IC8 Python API:RLPy RTransformControl
Contents
- 1 Description
- 2 Constructor & Destructor
- 3 Member Functions
- 4 Properties
Description
This class manages RTransformKey on the RTransform. RTransformControl can use GetValue, SetValue, GetTransformKey, and GetTransformKeyAt to access Transform Key values at a given point in time. It can also extrapolate the proper value between two keys. See Also: RControl, RFloatControl, RTransformKey, RTransform.
__init__ (self, *args, **kwargs)
Initializes a new transform control instance.
Parameters
- args
- kwargs
Member Functions
GetRotationOrder (self, eOrder)
Gets euler rotation order.
Parameters
- eOrder
GetTransformKey (self, kTick, pKey)
Get the Transform Key at a given point in time in this Transform Control. See Also: GetTransformKeyAt, RTransformKey.
Parameters
- kTick
- pKey
GetTransformKeyAt (self, uIndex, pKey)
Get the Transform Key at a given index in this Transform Control. See Also: GetTransformKey, RTransformKey.
Parameters
- uIndex
- pKey
GetValue (self, kTick, kValue)
Get the value of a Transform Key in this Transform Control at a given point in time. See Also: SetValue
Parameters
- kTick
- kValue
SetValue (self, kTick, kValue)
Set the value of a Transform Key in this Transform Control at a given point in time. See Also: GetValue
Parameters
- kTick
- kValue
SetValueAt (self, uIndex, kValue)
Sets the value at.
Parameters
- uIndex
- kValue
UpdateData (self)
Updates Key Times. (Internal used).
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
