IC Python API:RLPy RIAvatar
From Reallusion Wiki!
Jump to: navigation, search
Main article: Modules.
Inheritance
This class inherits public member functions from:
Detailed Description
This class is the interface to avatars in the scene. It provides methods to access various parts of an avatar such as its name, bones, etc. All methods of this class are implemented by the
system.
avatar = RLPy.RScene.FindObject( RLPy.EObjectType_Avatar, "Jade" )
# set name
avatar.SetName("new_name")
# get Name
avatar_name = avatar.GetName()
print(avatar_name) # Jade
# set Transform key
control = avatar.GetControl("Transform")
transform = RLPy.RTransform.IDENTITY
transform.T().x = 100.0
transform.T().y = 100.0
transform.T().z = 100.0
control.SetValue(RLPy.RTime(0), transform)
# get component
skeleton = avatar.GetSkeletonComponent()
print(skeleton.GetClipCount())
# set visible key
avatar.SetVisible(RLPy.RTime(600), False)
prop2 = RLPy.RScene.FindObject(RLPy.EObjectType_Prop, "Box2")
# iClone Avatar can't set Parent
# link to & unlink
result = avatar.LinkTo(prop2, RLPy.RTime(0))
result = avatar.UnLink(RLPy.RTime(0))
#get bound
ret_max = RLPy.RVector3()
ret_center = RLPy.RVector3()
ret_min = RLPy.RVector3()
ret = avatar.GetBounds( ret_max, ret_center, ret_min )
print(ret)
#get pivot
ret_pos = RLPy.RVector3()
ret_rot = RLPy.RVector3()
avatar.GetPivot( ret_pos, ret_rot )
print(ret)
#clone object
clone_avatar = avatar.Clone()
print( clone_avatar )
#is selected
RLPy.RScene.SelectObject(avatar)
print(avatar.IsSelected()) #True
Operators
This class supports the following operators:
Member Operation Syntax Description Example
__eq__ Equality a == b If the values of two operands are equal, then the condition becomes true. (a == b) is not true.
Member Functions
GetFaceComponent
RLPy.RIAvatar.GetFaceComponent ( self )
Get face component of the object. ( Experimental API )
Returns
Pointer of the RIFaceComponent object - RLPy.RIFaceComponent
GetHikEffectorComponent
RLPy.RIAvatar.GetHikEffectorComponent ( self )
Get human IK effector component of the object.
Returns
Pointer of the RIHikEffectorComponent object - RLPy.RIHikEffectorComponent
GetMaterialComponent
RLPy.RIAvatar.GetMaterialComponent ( self )
Get material component of the object.
Returns
Pointer of the RIMaterialComponent object - RLPy.RIMaterialComponent
GetMorphComponent
RLPy.RIAvatar.GetMorphComponent ( self )
Get morph component of the object.
Returns
Pointer of the RIMorphComponent object - RLPy.RIMorphComponent
RLPy.RIAvatar.GetSkeletonComponent ( self )
Get bone component of the object.
Returns
Pointer of the RISkeletonComponent object - RLPy.RISkeletonComponent
GetVisemeComponent
RLPy.RIAvatar.GetVisemeComponent ( self )
Get viseme component of the object.
Returns
Pointer of the RIVisemeComponent object - RLPy.RIVisemeComponent
SetVisible
RLPy.RIAvatar.SetVisible ( self, kTime, bVisible )
( Experimental Function ) Set visible status
Parameters
kTime [IN] Specifies the time to set visible - RLPy.RTime
bVisible [IN] Visible status - bool
Return Values
RLPy.RStatus.Success Success
RLPy.RStatus.Failure Fail
