IC8 Python API:RLPy RFloatControl
Contents
- 1 Description
- 2 Class Methods
- 3 Description
- 4 Constructor & Destructor
- 5 Member Functions
- 6 Properties
- Main article: iC8 Modules.
- Last modified: 10/21/2026
Description
This class is used to manage float keys ( RFloatKey ). RFloatControl can access RFloatKey via SetValue and GetValue. GetValue can retrieve the key value at a requested time, and if a key does not exist then it will return the nearest float key value.
Class Methods
RLPy.RFloatControl.GetValue(self, kTick, fValue, fDefaultValue = 0.0)
Get key value by time.
Parameters
- kTime[IN] Specifies the time to get value.
fValue[OUT] Value of the key - float
Returns
- RLPy.RStatus.Success - Succeed
- RLPy.RStatus.Failure - Fail
1 avatar_list = RLPy.RScene.GetAvatars()
2 avatar = avatar_list[0]
3
4 # get value
5 float_control = avatar.GetControl("PathPosition")
6 print(float_control.GetValue(time,value))
RLPy.RFloatControl.OptimizeKeys(self, kBeginTime, kEndTime, kFps, fError = 0.5)
Optimize Keys.
Parameters
- kBeginTime[IN] Specifies the time to start - RLPy.RLTime
- kEndTime[IN] Specifies the time to end - RLPy.RLTime
- kFps[IN] Specifies the fps - RLPy.RLFps
- fError[IN] Specifies the error value - float
Returns
1 # No example
RLPy.RFloatControl.ReserveKeyCapacity(self, uSize)
reserve key capacity.
Parameters
- uSize[IN] Size - int
Returns
1 # No example
RLPy.RFloatControl.SetValue(self, args)
Set key value by time.
Parameters
- fValue[IN] Value of the key - float
Returns
3
4 # set value
6 value = 1
7 float_control.SetValue(RLPy.RTime(100),value)
Description
This class is used to manage float keys ( RFloatKey ). RFloatControl can access RFloatKey via SetValue and GetValue. GetValue can retrieve the key value at a requested time, and if a key does not exist then it will return the neartes float key value. See Also: RKey, RFloatKey
__init__ (self, *args, **kwargs)
Initializes a new float control instance.
Parameters
- args
- kwargs
Member Functions
GetValue (self, kTick, fValue, fDefaultValue=0.0)
Get the float key value, if the key does not exist for the requested time then extract an interpolated value. See Also: SetValue
Parameters
- kTick
- fValue
- fDefaultValue (default: 0.0)
OptimizeKeys (self, kBeginTime, kEndTime, kFps, fError=0.5)
Optimizes Keys.
Parameters
- kBeginTime
- kEndTime
- kFps
- fError (default: 0.5)
RemoveKeys (self, kTicks)
Removes multiple keys from the control by time.
Parameters
- kTicks
ReserveKeyCapacity (self, uSize)
Reserve key capacity.
Parameters
- uSize
SetValue (self, *args)
Set the float key value for the requested time. See Also: GetValue
Parameters
- args
SetValueAt (self, uIndex, fValue)
Sets the float value at the specified key index.
Parameters
- uIndex
- fValue
SyncAdapterToControl (self)
Sync adapter to venus.
Properties
thisown
Indicates whether this SWIG proxy owns the underlying C++ object.
