IC8 Python API:RLPy RTcpCallback
From Reallusion Wiki!
Jump to: navigation, search
Description
This class is used to monitor TCP/IP connection status and recieve connection data.
Constructor & Destructor
__init__ (self)
Initializes a new tcp callback instance.
Member Functions
OnDataReceived (self)
The application will call this function when a connection has been made and once the data has been received. Once this has been achieved, RLPy.RTcpClient.GetDataSize() can be used to establish a sized buffer ready to recieve the incoming data via RLPy.RTcpClient.GetDataAt(). See Also: RTcpClient, RLPy.RTcpClient.GetData(), RLPy.RTcpClient.GetDataAt(), RLPy.RTcpClient.GetDataSize()
OnFailMessageReceived (self, pErrorMsg)
This function is called by the application in the event that a connection can not be established or a connection error has occurred; In which case, an error message will be given.
Parameters
  • pErrorMsg
OnStatusChanged (self, bIsConnected)
Callback function when status changed.
Parameters
  • bIsConnected
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
