Content Dev:CTA Thumbnailing
From Reallusion Wiki!
- Main article: CTA Prop Creation.
Provided Files
Use the following files to help you create thumbnails:
File | Description and Usage | Note | Download |
Prop.ctproject | For static props | Doesn't include render styles | Prop.rar |
Ani Prop.ctproject | For animated props | Doesn't included render styles | Ani_Prop.rar |
Thumbnail Creation Process
Static Props
(1) Open the Prop.ctproject and bring the prop onto the stage.
(2) Perform Export > Image.
- The stage will turn into a square aspect ratio -- because thumbnails are square.
(3) Scale the prop to fill the square stage.
(4) Go to Render Settings > Export to create a thumbnail image.
The thumbnail image will be exported in 300x300 pix size
Animated Props
(1) Open Ani Prop.ctproject
- Notice the Ani displayed in the upper left corner.
(2) Bring the finished animated prop onto the stage.
(3) Perform Export > Image and resize the image to fit the square stage.
(4) Press the Export button to create a 300x300 px image.
The Ani display text tells the user that this prop has motion.
Applying the Thumbnail Image
(1) Perform Content Manager > Load Thumbnail.
(2) Select the appropriate thumbnail made by using the aforementioned steps.
- Developers have direct control over the image of the thumbnail.
