IC8 Python API:RLPy RScene
Contents
- 1 Description
- 2 Constructor & Destructor
- 3 Member Functions
- 3.1 AddSwitchCameraKey (kSetTime, spCamera)
- 3.2 ClearSelectObjects ()
- 3.3 ClearSwitchCameraKeys ()
- 3.4 CreateCollection (strNewCollectionName)
- 3.5 DeleteCollection (strCollectionName)
- 3.6 FindChildObjects (spObject, eType, bAllLevel=True)
- 3.7 FindObject (eType, strName)
- 3.8 FindObjects (*args)
- 3.9 GetAvatars (*args)
- 3.10 GetBuildings ()
- 3.11 GetCameras ()
- 3.12 GetCurrentCamera ()
- 3.13 GetMDProps ()
- 3.14 GetProps ()
- 3.15 GetRootNode ()
- 3.16 GetSelectedObjects ()
- 3.17 GetSwitchCameraFrameIndexs (kFps)
- 3.18 Hide (spObject)
- 3.19 MoveToCollection (*args)
- 3.20 QueryObjectByID (strID)
- 3.21 RemoveObject (spObject)
- 3.22 SelectObject (spObject)
- 3.23 SelectObjects (kObjects)
- 3.24 SetCurrentCamera (spCamera)
- 3.25 Show (spObject)
- 4 Properties
Description
An animation project will usually contain all sorts of objects, such as characters, props, lights, cameras, particle systems, etc. The RScene class is used to manage these objects in the scene. It provides many functions for users to find and access these objects. RScene is a static class that can be used directly without having to create an instance. This class provides functions for finding objects by name or type, deleting object, showing / hiding objects, getting and setting selected object, and so on. See Also: RIObject, RIAvatar, RIProp
__init__ (self)
Initializes a new scene instance.
Member Functions
Adds key on camera switcher.
Parameters
- kSetTime
- spCamera
Deselect everything in the scene.
Clears all key on camera switcher.
Creates collection.
Parameters
- strNewCollectionName
Deletes collection.
Parameters
- strCollectionName
Finds all child objects of the specified object type from the object.
Parameters
- spObject
- eType
- bAllLevel (default: True)
Searches for an object by name and type. Returns the first object that fulfills the search criteria.
Parameters
- eType
- strName
FindObjects (*args)
Searches for all objects that match by name and type. See Also: FindObject
Parameters
- args
GetAvatars (*args)
Get all the characters in the scene. The search results can be filtered by avatar type. See Also: FindObject, FindObjects
Parameters
- args
GetBuildings ()
Gets all buildings in the scene.
GetCameras ()
Gets all cameras in the scene.
GetCurrentCamera ()
Gets the current camera in the scene.
GetMDProps ()
Gets all MD props in the scene.
GetProps ()
Get all the props in the scene. See Also: FindObject, FindObjects
GetRootNode ()
Gets the root node of the scene.
Get all the selected object in the scene. If no objects are selected then return an empty list. See Also: SelectObject, SelectObjects, ClearSelectObjects
Gets the switch camera frame and camera in the scene.
Parameters
- kFps
Hide (spObject)
Hide an object in the scene. See Also: Show
Parameters
- spObject
Moves to collection.
Parameters
- args
Returns the scene object with the specified ID, if one is found.
Parameters
- strID
Remove an object from the scene. See Also: Show
Parameters
- spObject
Select an object in the scene. See Also: SelectObjects, ClearSelectObjects, GetSelectedObjects
Parameters
- spObject
Select several objects in the scene. See Also: SelectObject, ClearSelectObjects, GetSelectedObjects
Parameters
- kObjects
Sets the current camera in the scene.
Parameters
- spCamera
Show (spObject)
Display an object in the scene. See Also: Hide
Parameters
- spObject
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
