IC8 Python API:RLPy RUi
Contents
- 1 Description
- 2 Constructor & Destructor
- 3 Member Functions
- 3.1 AddContextAction (spObject, strText)
- 3.2 AddContextMenu (spObject, strText)
- 3.3 AddHotKey (strKeySequence)
- 3.4 AddMenu (*args)
- 3.5 CallLuaFunction (strFilePath, strFunction, kParam, kReturn)
- 3.6 ClearViewportLabels (strOwnerId)
- 3.7 CreateRDialog (*args)
- 3.8 CreateRDockWidget (*args)
- 3.9 FindMenu (*args)
- 3.10 FindToolBar (strToolBarName)
- 3.11 GetCSSType ()
- 3.12 GetMainWindow ()
- 3.13 GetResolutionType ()
- 3.14 IsProgressCancel ()
- 3.15 LoadLuaUI (strFilePath)
- 3.16 OpenFileDialog (*args)
- 3.17 OpenFilesDialog (*args)
- 3.18 PopProgress ()
- 3.19 PushProgress (fProgress)
- 3.20 RemoveContextAction (spObject, pAction)
- 3.21 RemoveContextMenu (spObject, pMenu)
- 3.22 RemoveHotKey (pAction)
- 3.23 RemoveMenu (pMenu)
- 3.24 SaveFileDialog (*args)
- 3.25 SetProgressStatusString (strStatus)
- 3.26 SetViewportLabels (ownerId, labels, defaultTextStyle=None)
- 3.27 ShowMessageBox (*args)
- 3.28 ShowProgressDialog (bShow, bCancelable=False, bPauseRender=True)
- 4 Properties
Description
This class is a package of instructions related to the application user interface (UI). It includes the ability to bridge communication between plugins and the application UI system, provides operations for the main window and menu, application version settings, show message boxes, open file browse dialog, as well as adding RIDialog and RIDockWidget related components, and much more. By using this class, developers can define plugin behaviors via custom user interfaces to achieve their goals.
__init__ (self)
Initializes a new ui instance.
Member Functions
Adds context action.
Parameters
- spObject
- strText
Adds context menu.
Parameters
- spObject
- strText
Create and register a hotkey event. The input hotkey string will be compared with the keys within QKeySequence of the Qt component and returns a QAction address. If the given hotkey is already registered to another event, then the previous event will be replaced by the newly registered hotkey event. In order to revert to the previous event, one must first unregister the current event.
Parameters
- strKeySequence
Sample code
Register a Tab shortcut and remove it in a finally block.
def run_script():
import RLPy
hotkey = RLPy.RUi.AddHotKey("tab")
if hotkey is None:
raise RuntimeError("AddHotKey did not return an action.")
try:
pass
finally:
result = RLPy.RUi.RemoveHotKey(hotkey)
assert result == RLPy.RStatus.Success
Preconditions
- Before running, confirm that Tab is not already assigned to another action; AddHotKey can replace an existing Tab event.
Side Effects
- Temporarily registers Tab. If Tab already has an event, AddHotKey replaces it, and RemoveHotKey does not restore the previous event.
AddMenu (*args)
Currently, this function can only create menu items within the Plugins menu. The Qmenu address is returned upon creation.
Parameters
- args
Sample code
Add a uniquely named item to the Plugins menu.
def run_script():
import uuid
import RLPy
menu_name = "Codex API sample " + uuid.uuid4().hex
menu_item = RLPy.RUi.AddMenu(menu_name, RLPy.EMenu_Plugins)
assert menu_item is not None
Side Effects
- Adds a uniquely named item to the Plugins menu. The item remains after run_script returns; this sample does not remove it.
Call Lua function.
Parameters
- strFilePath
- strFunction
- kParam
- kReturn
Removes all viewport labels owned by strOwnerId.
Parameters
- strOwnerId
Create either a normal or exclusive dialog object and return it. A normal dialog can exist among other instances at the same time, while exclusive means that only one instance can be displayed at any given time.
Parameters
- args
Create a new dock widget object and return it as RIDockWidget.
Parameters
- args
FindMenu (*args)
Find submenu under Plugin menu, create if not found.
Parameters
- args
Find toolbar, create if not exist.
Parameters
- strToolBarName
GetCSSType ()
Get the current application cascading style sheet (CSS) settings.
GetMainWindow ()
Get the QWidget address for the main window. You can bind the main window to a PySide object by using this function, for UI operations.
Sample code
Retrieve the application's main window handle.
def run_script():
import RLPy
main_window = RLPy.RUi.GetMainWindow()
Get the application resolution settings.
IsProgressCancel ()
Checks if the user has requested to cancel the operation.
Loads Lua UI.
Parameters
- strFilePath
Browse for a file by opening the file open dialog window according to the extension filter and a starting directory. If the starting directory is an empty string, then it will automatically browse to the last directory location recorded by the application as the opening path. See also: OpenFilesDialog
Parameters
- args
Sample code
Open a JSON file-selection dialog and return the selected path, if any.
def run_script():
import RLPy
selected_path = RLPy.RUi.OpenFileDialog("Json Files(*.json)")
return selected_path
Preconditions
- Run in an interactive iClone session.
Side Effects
- Displays a modal dialog until the user selects a path or cancels.
Browse for multiple files by opening the file open dialog window according to the extension filter and a starting directory. If the starting directory is an empty string, then it will automatically browse to the last directory location recorded by the application as the opening path. See also: OpenFileDialog
Parameters
- args
PopProgress ()
Updates the progress and pops the current task from the progress stack.
Pushes a new task onto the progress stack.
Parameters
- fProgress
Removes context action.
Parameters
- spObject
- pAction
Removes context menu.
Parameters
- spObject
- pMenu
Remove a hotkey event registered to the given QAction address.
Parameters
- pAction
Sample code
def run_script():
import RLPy
if hotkey is None:
try:
pass
finally:
Preconditions
Side Effects
RemoveMenu (pMenu)
Remove a menu item from the main window. Currently, this function only supports removal of menu items from the Plugins menu.
Parameters
- pMenu
Launch a save file dialog window and save a file to a specified file path. The possible file types can be restricted by the strFilter parameter. Once a file is saved, its absolute path is returned.
Parameters
- args
Sample code
Open a JSON save dialog and return the selected path, if any.
def run_script():
import RLPy
selected_path = RLPy.RUi.SaveFileDialog("Json Files(*.json)")
Preconditions
Side Effects
Sets progress dialog status string.
Parameters
- strStatus
Replaces the viewport labels owned by strOwnerId.
Parameters
- ownerId
- labels
- defaultTextStyle
Displays a message box with the configured button choices and returns the selected button status.
Parameters
- args
Show progress dialog.
Parameters
- bShow
- bCancelable (default: False)
- bPauseRender (default: True)
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
