IC Python API:RLPy RStatus
From Reallusion Wiki!
- Main article: Modules.
- Last modified: 04/14/2020
Description
This class facilitates error handling for each API. It encapsulates the status code as a return value for each API function. Developers can query, set, or output status codes through this class. The RStatus codes and their instructions are listed below:
| Constant | Value |
| RStatus.Success | The operation was successful. |
| RStatus.Failure | The operation failed. |
| RStatus.InsufficientMemory | The operation failed due to insufficient memory. |
| RStatus.LicenseFailure | Application is not licensed for the attempted operation. |
| RStatus.IncompatibleVersion | The applied operation is not compatible with the current version. |
| RStatus.InvalidParameter | An invalid parameter was provided. |
| RStatus.UnknownParameter | The operation was called with an unrecognized argument. |
| RStatus.NotImplemented | This operation has not been implemented. |
| RStatus.Deprecated | This operation has been deprecated. |
| RStatus.NotFound | Not currently used. |
| RStatus.EndOfFile | Not currently used. |
Member Functions
Clear( self )
Clear the current error status. Success status code is returned upon calling this function.
See also: IsError( self )
1 status = RLPy.RGlobal.SetTime(RLPy.RTime(1000))
2 if status == RLPy.RStatus.Failure:
3 print("failure")
4 status.Clear()
5 print(status.IsError()) # False
GetStatusCode ( self )
Get the current status code. Refer to the status code table above.
Returns
- Return the internal status code - int
- RLPy.RStatus.Success
- RLPy.RStatus.Failure
- RLPy.RStatus.InsufficientMemory
- RLPy.RStatus.LicenseFailure
- RLPy.RStatus.IncompatibleVersion
- RLPy.RStatus.InvalidParameter
- RLPy.RStatus.UnknownParameter
- RLPy.RStatus.NotImplemented
- RLPy.RStatus.Deprecated
- RLPy.RStatus.NotFound
- RLPy.RStatus.EndOfFile
1 if status.GetStatusCode() == RLPy.RStatus.Success:
2 print("sucess") # print sucess
IsError( self )
Check whether the current status is an error.
Returns
- True: An error has occured.
- False: No error.
3 if status == RLPy.RStatus.Success:
4 print("sucess") # print sucess
5
6 if status == RLPy.RStatus.Failure:
7 print("failure")
8 status.Clear()
9 print(status.IsError()) # False
10
11 if status.GetStatusCode() == RLPy.RStatus.Success:
12 print("sucess") # print sucess
13
14 print(status.IsError())
