IC8 Python API:RLPy RTime
From Reallusion Wiki!
Jump to: navigation, search
Description
This class represents the midst unit (a.k.a unit of time) in animation. Currently, it provides two states: milliseconds and 60FPS (frames per second). When you create an animation key, you'll need to set the value according to the incoming time. This class also provides different unit conversions such as GetFrameIndex, IndexedFrameTime, and GetFrameTime to ensure that the time retrieved is aligned with animation frames.
Constructor & Destructor
__init__ (self)
This operation creates a time object instance.
Member Functions
FromValue (tTick)
Creates a time value from the supplied underlying value.
Parameters
  • tTick
Sample code
Demonstrates calls to `RLPy.RTime.FromValue`, `RLPy.RTime.ToDouble`, `RLPy.RTime.ToFloat`, `RLPy.RTime.ToInt`, `RLPy.RTime.ToInt64`, `RLPy.RTime.ToLong`, `RLPy.RTime.ToUInt32`, `RLPy.RTime.__eq__`, `RLPy.RTime.__ge__`, `RLPy.RTime.__gt__`, `RLPy.RTime.__iadd__`, `RLPy.RTime.__imul__`, `RLPy.RTime.__isub__`, `RLPy.RTime.__itruediv__`, `RLPy.RTime.__le__`, `RLPy.RTime.__lt__`, `RLPy.RTime.__ne__`, and `RLPy.RTime.__neg__` using the example's inputs.
import RLPy
def run_script():
    converted = RLPy.RTime.FromValue(1000)
    conversions = (
        RLPy.RTime.ToInt(converted),
        RLPy.RTime.ToInt64(converted),
        RLPy.RTime.ToLong(converted),
        RLPy.RTime.ToUInt32(converted),
        RLPy.RTime.ToFloat(converted),
        RLPy.RTime.ToDouble(converted),
    first = RLPy.RTime()
    second = RLPy.RTime()
    equal = first == second
    not_equal = first != second
    less = first < second
    less_equal = first <= second
    greater = second > first
    greater_equal = second >= first
    first += second
    first *= 2.0
    first -= second
    first /= 2.0
    negative = -first
    return (conversions, equal, not_equal, less, less_equal, greater, greater_equal, first.ToInt(), negative.ToInt())
ToDouble (self)
Returns this time value as a double-precision number.
Sample code
import RLPy
def run_script():
    conversions = (
    first += second
    first *= 2.0
    first -= second
    first /= 2.0
    negative = -first
ToFloat (self)
Returns this time value as a floating-point number.
Sample code
import RLPy
def run_script():
    conversions = (
    first += second
    first *= 2.0
    first -= second
    first /= 2.0
    negative = -first
ToInt (self)
Returns this time value as an integer.
Sample code
import RLPy
def run_script():
    conversions = (
    first += second
    first *= 2.0
    first -= second
    first /= 2.0
    negative = -first
ToInt64 (self)
Returns this time value as a 64-bit integer.
Sample code
import RLPy
def run_script():
    conversions = (
    first += second
    first *= 2.0
    first -= second
    first /= 2.0
    negative = -first
ToLong (self)
Returns this time value as a long integer.
Sample code
import RLPy
def run_script():
    conversions = (
    first += second
    first *= 2.0
    first -= second
    first /= 2.0
    negative = -first
ToUInt32 (self)
Returns this time value as an unsigned 32-bit integer.
Sample code
import RLPy
def run_script():
    conversions = (
    first += second
    first *= 2.0
    first -= second
    first /= 2.0
    negative = -first
__add__ (self, kTime)
The addition operator. Add two time objects together.
Parameters
  • kTime
Sample code
Calls `RLPy.RTime.__add__` with the inputs shown in the example.
def run_script():
    import RLPy
    # Addition operator
    time1 = RLPy.RTime(1000)
    time2 = RLPy.RTime(2000)
    time3 = time1 + time2
    print(time3)
__eq__ (self, kTime)
The "equal to" operator. Check if two time objects are equal.
