IC Python API:RLPy RIClip
From Reallusion Wiki!
(Redirected from IC Python API:RLPy RlClip)
Jump to: navigation, search
Main article: Modules. Last modified: 04/15/2020
Description
Animation keys reside in clips.
An animation clip representes a sequence of connected motions. Different types of animations can be derived from composing clips and applying various clip operations. Animation clips are recorded for each character bone node or a scene object itself. One can access an animation clip's transform control via RIClip, to facilitate subsequent key operations.
Inheritance
RIBase > RIClip
Member Functions
GetControl ( self, strKey, spNode )
Get the transform control for a character's bone node or scene object according to the clip index. At the present, only "Layer" is supported as the clip key. If the character's skeleton bone node or the scene object does not have a clip or if the clip index is larger than the total number of clips, return None.
Parameters
strKey [IN] Name for the clip key, currently only "Layer" is supported - string
spNode [IN] Character skeleton bone node or the scene object node - RIBase
Returns
The transform control on a character's skeleton bone node or scene object. - RControl
1 # Get skeleton component
2 avatar_list = RLPy.RScene.GetAvatars()
3 avatar = avatar_list[0]
4 bone = avatar.GetSkeletonComponent()
5
6 # Get transform control from bone root
7 clip_index = 1
8 clip = bone.GetClip(clip_index)
9 transform_control = clip.GetControl("Layer", bone.GetRootBone())
GetLength ( self )
Get the length of this clip. If this clip does not contain a key then return RTime(0).
Returns
The length of this clip - RTime
5
6 # Get clip length
7 clip_index = 1
9 clip_len = clip.GetLength()
SetLength ( self, kLength )
Set the length of this clip.
Parameters
kLength [IN] The desired clip length - RTime
Return
Success - RLPy.RStatus.Success
Failure - RLPy.RStatus.Failure
 5
 6 # Set clip length
 7 clip_index = 1
 9 clip_len = RLPy.RTime(2000)
10 clip.SetLength(clip_len)
GetLastKeyTime ( self )
Get the final key time on a scene object clip.
Returns
Time of the final key - RTime
5
6 # Get last key time
7 clip_index = 1
9 last_key_time = clip.GetLastKeyTime()
SceneTimeToClipTime ( self, kSceneTime )
Convert a point in time within the scene to clip time. If a given object does not have a clip or if the clip index exceeds the total number of clips, then return scene time instead.
See Also: ClipTimeToSceneTime
Parameters
kSceneTime [IN] Project scene time - RTime
Returns
Clip time at the corresponding scene time - RTime
 5
 6 # Scene time to clip time
 7 clip_index = 1
 9 scene_time = RLPy.RTime(13000)
10 clip_time = clip.SceneTimeToClipTime(scene_time)
ClipTimeToSceneTime ( self, kClipTime )
Convert a point in time within this clip to scene time. If a given object does not have a clip or if the clip index exceeds the total number of clips, then return the clip time instead.
See Also: SceneTimeToClipTime
Parameters
kClipTime [IN] Clip time - RTime
Returns
Clip time converted to scene time - RTime
 5
 6 # Clip time to scene time
 7 clip_index = 1
 9 clip_time = RLPy.RTime(2000)
10 scene_time = clip.ClipTimeToSceneTime(clip_time)
