IC Python API:RLPy RINode
From Reallusion Wiki!
Jump to: navigation, search
Main article: Modules. Last modified: 04/14/2020
Description
This class is used to access node parameters in a character skeleton or scene object. Retrievable parameters include name, ID, parent node, list of child nodes, and more. Update to get the world-transform of the bone node for the current point in time.
Inheritance
RIBase > RINode
Member Functions
GetName ( self )
Get the name of the node in a character skeleton or scene object.
Returns
Name of the node - str
1 # Get root bone
2 avatar_list = RLPy.RScene.GetAvatars()
3 avatar = avatar_list[0]
4 skeleton_component = avatar.GetSkeletonComponent()
5 root_bone = skeleton_component.GetRootBone()
6
7 # Get root bone node name
8 node_name = root_bone.GetName()
9 print(node_name)
GetID ( self )
Get the ID of the node in a character skeleton or scene object.
Returns
ID of the node - int
1 # Get root bone
6
7 # Get root bone node ID
8 node_id = root_bone.GetID()
9 print(node_id)
GetParent ( self )
Get the parent node of the bone node in a character skeleton or scene object. If a parent does not exist, then return None.
Returns
Parent node - RINode
No parent node - None
1 # Get root bone
6
7 # Get root bone parent node
8 parent_node = root_bone.GetParent()
9 print(parent_node)
GetChildren ( self )
Get a list of child nodes for a node in a character skeleton or scene object. If this node does not have child nodes, then return None.
See Also: GetParent
Returns
List of child nodes - RINode list
No child nodes - None
1 # Get root bone
6
7 # Get root bone children node list
8 children_node_list = root_bone.GetChildren()
9 print(children_node_list)
LocalTransform ( self )
Get the local-transform for a node in a character skeleton or scene object.
See Also: WorldTransform
Returns
Node local-transform - RTransform
1 # Get root bone
6
7 # Get root bone local transform
8 local_transform = root_bone.LocalTransform()
9 print(local_transform)
WorldTransform ( self )
Get the world-transform for a node in a character skeleton or scene object.
See Also: LocalTransform
Returns
Node world-transform - RTransform
1 # Get root bone
6
7 # Get root bone world transform
8 world_transform = root_bone.WorldTransform()
9 print(world_transform)
WorldToLocal ( self, kWorldMatrix )
Convert the world-transform matrix for a node in a character skeleton or scene object to local-transform matrix.
See Also: LocalToWorld
Parameters
kWorldMatrix [IN] Node world-transform matrix - RMatrix4
Returns
Node local-transform matrix - RMatrix4
 1 # Get root bone
 6
 7 # Transfer root bone world transform matrix to local transform matrix
 9 world_matrix = world_transform.Matrix()
10 world_to_local = bone.WorldToLocal(world_matrix)
11 print(world_to_local)
LocalToWorld ( self, kLocalMatrix )
Convert the local-transform matrix for a node in a character skeleton or scene object to world-transform matrix.
See Also: WorldToLocal
Parameters
kLocalMatrix [IN] Node local-transform matrix - RMatrix4
Returns
1 # Transfer root bone local transform matrix to world transform matrix
2 local_transform = root_bone.LocalTransform()
3 local_matrix = local_transform.Matrix()
4 local_to_world = bone.LocalToWorld(local_matrix)
5 print(local_to_world)
Update ( self )
Update the Transform Control for a node in a character skeleton or scene object and update the scene. After the Update, the Transform Control's key values will reflect the world-transform values of the node for the current point in time.
 1 # Get root bone
 6
 7 # Get root bone child node world transform rotation x-axis value
 8 motion_bones = skeleton_component.GetMotionBones()
 9 child = motion_bones[1]
10 child_world = child.WorldTransform()
11 child_rot_x = child_world.R().x
12
13 # Set float control rotation x-axis value
14 RLPy.RGlobal.SetTime(RLPy.RTime(0))
15 animation_clip = skeleton_component.GetClip(0)
16 root_control = animation_clip.GetControl("Layer", root_bone)
17 data_block = root_control.GetDataBlock()
18 float_control_rotate_x = data_block.GetControl("Rotation/RotationX")
19 float_control_rotate_x.SetValue(RLPy.RGlobal.GetTime(), math.radians(60))
20
21 # Update root bone with float control
22 root_bone.Update()
23
24 # Get root bone child node world transform rotation x-axis value after updated
25 new_child_world = child.WorldTransform()
26 after_update_child_rot_x = new_child_world.R().x
