IC8 Python API:RLPy RUdpCallback
Contents
Description
This class is used to monitor UDP connection status and recieve connection data.
Constructor & Destructor
__init__ (self)
Initializes a new udp callback instance.
Member Functions
OnDataReceived (self)
The application will call this function when a connection has been made and once the data has been received. Once this has been achieved, RLPy.RTcpClient.GetDataSize() can be used to establish a sized buffer ready to recieve the incoming data via RLPy.RTcpClient.GetDataAt(). See Also: RUdpClient, RLPy.RUdpClient.GetData(), RLPy.RUdpClient.GetDataAt(), RLPy.RUdpClient.GetDataSize()
OnFailMessageReceived (self, pErrorMsg)
This function is called by the application in the event that a connection can not be established or a connection error has occurred; In which case, an error message will be given.
Parameters
- pErrorMsg
OnStatusChanged (self, bIsConnected)
The application will call this function when there is a change in connection status; In which case, the new status message will be given.
Parameters
- bIsConnected
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
