IC Python API:RLPy RRgb
From Reallusion Wiki!
Jump to: navigation, search
Main article: Modules. Last modified: 04/13/2020
Description
Primary color class that stores data for red (R), green (G), and blue (B). The value stored in RRgb ranges from 0-1, which represents 0 to 255 in color value. You can swtich between these two representations in different ways; For example, the range of values retrieved by R is 0 to 1, and the range of values retrieved by Red is 0 to 255. In addition, preset colors are provided for direct usage:
Constant Value
RLPy.RRgb.BLACK RLPy.RRgb(0, 0, 0)
RLPy.RRgb.WHITE RLPy.RRgb(1, 1, 1)
RLPy.RRgb.RED RLPy.RRgb(1, 0, 0)
RLPy.RRgb.GREEN RLPy.RRgb(0, 1, 0)
RLPy.RRgb.BLUE RLPy.RRgb(0, 0, 1)
RLPy.RRgb.YELLOW RLPy.RRgb(1, 1, 0)
RLPy.RRgb.CYAN RLPy.RRgb(0, 1, 1)
RLPy.RRgb.MAGENTA RLPy.RRgb(1, 0, 1)
RRgb does not include alpha data. Use RColor instead if alpha channel is needed. This class also provides ways to convert to other color formats:
 1 # create color
 2 color_red1 = RLPy.RRgb(1, 0, 0)
 3 color_red2 = RLPy.RRgb()
 4 color_red2.From(255, 0, 0)
 5 color_red3 = RLPy.RRgb.RED
 6
 7 # print color
 8 print( color_red1.R() )         # 1
 9 print( color_red1.Red() )       # 255
10
11 # convert different format
12 print(hex(color1.ToXRGB()))     # 0xff0000
13 print(hex(color1.ToCOLORREF())) # 0xff
See Also: RColor
Member Functions
B ( self, args )
Get the blue value of this color (0-1).
See Also: Blue
Returns
Value for the blue channel (0-1) - float
1 color1 = RLPy.RRgb(0, 0, 1)
2 print(color1.B())               # 1
Blue ( self )
Get the blue value of this color (0-255).
See Also: B
Returns
Value for the blue channel (0-255) - int
2 print(color1.Blue())            # 255
From ( self, R, G, b )
Adjust color using 32 bit (0-255).
Parameters
r [IN] Red value (0-255) - int
g [IN] Green value (0-255) - int
b [IN] Blue value (0-255) - int
Returns
(0-255) color - RRgb
1 color1 = [[IC_Python_API:RLPy_RRgb|RRgb]]
2 color1.From(255, 0, 0)
FromCOLORREF ( self, arg2 )
Adjust color using COLORREF (0xbbggrr).
See Also: ToCOLORREF
Parameters
arg2 [IN] COLORREF data
Returns
Changed color - RRgb
1 color_red2 = [[IC_Python_API:RLPy_RRgb|RRgb]]
2 color_red2.FromCOLORREF(int(ff0000, 16))
FromXRGB ( self, arg2 )
Assign this color using hexadecimal (0xrrggbb).
See Also: ToXRGB
Parameters
arg2 [IN] RGB hexadecimal value - HEX
Returns
2 color_red2.FromXRGB(int(0000ff, 16))
G ( self, args )
Get the green value of this color (0-1).
See Also: Green
Returns
Green value of this color (0-1) - float
1 color1 = RLPy.RRgb(0, 1, 0)
2 print(color1.G())               # 1
Green ( self )
Get the green value of this color (0-255).
See Also: G
Returns
Green value of this color (0-255) - int
2 print(color1.Green())           # 255
Normalize ( self )
Normalize RGB values so that their sum equals 1.
Returns
Normalized color - RRgb
1 color1 = RLPy.RRgb(1, 1, 0)
2 color1.Normalize()              # (0.5, 0.5, 0)
R ( self, args )
Get the red value of this color (0-1).
See Also: Red
Returns
Red value of this color (0-1) - float
1 color1 = RLPy.RRgb(1, 0, 0)
2 print(color1.R())               # 1
Red ( self )
Get the red value of this color (0-255).
See Also: R
Returns
Red value of this color (0-255) - int
2 print(color1.Red())            # 255
Saturate ( self )
Clamp the RGB values to a range of 0 and 1. Values under 0 will become 0, and values over 1 will become 1.
Returns
This color saturated (RRgb) - RRgb
1 color1 = RLPy.RRgb(1.2, -0.3, 0.5)
2 color1.Saturate()              # (1, 0, 0.5)
ToCOLORREF ( self )
Output COLORREF data from this color (0xbbggrr).
See Also: FromCOLORREF
Returns
COLORREF color data - int
2 print(int(color1.ToCOLORREF()))          # 0xff0000
ToVector3f ( self )
Output 3D vector data from this color.
Returns
3D vector color data - RVector3
2 print(color1.ToVector3f())
ToXRGB ( self )
Output hexadecimal data from this color (0xrrggbb)
See Also: FromXRGB
Returns
Hexadecimal color data - int
2 print(int(color1.ToXRGB()))              # 0xff