Parameters
  • kTime
Sample code
import RLPy
def run_script():
    conversions = (
    first += second
    first *= 2.0
    first -= second
    first /= 2.0
    negative = -first
__ge__ (self, kTime)
Reports whether this value is greater than or equal to another value.
Parameters
  • kTime
Sample code
import RLPy
def run_script():
    conversions = (
    first += second
    first *= 2.0
    first -= second
    first /= 2.0
    negative = -first
__gt__ (self, kTime)
Reports whether this value is greater than another value.
Parameters
  • kTime
Sample code
import RLPy
def run_script():
    conversions = (
    first += second
    first *= 2.0
    first -= second
    first /= 2.0
    negative = -first
__iadd__ (self, kTime)
Adds another value to this value in place.
Parameters
  • kTime
Sample code
import RLPy
def run_script():
    conversions = (
    first += second
    first *= 2.0
    first -= second
    first /= 2.0
    negative = -first
__imul__ (self, tTimes)
Multiplies this value by another value in place.
Parameters
  • tTimes
Sample code
import RLPy
def run_script():
    conversions = (
    first += second
    first *= 2.0
    first -= second
    first /= 2.0
    negative = -first
__isub__ (self, kTime)
Subtracts another value from this value in place.
Parameters
  • kTime
Sample code
import RLPy
def run_script():
    conversions = (
    first += second
    first *= 2.0
    first -= second
    first /= 2.0
    negative = -first
__itruediv__ (self, *args)
Divides this value by another value in place.
Parameters
  • args
Sample code
import RLPy
def run_script():
    conversions = (
    first += second
    first *= 2.0
    first -= second
    first /= 2.0
    negative = -first
__le__ (self, kTime)
Reports whether this value is less than or equal to another value.
Parameters
  • kTime
Sample code
import RLPy
def run_script():
    conversions = (
    first += second
    first *= 2.0
    first -= second
    first /= 2.0
    negative = -first
__lt__ (self, kTime)
Reports whether this value is less than another value.
Parameters
  • kTime
Sample code
import RLPy
def run_script():
    conversions = (
    first += second
    first *= 2.0
    first -= second
    first /= 2.0
    negative = -first
__mul__ (self, tTimes)
The "multiplication" operator. Multiply two time objects.
Parameters
  • tTimes
Sample code
Calls `RLPy.RTime.__mul__` with the inputs shown in the example.
def run_script():
    import RLPy
    # Multiplication operator
    time1 = RLPy.RTime(100.0)
    time2 = time1 * 0.5
    print(time2)
__ne__ (self, kTime)
The "not equal to" operator. Check if two time object are not equal.
Parameters
  • kTime
Sample code
import RLPy
def run_script():
    conversions = (
    first += second
    first *= 2.0
    first -= second
    first /= 2.0
    negative = -first
__neg__ (self)
Returns the negated value.
Sample code
import RLPy
def run_script():
    conversions = (
    first += second
    first *= 2.0
    first -= second
    first /= 2.0
    negative = -first
__sub__ (self, kTime)
The 'subtraction' operator. Minus a time object from another.
Parameters
  • kTime
Sample code
Calls `RLPy.RTime.__sub__` with the inputs shown in the example.
def run_script():
    import RLPy
    # Subtraction operator
    time3 = time2 - time1
    print(time3)
__truediv__ (self, *args)
The "division" operator. Divide two time objects.
Parameters
  • args
Sample code
Calls `RLPy.RTime.__truediv__` with the inputs shown in the example.
def run_script():
    import RLPy
    # Division operator
    time1 = RLPy.RTime(3000)
    time2 = time1 / 150
    print(time2)
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
Constants
HALF_MAXIMUM
HALF_MINIMUM
MAXIMUM
MINIMUM
NEGATIVE_ONE
ONE
ZERO
