IC 8 Python API:Smart Content Manager
From Reallusion Wiki!
Jump to: navigation, search
Main article: iC8 Python API.
In order to share folders and integrate shared content between iClone and Character Creator and avoid repeated downloads that waste storage space, the Content Manager of iClone 8 uses a database to manage the user's Content. Keep in mind that RLPy.RApplication.GetTemplateDataPath() cannot obtain the absolute path of the template directory, instead, the database needs to be queried to get the correct path. This means you'll have to feed the proper content type key into RLPy.RApplication.GetDefaultContentFolder() to obtain the relative path of the template directory, or use RLPy.RApplication.GetCustomContentFolder() to obtain the relative path of the custom directory
See the section below on Content Type Keys for an enumeration of the possible values.
Finally, you'll need to use RLPy.RApplication.GetContentFoldersInFolder() to obtain the relative path of the subdirectory under it, and use RLPy.RApplication.GetContentFilesInFolder() to obtain the actual path of the file. The procedure is as follows:
 1 # get content folder recursively
 2 def get_all_content_folders(_folder, all_content_folders):
 3     content_folders = RLPy.RApplication.GetContentFoldersInFolder(_folder)
 4     for sub_folder in content_folders:
 5         all_content_folders.append(sub_folder)
 6         print("sub_folder :"+sub_folder)
 7         get_all_content_folders(sub_folder, all_content_folders)
 8
 9 # Get the default content folder
10 content_key = RLPy.ETemplateRootFolder_Character
11 def_folder = RLPy.RApplication.GetDefaultContentFolder(content_key)
12 print(def_folder)
13 # $/Actor/Character
14
15 # Get particle content folder
16 all_content_folders = []
17 get_all_content_folders(default_content_folder, all_content_folders)
18 # $/Actor/Character/ActorCore Crowd/, $/Actor/Character/ActorCore/...
19
20 # Get all files for the folder in all_content_folders:
21     real_files = RLPy.RApplication.GetContentFilesInFolder(folder)
22     for files in real_files:
23         print("files :"+files )
24 # C:/Users/Public/Documents/Reallusion/Reallusion Templates/Actor/Character/ActorCore/Kevin actorBuild.iAvatar
Content Type Keys
The possible content type values are enumerated below:
# Project
ETemplateRootFolder_Project
# Character
ETemplateRootFolder_AvatarControl
ETemplateRootFolder_FacialProfile
ETemplateRootFolder_Teeth
ETemplateRootFolder_Eye
ETemplateRootFolder_Face
ETemplateRootFolder_RLHead
ETemplateRootFolder_Oral
ETemplateRootFolder_Upper
ETemplateRootFolder_Lower
# Avatar Preset
ETemplateRootFolder_FullBodyMorphSkin
ETemplateRootFolder_HeadMorphSkin
ETemplateRootFolder_BodyMorph
ETemplateRootFolder_AvatarPresetEyelash
ETemplateRootFolder_Nail
# Skin
ETemplateRootFolder_Overall
ETemplateRootFolder_FullSkin
ETemplateRootFolder_SkinBase
ETemplateRootFolder_NormalEffects
ETemplateRootFolder_SkinDetails
ETemplateRootFolder_Blemish
ETemplateRootFolder_Acquired
ETemplateRootFolder_BodyHair
ETemplateRootFolder_Nails
ETemplateRootFolder_SkinGenTools
# Makeup
ETemplateRootFolder_FullMakeup
ETemplateRootFolder_FoundationMakeup
ETemplateRootFolder_EyeMakeup
ETemplateRootFolder_MakeupEyelash
ETemplateRootFolder_LipMakeup
ETemplateRootFolder_Eyebrow
ETemplateRootFolder_Miscellaneous
ETemplateRootFolder_MakeupSkinGenTools
# Hair
ETemplateRootFolder_Style
ETemplateRootFolder_Group
ETemplateRootFolder_Element
# Cloth
ETemplateRootFolder_Underwear
ETemplateRootFolder_Shirts
ETemplateRootFolder_Pants
ETemplateRootFolder_Skirts
ETemplateRootFolder_Coats
ETemplateRootFolder_ClothOthers
ETemplateRootFolder_Gloves
ETemplateRootFolder_Shoes
# Accessory
ETemplateRootFolder_Torso
ETemplateRootFolder_Arm
ETemplateRootFolder_Leg
ETemplateRootFolder_AccessoryOthers
# Animation
ETemplateRootFolder_MotionPlus
ETemplateRootFolder_Expression
ETemplateRootFolder_Gesture
ETemplateRootFolder_Pose
ETemplateRootFolder_MotionDirector
ETemplateRootFolder_Persona
ETemplateRootFolder_iAnimation
# Stage
ETemplateRootFolder_LightRoom
ETemplateRootFolder_Atmosphere
ETemplateRootFolder_Camera
ETemplateRootFolder_PostEffect
ETemplateRootFolder_ImageLayer
ETemplateRootFolder_Scene3D
ETemplateRootFolder_Material
ETemplateRootFolder_MaterialPlus
ETemplateRootFolder_Background2D
ETemplateRootFolder_Texture
# Stage/Texture
ETemplateRootFolder_Diffuse
ETemplateRootFolder_Opacity
ETemplateRootFolder_Bump
ETemplateRootFolder_Glow
ETemplateRootFolder_Reflection
ETemplateRootFolder_Specular
ETemplateRootFolder_Blend
ETemplateRootFolder_Displacement
ETemplateRootFolder_IBL
ETemplateRootFolder_WeightMap
ETemplateRootFolder_Metallic
ETemplateRootFolder_Roughness
ETemplateRootFolder_AO
ETemplateRootFolder_LensFlare
ETemplateRootFolder_IES
ETemplateRootFolder_IMDL
# Set
ETemplateRootFolder_Tree
ETemplateRootFolder_Grass
ETemplateRootFolder_Particle
ETemplateRootFolder_Terrain
ETemplateRootFolder_Water
ETemplateRootFolder_Sky
ETemplateRootFolder_MotionPath
# Props
ETemplateRootFolder_Props
# Media
ETemplateRootFolder_Sound
ETemplateRootFolder_Video
# Other
ETemplateRootFolder_Digital_Human_Shader_Resource
ETemplateRootFolder_SSS_Shader_Resource
ETemplateRootFolder_Spring
ETemplateRootFolder_LuaScript
# Profile
ETemplateRootFolder_MotionPuppet
ETemplateRootFolder_FacePuppet
ETemplateRootFolder_SubstancePreset
ETemplateRootFolder_ContentPatch
ETemplateRootFolder_SpringProfile
