPy.ESaveMotionPlusOption_Avatar_Motion: Saves Motion animation
- RLPy.ESaveMotionPlusOption_Avatar_Spring: Saves Spring animation
- RLPy.ESaveMotionPlusOption_Avatar_Visible: Saves Visible animation
- RLPy.ESaveMotionPlusOption_Avatar_Sound: Saves Sound animation
- RLPy.ESaveMotionPlusOption_Avatar_Talk: Saves Expression and Viseme animations
- RLPy.ESaveMotionPlusOption_Avatar_Morph: Saves Morph animation
- RLPy.ESaveMotionPlusOption_Avatar_Material: Saves Material animation
- RLPy.ESaveMotionPlusOption_AllAvatar: Saves all animations
- RLPy.RSaveMotionPlusOption().SetMotionClipOption() accepts:
- RLPy.ESaveMotionClipOption_WithLayerKey: Saves LayerKey animation
- RLPy.ESaveMotionClipOption_FkMotionOnly: Saves only FK animation
- RLPy.ESaveMotionClipOption_AllBone: Saves all Bone animations
- RLPy.ESaveMotionClipOption_ExcludeTransformData: Excludes Transform animation
GetSaveFileOption(self)
Retrieves file-specific options, as configured by SetSaveFileOption().
Returns
- See SetSaveFileOption() for details.
Description
__init__ (self)
Initializes a new save file setting instance.
Member Functions
GetSaveFileOption (self)
GetSaveRangeEnd (self)
GetSaveRangeStart (self)
GetSaveType (self)
SetSaveFileOption (self, pSaveFileOption)
Parameters
- pSaveFileOption
SetSaveRange (self, kStart, kEnd)
Parameters
- kStart
- kEnd
Parameters
- eType
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
