IC8 Python API:RLPy RVisemeSmoothOption
Contents
- 1 Description
- 2 Constructor & Destructor
- 3 Member Functions
- 3.1 GetSmoothEnableSetting (self)
- 3.2 GetSmoothValueSetting (self)
- 3.3 GetStrengthEnableSetting (self)
- 3.4 GetStrengthValueSetting (self)
- 3.5 SetSmoothEnable (self, bJawEnable, bLipsEnable, bTongueEnable)
- 3.6 SetSmoothValue (self, fJaw, fLips, fTongue)
- 3.7 SetStrengthEnable (self, bJawEnable, bLipsEnable, bTongueEnable)
- 3.8 SetStrengthValue (self, fJaw, fLips, fTongue)
- 4 Properties
Description
This class is responsible for recording viseme smooth and strength settings for parts of the mouth: jaw, lips and tongue. These settings can be fed into a RIVisemeComponent using RIVisemeComponent.AddVisemeOptionClip().
__init__ (self)
Initializes a new viseme smooth option instance.
Member Functions
Get all the viseme smoothing states for the mouth parts. See Also: GetSmoothValueSetting
Sample code
Calls `RLPy.RVisemeSmoothOption.GetSmoothEnableSetting` with the inputs shown in the example.
def run_script():
import RLPy
# Get smooth enable state
viseme_smooth_option = RLPy.RVisemeSmoothOption()
enable_list = viseme_smooth_option.GetSmoothEnableSetting()
print(enable_list[0]) # Jaw smooth enable status
print(enable_list[1]) # Lips smooth enable status
print(enable_list[2]) # Tongue smooth enable status
Get all the viseme smoothing values for the mouth parts. See Also: GetSmoothEnableSetting
Sample code
Calls `RLPy.RVisemeSmoothOption.GetSmoothValueSetting` with the inputs shown in the example.
def run_script():
import RLPy
# Get smooth values
value_list = viseme_smooth_option.GetSmoothValueSetting()
print(value_list[0]) # Jaw smooth value
print(value_list[1]) # Lips smooth value
print(value_list[2]) # Tongue smooth value
Get all the viseme strengthening states for the mouth parts. See Also: GetStrengthValueSetting
Sample code
Calls `RLPy.RVisemeSmoothOption.GetStrengthEnableSetting` with the inputs shown in the example.
def run_script():
import RLPy
# Get strength enable state
enable_list = viseme_smooth_option.GetStrengthEnableSetting()
print(enable_list[0]) # Jaw strength enable status
print(enable_list[1]) # Lips strength enable status
print(enable_list[2]) # Tongue strength enable status
Get all the viseme strength values for the mouth parts. See Also: GetStrengthEnableSetting
Sample code
Calls `RLPy.RVisemeSmoothOption.GetStrengthValueSetting` with the inputs shown in the example.
def run_script():
import RLPy
# Get strength values
value_list = viseme_smooth_option.GetStrengthValueSetting()
print(value_list[0]) # Jaw strength value
print(value_list[1]) # Lips strength value
print(value_list[2]) # Tongue strength value
Enable/disable viseme smoothing for parts of the mouth.
Parameters
- bJawEnable
- bLipsEnable
- bTongueEnable
Sample code
Calls `RLPy.RVisemeSmoothOption.SetSmoothEnable` with the inputs shown in the example.
def run_script():
import RLPy
# Set smooth enable
jaw_enable = False
lips_enble = True
tongue_enble = False
viseme_smooth_option.SetSmoothEnable(jaw_enable, lips_enble, tongue_enble)
Set the viseme smoothing values for parts of the mouth. See Also: SetSmoothEnable
Parameters
- fJaw
- fLips
- fTongue
Sample code
Calls `RLPy.RVisemeSmoothOption.SetSmoothValue` with the inputs shown in the example.
def run_script():
import RLPy
# Set strength value
jaw_value = 0.4
lips_value = 0.2
tongue_value = 0.7
viseme_smooth_option.SetSmoothValue(jaw_value, lips_value, tongue_value)
Enable/disable viseme strengthening for parts of the mouth. See Also: SetStrengthValue
Parameters
- bJawEnable
- bLipsEnable
- bTongueEnable
Sample code
Calls `RLPy.RVisemeSmoothOption.SetStrengthEnable` with the inputs shown in the example.
def run_script():
import RLPy
# Set strength enable
jaw_enable = True
lips_enble = False
tongue_enble = True
viseme_smooth_option.SetStrengthEnable(jaw_enable, lips_enble, tongue_enble)
Set the viseme strength values for parts of the mouth.
Parameters
- fJaw
- fLips
- fTongue
Sample code
Calls `RLPy.RVisemeSmoothOption.SetStrengthValue` with the inputs shown in the example.
def run_script():
import RLPy
jaw_value = 0.4
lips_value = 0.5
tongue_value = 0.6
viseme_smooth_option.SetStrengthValue(jaw_value, lips_value, tongue_value)
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
