IC8 Python API:RLPy RVariant
From Reallusion Wiki!
Jump to: navigation, search
Description
This class acts like an union for common data types. A RVariant object holds a single value of a specified type T at a time. You can use GetType to find out what type the variant holds, and get its value by one of the ToT() functions, e.g. ToInt32. Currently, there are two types supported: float and int.
Constructor & Destructor
__init__ (self, *args)
Initializes a new variant instance.
Parameters
  • args
Member Functions
GetType (self)
Get type of this RVariant object.
Sample code
Demonstrates calls to `RLPy.RVariant.GetType`, `RLPy.RVariant.ToBool`, and `RLPy.RVariant.ToString` using the example's inputs.
import RLPy
def run_script():
    number = RLPy.RVariant(-10)
    number_type = number.GetType()
    as_bool = number.ToBool()
    text = RLPy.RVariant("sample text")
    text_type = text.GetType()
    as_text = text.ToString()
    return (number_type, as_bool, text_type, as_text)
ToBool (self, pSuccess=None)
Converts to bool.
Parameters
  • pSuccess
Sample code
import RLPy
def run_script():
ToFloat (self, pSucess=None)
Convert to float. See Also: ToInt32, ToUInt32
Parameters
  • pSucess
Sample code
Calls `RLPy.RVariant.ToFloat` with the inputs shown in the example.
def run_script():
    import RLPy
    x = RLPy.RVariant(-10)
    f = x.ToFloat()
    print(f)
ToInt32 (self, pSucess=None)
Convert to int32_t. See Also: ToFloat, ToUInt32
Parameters
  • pSucess
Sample code
Calls `RLPy.RVariant.ToInt32` with the inputs shown in the example.
def run_script():
    import RLPy
    f = RLPy.RVariant(-10.0)
    x = f.ToInt32()
    print(x)
ToString (self, pSuccess=None)
Converts to string.
Parameters
  • pSuccess
Sample code
import RLPy
def run_script():
ToUInt32 (self, pSucess=None)
Convert to uint32_t. See Also: ToFloat, ToInt32
Parameters
  • pSucess
Sample code
Calls `RLPy.RVariant.ToUInt32` with the inputs shown in the example.
def run_script():
    import RLPy
    f = RLPy.RVariant(10.0)
    x = f.ToUInt32()
    print(x)
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
Constants
Bool
Float
InValid
Int32
String
UInt32
